Old 11-03-2010, 03:29 AM #1
A/V1's Avatar
A/V1 A/V1 is offline
Real Name: Brad
A/V1 is on a distinguished road
A/V1's Avatar
Real Name: Brad
Lightbulb Window Moulding Removal?
Hey everybody. I'm trying to figure out how exactly to remove the winshield side moulding without breaking it. It seems to pull out fine from under the roof rack mounts, but once I get to the windshield, it feels like it is in there solid.
According to the repair manual, you should be able to just pull it out by hand. Anyone else done this? I just want to make sure before I snap it in two, or break something else in the process.
The reason I want to remove it is I'm trying to run GPS & XM antennas up to there and need to run the wiring through this channel. I wish I could take the credit for this idea, but I remember seeing another member do this some time ago. I don't think he mentioned how he removed the moulding though...
Window Moulding Removal?-windshield-moulding-001-jpg
The moulding in question is marked in red (I want to remove the other side but it should be the same). Any help would be appreciated!
Vehicle: Black 2003 T4R Limited V8 4WD Mods & Equipment: Hail Damage; Kenwood DDX573BH/ rear camera; GX470 Overhead; DC power, A/V aux jacks, & USB plug inside center console box; DAC switch relocate; Interior LED swap; Footwell LED lighting; Muth heated signal mirrors, LED tails, & Valor exhaust tip.
Support our troops!
A/V1 is offline   Reply With QuoteReply With Quote
Old 11-04-2010, 04:30 AM #2
asm asm is offline
asm is on a distinguished road
asm asm is offline
I don't think Yu can simply pull the molding out. They likely to be glued in with sealent. The sealent is what's actually holding the window in place.
asm is offline   Reply With QuoteReply With Quote
Old 11-04-2010, 06:23 AM #3
A/V1's Avatar
Real Name: Brad
A/V1's Avatar
Real Name: Brad
Well, you are correct about the upper moulding, and there is an adhesive dam that goes around the window opening, but the side mouldings simply seem to snap in place. What the hell, I'm gonna try it. Here I've included the removal & installation of the moulding pieces...
Window Moulding Removal?-windshield-moulding-002-jpg
Support our troops!
Old 02-01-2015, 12:48 PM #4
DRC DRC is offline
DRC is on a distinguished road
DRC DRC is offline
I know this is an old thread but I am in need of replacing the left and right side windshield moldings on my 08 limited. This seems to be the best thread I found about how to do this however it ended without really saying if the molding just snaps in / out. From the 08 part diagram it appears to be the same as what's shown here.
Does anyone know if it's as simple as just pulling the molding out by hand and then snapping the new molding back in place?
Is there any adhesive involved?
Also, I have a roof rack, do I need to remove the front part so the molding can be placed under it or can this be done without removing that?
DRC is offline   Reply With QuoteReply With Quote
Old 02-15-2020, 04:50 PM #5
ging144 ging144 is offline
ging144 is on a distinguished road
Did anyone ever successfully do this? I've got a busted molding and want to try it.
ging144 is offline   Reply With QuoteReply With Quote
Old 07-04-2021, 01:10 PM #6
5054runner 5054runner is offline
5054runner is on a distinguished road
The answer to the above question is: yes, and it's super easy. First pop off the roof rack cover with trim removal tool, and loosen the two bolts holding the rack down. The adhesive of my molding was completely gone, so the old molding strip pulled right out. Before you remove the adhesive tape top layer, shove the new molding under the rack mount (gently) and make note of the distance you'll have to push it until it fits. Then, after eyeballing the depth, insert the new one, adhesive tape removed, quickly, before th etape begins to stick, and snap the remaining length of molding into the groove along the side of the windshield, making sure you have enough length to tuck it under the piece of molding at the bottom corner of the windshield. Tighten the bolts of the rack and replace the cover and you're done. Just don't be impatient like I was and break the cover at the corner.
5054runner is offline   Reply With QuoteReply With Quote
Window molding removal Vincent96SR5 3rd gen T4Rs 1 11-06-2010 07:24 PM
window glass molding removal help? Iroke17 Classic T4Rs 4 04-23-2010 05:01 PM
window tint film removal jlfindley74 Classic T4Rs 1 03-22-2009 08:39 PM
Window vent visor removal phishtaco 4th Gen T4Rs 1 10-13-2008 03:25 PM
window moulding removal bluerunner Classic T4Rs 3 09-21-2005 03:57 AM
