10-24-2010, 08:07 AM
I don't have any experience site the Karcher Brand, but I'd go with an electric unless you have a need for gas (portability, more power, etc.)
A power washer is great for undercarriage dirt etc.
On the paint, I'd stay back at least a foot. Be careful near paint chips or scratches. There's a chance of pealing up some paint.
In the reservoir, I use simple green underneath. Palmolive when I'm stripping wax. And Meguars wash in between waxes.
Good luck.
2007 SR5 4Runner V6 4X4 - Nautical Blue
10-24-2010, 09:12 AM
Good luck.
Sounds like you have a PW your happy with? If so, what brand/model, and would you buy it again?
10-24-2010, 09:27 AM
Ehh, it's ok. A Husky 2000 psi electric, 110v.
It was $199 at home depot.
For 99% of tools my motto is buy the best the first time. I just couldn't seem to justify $400+ on a powerwasher.
It works well. My complaint is the ground fault indicator safety plug seems to trip more than it should. I see why it's there, but I'd like to cut it off and replace it with a STD plug.
I'm actually pulling out the washer today for an undercarriage wash after a beach run. I'll grab some pics.
10-24-2010, 09:31 AM
10-24-2010, 12:43 PM
Super Moderator
Super Moderator
Unless you're doing a lot of pressure washing and need the added power, I would stick with an electric. No maintenance on electric pressure washers. Gas ones are usually upwards of 3000 psi and up. Electrics are between 1500 to 2000 psi.
I have a Karcher electric one rated for 1750 psi, it works well and I have no complaints about it.
A must have accessory with a pressure washer is a foam cannon. No need to bother with a bucket.
Autogeek Foam Cannon HP, foam lance, foam wash gun, pressure washer foamer
'06 Limited V6
Amy's Mom: "Who's that you're talking to?"
Amy: "It's Uneek, spelled in a 'unique' way."
11-02-2019, 01:30 PM
Real Name: Michael
Real Name: Michael
I'd say electric if you're only going to use it for vehicles. I have a nice gas one from Costco that I've had for years and it's great but I have to change the oil and it's sucks gas super fast. Gas is super handy for driveways and other things where you may be away from the house, electric is quieter.
One thing I noticed on a lot of electric is the lack of nozzle / attachment capability. I use a foam cannon and need the ability to attach things.
This was a strip wash before sealing so it wasn't a ton of foam but a foam cannon is awesome.
IMG_20190921_115716 (1) by Michael Starmer, on Flickr
11-03-2019, 12:35 PM
I also have the Sun Joe SPX3000 electric washer. For the price I paid on Amazon for it, I have no complaints. Everything works great for my needs as far as washing my vehicles and it comes w/ 5 nozzles of which I only use one, which is to rinse and wash off my vehicle.
As for the foam cannon, check on Amazon for the foam cannons. Probably cheaper than the name brand ones. This is what I purchased in Amazon.
https://www.amazon.com/MATCC-Pressur...s%2C240&sr=8-9
No complaints on this foam cannon. It's worked every time myself or my kids have used it.
2002 4runner SR5
2005 Sequoia SR5
11-03-2019, 03:06 PM
Real Name: Eddie
Real Name: Eddie
If you go electric, keep in mind the amp draw at start up and running.
Most residential circuits are 15A. If there is anything else on the circuit where you use the PW, it will most likely trip the circuit. Royal PITA unless you have a dedicated circuit for your PW.
I only used me electric PW 5 times in 10 years for this very reason, and recently sold it since it was only collecting dust.
Good luck,
Eddie
2001 T4R SR5 - 180k miles and counting.
11-04-2019, 01:39 PM
I've used several different electric PWers (ones from big box stores) and plugged them into power strips that had multiple other things plugged into them. Never had a single issue as long as none of those other things were running at the same time. Nothing special about the electric systems at any of the places I used them, either.
Maybe if I had used a higher power AR Blue or Kranzle things would have been different.
03-26-2020, 11:02 AM
Sorry for bumping such an old thread but I would like to say that electric pressure washers are better than gas. But it is only my opinion. I have used a lot of different pressure washers and yes, Karcher is among the best washers. Which one have you chosen?
01-13-2022, 07:56 PM
In my humble opinion I believe they both have a place in the detailing world. For a number of years I had exclusively used a Dewalt 3400 psi gas power washer. It’s very powerful, easily removes dirt and grime. Unfortunately, it’s loud, expensive to run (using TruFuel) and a bit overkill for maintenance washes.
I’ve recently purchased a Kranzle 1122TST and I have to say I’m quite pleased. It doesn’t have the power of gas, but for maintenance washes, it’s excellent. There’s enough power, produces enough foam when using my foam cannon. The feature that I think is ideal, is the stop start. Unlike my gas power washer, the machine only turns on when you squeeze the trigger.
Gas is great for disaster details, but I think most people would find electric are more than adequate for everyday use.
