Old 12-16-2004, 11:36 PM #1
bcantrell bcantrell is offline
bcantrell is an unknown quantity at this point
transmission fluid level
As embarrassing as this is to ask- How do you read the dip stick for the transmission fluid level.
The stick on my 98 4x4 has a cold level with min/max notches and a hot level with min/max notches. What I need to know is are these levels static or with the motor running.
I have the owners manual but cannot seem to find the proper way to check the level.
bcantrell is offline   Reply With QuoteReply With Quote
Old 12-17-2004, 04:22 AM #2
bulldog-yota's Avatar
bulldog-yota bulldog-yota is offline
bulldog-yota is on a distinguished road
drive the 4r around make sure the tranny fluid is warm. park on level service make sure the engine stays running. cycle transmission from p to 1st and back to park. keep engine running. no go check the dip stick the normal way and check the warm level.
03 4R
www.toyota120.com
www.ih8mud.com
bulldog-yota is offline   Reply With QuoteReply With Quote
Old 12-17-2004, 09:38 AM #3
Thanks for the info. It seemed logical that it would be checked with the motor running.
I found it strange that the owners manual tells you how to check all fluid levels except the transmission.
I drained the fluid and pulled the pan and while I was cleaning the pan I noticed a river of fluid running down the drive way. The 2 quart drain and refill turned into a little over 5 quarts.
Old 01-30-2005, 04:34 PM #4
4wheeln98's Avatar
4wheeln98 4wheeln98 is offline
4wheeln98 is on a distinguished road
4wheeln98's Avatar
dont know if i missed it but where should the level on the dip stick be?
2015 Trail-Silver
265/70/17 BFG KO2
Bilstein 5100 1.75; 1" Rough Country Spacer Rear
SurfRider Foundation
4wheeln98 is offline   Reply With QuoteReply With Quote
Old 01-30-2005, 04:42 PM #5
TechWrench's Avatar
TechWrench TechWrench is offline
TechWrench will become famous soon enough
TechWrench's Avatar
That depends. If you are checking cold, use the cold marks, If hot, up to operating temp use the hot marks. Just remember, that the engine gets up to operating temp way before the transmission does. As long as it is between the min/max marks depending on temp, you are good to go. And always check the fluid level with engine running, in park, and on level ground.
I can Explain it to you, I can't Understand it for you.
'08 Tundra SR5 5.7 V8 Double Cab, White, Equalizer WD system, '91 Coachmen Catalina 260FK, '89 Grumman GSS w/35HP Force O/B, 8' Snowbear utility trailer, 2012 Polaris 500HO LE in Camo, 7 x 14 TWF Landscape trailer w/2 ramps.
TechWrench is offline   Reply With QuoteReply With Quote
Old 02-02-2011, 12:52 PM #6
kao kao is offline
kao is on a distinguished road
kao kao is offline
Any ways to make sure that transmission gets up to operating temp?
I've changed atf two days ago and now level on dipstick is slightly lower then min cold mark after some smooth driving. It's rather cold on street, about 33F. I'd like to think that cold weather is reason and atf get cold quickly.
Anyway i'm going to buy quart of atf to level up one to max cold level.
What do you think about it?
PS Sorry for getting up necrothread
kao is offline   Reply With QuoteReply With Quote
Old 02-02-2011, 01:28 PM #7
KB084RUNNER KB084RUNNER is offline
KB084RUNNER is on a distinguished road
Why? the only stupid question is the one not asked. There are guys on here that know reams about these 4 Runners. Most all of them seem eager to help each other out. That is what these forums are all about. Ask away.
2008 4Runner Limited 4.0L V6
KB084RUNNER is offline   Reply With QuoteReply With Quote
Old 02-13-2020, 10:00 AM #8
mstg46 mstg46 is offline
mstg46 is on a distinguished road
Sorry to drag up such an old post, but this was the best one I could find that was related to my question. Does anyone know how much fluid to add if the dipstick shows it's at the cold full line when the transmission is hot?
mstg46 is offline   Reply With QuoteReply With Quote
Old 02-15-2020, 03:55 PM #9
usually its 1pint... but since this is a dipstick trans & not a sealed one, its very easy to just creep up on it, add about 1 cup at a time & recheck. & be sure youre checking while fully warmed up & in park on a level surface. & fully warmed up means drive for 15-20 minutes, not just warm on the coolant temp gauge.
Old 03-31-2020, 02:32 PM #10
[email protected] rd51852@aol.com is offline
rd51852@aol.com is on a distinguished road
I have watched a few videos on this and the level that states cold, you should read when the engine is cold and the level should be between those two notches. Then start and run the engine up to operating temperature and with the engine running check again and it should now read between those two notches for the hot reading. Hope this helps.
rd51852@aol.com is offline   Reply With QuoteReply With Quote
Old 03-31-2020, 02:35 PM #11
If the tranny is hot and your engine is running I would just add a little at a time 3 ounces maybe then check level again until you get it up between the two hot reading notches.
DIY: Changing transmission fluid/ dropping transmission pan thumper 4th Gen T4Rs 11 12-18-2023 05:21 AM
how to check transmission fluid level? Idgy Maintenance/Detailing 14 01-03-2022 05:05 PM
DIY: Non-Sealed Transmission Service for 4th Gen T4R's and Prior Mike the Wino Maintenance/Detailing 59 06-02-2021 11:35 AM
Brake fluid maintenance Thai Maintenance/Detailing 4 06-02-2006 04:07 AM
The Basics: Automatic Transmission Servicing Thai Maintenance/Detailing 0 03-24-2003 03:28 PM
