10-07-2010, 09:38 PM
Synthetic oil with which oil filter?
About to do my first oil change on my 08' sr5 4x4 and was wondering what everyone here is using? Where do you buy your synthetic oil at? Walmart? what about the oil filter? Would you happen to have a part # for the oil filter? Also, where do you buy the crush washer at? Toyota? online somewhere?
BIG THANKS!
P.S. Is there a DIY oil change on here somewhere for an 08'?
10-07-2010, 10:01 PM
Walmart is great for oil and have excellent prices. I use OEM Toyota filters. The ones you get from the dealership are made in Thailand and look good. Crush washers from the dealer as well.
2005 V8 4Runner 4X4 SR5, FJ TRD Bilstein Suspension, KO2s
2020 Mercedes GLE450
2014 Wrangler Rubicon, Synergy suspension + 35 MTRs + way too many mods
10-07-2010, 10:06 PM
I get Mobile1 from Costco, and Purolator filters from pepboys.
10-07-2010, 10:07 PM
Super Moderator
Super Moderator
http://www.toyota-4runner.org/mainte...-refrence.html
What oil filter do you use?
Wal-mart is good for the oil.
The dealer or the chain parts store that carries Purolator or a Napa is a good place to get a filter.
Toyota filters are very good. The higher tier Purolator (PureOne) filters are good as are the Napa Gold filters. They'll have a crush washer too.
If you want a great filter, cheap, pick up a Motorcraft FL400S while at Wally world. (Before anyone bashes me for suggesting a Ford filter study up, I'm not making that up!) It's a little larger, about like a PL20195/25230 Purolator which several people use.
Do you want obsess and drive yourself crazy over this? Spend some time here: http://www.bobistheoilguy.com/cms/ http://www.bobistheoilguy.com/forums/ubbthreads.php
Chris
07 Salsa SR5, 4wd Cyclone pre-cleaner , Aux Transmission Cooler, Hidden Hitch 70779 (600/6000lbs, WDH=730/7300lbs), AirLift 1000, FJCruiser front springs (& now rear too!), Axle Vent Mod, Swaybar Bushing Upgrade, V6 Tick Reduction, VSC off mod, Maplight Mod, 255/75/17 Goodyear Wrangler SAs, Tailpipe Mod
10-07-2010, 10:46 PM
Banned
Banned
I use Valvoline Synthetic 5W-30 along with B&G and OEM Toyota filter. I buy my oil from Autozone.
10-08-2010, 07:31 AM
Some full synthetics I've used: (all 5w-30)
Mobil 1 Extended Protection
Valvoline maxlife blend and full synthetic
Castrol Syntec
Penzoil Platinum & Ultra
I do yearly oil changes or 7,500 miles whichever comes first.
Oil filters I've used:
Fram Extended Guard (XG3614)
Purolator PureOne
K&N
My next oil change will be Shell Rotella T5 Synthetic Blend 10w-30 1 gallon + 2 quarts Penzoil Platinum or Ultra in the Spring.
10-08-2010, 10:18 AM
Super Moderator
Super Moderator
Originally Posted by Dasanii19
It says the motocraft wont fit my 4runner here...
I know. It does fit, the bypass pressure is around 8-11psi IIRC and it'll work fine. I'll PayPal you the $4 if it doesn't fit Watch Wal-mart, seriously, they usually have this filter and when it goes on sale they let them go for $4.xx.
Chris
10-08-2010, 10:45 AM
Thanks. Ok so if you can let your oil changes go for 7,500 miles, what do you do when the maint light comes on around 3k or whatever millage it goes on at? do you just reset it? How do you keep track of when to do an oil change? do you just write it down? Also, do you have a DIY for an oil change on the differentials?
10-08-2010, 11:47 AM
Super Moderator
Super Moderator
I have a book and I write it down, with 3 cars I forget things, but I don't know anyone else that does this. I also, use the second trip meter for the oil change. The first trip meter I use for gas fill ups and the second I leave for the oil. I change at 5,000 miles. When I wonder where it is, I hit the button for the trip meter. It might say 4,288, meaning I have about 700 miles to go before I should worry about the change. I do this on both 4Runners.
Also, I forget to re-set the maint light for the oil, when it comes on, I re-set it and forget until it comes on again.
2001 & 2004 Toyota 4Runner SR5 4X2
Both V6 and both Natural White
"Yeah, I like white and I like 4Runners"
10-08-2010, 12:54 PM
Super Moderator
Super Moderator
I've used Puralator PureOne filters for over 10 years now.
2010 Lexus RX350
'99 4RUNNER Highlander SR5 4wd *Sold
10-08-2010, 01:27 PM
Super Moderator
Super Moderator
For years I have only gone with the oil filter manufactured for the car company. Honda's only had Honda filters, Toyota only had Toyota filters. When I bought the 04 4Runner used in 2008 I changed the oil the next day and used a Puralator PureOne and have been fairly impressed with them. After 2 or 3 changes I noticed a difference in the oil, I think the old owner did not change the oil that often, well not as often as I do.
I still have quite a few Toyota filters for my 2001, when I run out, I may go with the PureOne.
As for buying items, I buy the Toyota parts on-line at the cheapest place I can find. I buy at least a dozen crush washers when I order and I use them in all 3 of my Toyotas. The oil, Mobil 1 I buy at Costco when I have a coupon, Pep Boys when there is a coupon, or at Wal Mart when I don't have a coupon. I also have gotten coupons from links that other members have posted. Right now I have about 29 quarts of Mobil 1 and 12 quarts of Castrol GTX (for my older Toyota Previa). So, I stock up, when they are at a certain price. For me, $4 a quart for Mobil 1 is really hard to beat, when it is that price, I stock up on it.
Picture of the PureOne filter in my 04.
10-08-2010, 06:52 PM
Super Moderator
Super Moderator
Lots of good DIY threads in the sticky at the top of this page. http://www.toyota-4runner.org/mainte...diys-faqs.html
I track oil changes on trip odometer 'B', I use 'A' for gas mileage tracking... All the chain parts stores giveaway oil reminder stickers like a shop puts on your car.
As for the Maint light, I use like Peter does which is to say I pretty much don't use it.
Chris
10-16-2010, 05:01 PM
Maintenance Light
The maintenance light is a good reminder for rotating the tires and not much else.
Mike
10-18-2010, 12:52 AM
I use Mobil 1 and usually buy it at Walmart or anywhere it's on sale. The washers you can get just about anywhere. I use the OEM filters and buy them at my local stealership. They sell them at a discount if you buy 3 or more.
'07 Galactic Gray 4Runner Sport Edition 4X4 V8
Icon 2.5" coilovers with remote resi's | LT285/70/R17 Goodyear Duratracs | SCS Stealth 6 wheels | Light Racing UCA's | Bud Built front skid | Shrockworks Sliders | Toytec diff drop | Volant CAI | PIAA 520 ATP lights | Removed resonator, rerouted exhaust out the side | WeatherTech floor liners | Rear diff breather mod | GX470 driveshaft | Mobil 1 in all the boxes
