Old 11-11-2010, 03:11 PM #1
BIG BIG is offline
BIG is an unknown quantity at this point
BIG BIG is offline
Rear Diff Oil Change Question '08
I have a 2008 2WD V6 4Runner I just bought with approx. 43k miles. I would like to change my rear differential oil. I would like to know what type of fluid to use and what is the capacity?
Mine as the "auto limited slip differental" (Maybe all 08's have this) and it has a tag on the fill plug of the rear diff saying something the effect that it uses a "special" oil. I just want to be sure and use the correct fluid.
BIG is offline   Reply With QuoteReply With Quote
Old 11-11-2010, 05:45 PM #2
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
There is no special fluid. Just use 75w-90 Limited Slip type IV to V API rated stuff. As for capacity: 2.7 US Quarts.
<<<< is offline   Reply With QuoteReply With Quote
Old 11-12-2010, 05:22 AM #3
asm asm is offline
asm is on a distinguished road
asm asm is offline
Actually, instead of 75W-90, my 2006 manual suggest SAE 90 for above -18C degree. 80W-90 for below -18C.
75W-90 may be on the thin side especially if you live in the sun belt.
B
asm is offline   Reply With QuoteReply With Quote
Old 11-12-2010, 07:19 AM #4
lost_in_the_woo lost_in_the_woo is offline
lost_in_the_woo is on a distinguished road
Try Royal Purple
I have run Royal Purple for years and I have been very happy with it. I put in the 75W-90 and no friction adder is required for your limited slip.
lost_in_the_woo is offline   Reply With QuoteReply With Quote
Old 11-12-2010, 08:26 AM #5
jstutz101 jstutz101 is offline
jstutz101 is on a distinguished road
More important then what kind of oil to use is be sure to remove the fill bolt first before the drain! I just did mine a few weeks ago and it was super tight. After it came out the rest was easy.
jstutz101 is offline   Reply With QuoteReply With Quote
Old 11-12-2010, 08:32 AM #6
echo4tango echo4tango is offline
echo4tango is on a distinguished road
I do not like amsoil ENGINE oil but they do make very good gear oil. Amsoil is what i use in all my diffs
___________
JT
2001 SR5 106,000 miles
echo4tango is offline   Reply With QuoteReply With Quote
Old 11-12-2010, 11:09 AM #7
BIG BIG is offline
BIG BIG is offline
Thanks to all. I guess all 4th Gen 4Runners have a limited slip type diff and need the oil with the additive to protect the LSD? I know my 08 button on the dash is different than the 07 and older models that have a button that say "Auto LSD". Even though the buttons read different, I guess the rear diffs are the same?
Old 11-12-2010, 07:16 PM #8
CJ3Flyr's Avatar
CJ3Flyr CJ3Flyr is offline
Super Moderator
CJ3Flyr will become famous soon enough
Super Moderator
CJ3Flyr's Avatar
Originally Posted by BIG View Post
Thanks to all. I guess all 4th Gen 4Runners have a limited slip type diff and need the oil with the additive to protect the LSD? No. No 4th gen needs the additive, 2wd or 4wd. I know my 08 button on the dash is different than the 07 and older models that have a button that say "Auto LSD". Even though the buttons read different, I guess the rear diffs are the same?
As far as the fluid is concerned all the differentials in the 4th gens are 'open-diffs' (non-limited-slip). If you happen to have coveted TE with the locking rear diff that still doesn't require the limited-slip additive. The only limited-slip type diffs that require the additive pack are clutch-type limited-slips.
All the 4th gens 'limited-slip' action is created by the brakes, the Torsen diff in the t-case or a no-slip locking mechanism not clutches in the differential.
CJ3Flyr is offline   Reply With QuoteReply With Quote
Old 11-13-2010, 01:48 PM #9
airfranz airfranz is offline
airfranz is an unknown quantity at this point
What does the "TE" designation for the locking diff, where can this be found, at the beginning of the VIN....ie. JTE.....? I have an 06 sport with a button on the dash to the left of the steering wheel that has an X on the transfer case and four corresponding wheels. When its depressed, the same symbol illuminates by the fuel gauge.
Getting ready for my 90k mile service and the stealer told me that the diff fluid is special and cost $400 to drain and fill....??? Any thoughts..?? Thank you
airfranz is offline   Reply With QuoteReply With Quote
Old 11-13-2010, 06:38 PM #10
CJ3Flyr's Avatar
Super Moderator
Super Moderator
CJ3Flyr's Avatar
Originally Posted by airfranz View Post
What does the "TE" designation for the locking diff, where can this be found, at the beginning of the VIN....ie. JTE.....? '09 was the only 4th gen TE (Trail Edition model). I have an 06 sport with a button on the dash to the left of the steering wheel that has an X on the transfer case and four corresponding wheels. When its depressed, the same symbol illuminates by the fuel gauge. That's the lock for the center-diff.
Getting ready for my 90k mile service and the stealer told me that the diff fluid is special and cost $400 to drain and fill....??? Any thoughts..?? The dealer needs to get off of crack. Thank you
If all they are doing is a t-case, rear and front axle fluid change that requires 7 qts of fluid that costs $8-$12/qt and 1 hour.
I know you're not asking about DIY but skim this and it'll give you an idea of what they're doing.
http://www.toyota-4runner.org/mainte...-included.html
Old 11-14-2010, 11:56 AM #11
KB084RUNNER KB084RUNNER is offline
KB084RUNNER is on a distinguished road
$400 for 7 quarts of oil? Tell them Then find another dealer or independent shop or DIY. I did mine in 2 hours and it took 7 quarts of Mobil1 75w90LS gear oil from autozone for $72. Plus the crush washers for the front dif, tcase and rear diff for $15. $300 for labor is a bit steep.
KB084RUNNER is offline   Reply With QuoteReply With Quote
Synthetic Engine Oil Thai Maintenance/Detailing 114 02-18-2023 01:39 PM
Oil Change Fraud. JP4RNR 4th Gen T4Rs 21 01-19-2016 06:19 PM
Rear Diff. oil leakage awdjunkies Maintenance/Detailing 6 05-17-2008 11:00 PM
First oil change today, couple of observations - questions G.I.G. 4th Gen T4Rs 11 09-23-2007 10:18 PM
