Old 05-28-2020, 02:37 AM #16
sampson967 sampson967 is offline
sampson967 is on a distinguished road
I know the general idea of gear oil with different ratings for viscosity under certain temperatures... can anyone tell me if there’s any specific gear oil that would be best for running an 07 SR5 4WD in Phoenix, Arizona? I hear the standard for the T4R is 75W-85 but we get temps up to 120 over the summer, it’ll be at 111 by this weekend. Thanks for the recommendations!
sampson967 is offline   Reply With QuoteReply With Quote
Old 03-09-2022, 04:01 AM #17
4-Funner 4-Funner is offline
4-Funner is on a distinguished road
Originally Posted by Acidmeld View Post
Toyota requires synthetic 75w-90 and i wouldnt run anything less. Personally i run 90w-135. Little heaver, keeps driveline quieter, probably hurts my mileage...
AFAICT, and I'm not sure if the difference matters or not, Toyota specifies API GL–5 SAE 75W–85 (per TSB DL003-07) in the front and rear differentials and it matters if you have a limited slip diff or not in the rear, and API GL-5 SAE 75W-90 in the transfer case.
Prior to the TSB Toyota factory service manual specified API GL-5 API GL–5 SAE 90 front and rear diffs in climates above 0 deg F and SAE 80 or 80W-90 in colder.
What gear oil? V8 4th gen 4x4-4runner-gear-oil-tsb-jpg  What gear oil? V8 4th gen 4x4-t4r-gear-oil-jpg
4-Funner is offline   Reply With QuoteReply With Quote
Old 08-03-2022, 01:53 PM #18
Ali0227 Ali0227 is offline
Real Name: Ali
Ali0227 is on a distinguished road
Real Name: Ali
Not trying to be disrespectful, but why do you say Toyota requires synthetic. I have an 04 and specs do not mention synthetic. I am aware of the TSB DL003-007 for synthetic 75W85 but didn’t think it was requirement and was only recommended b/c Dino and weight difficult to find. ??? I can actually find original spec Toyota brand oil at one dealership which is shocking after calling several. Some dealerships using synthetic for my VIN and others using conventional. Curious your thoughts.
Ali0227 is offline   Reply With QuoteReply With Quote
What gear oil are you using? G.I.G. Maintenance/Detailing 32 05-14-2013 04:34 PM
Gear Oil to Prevent Gear "whine" - suggestions? BIG 4th Gen T4Rs 5 11-18-2010 11:54 AM
Proper A/T Gear to be used with L4 gear toyslug 5th gen T4Rs 5 08-05-2010 05:23 AM
4th gear??? astar4runner 3rd gen T4Rs 5 09-01-2008 10:49 AM
gear oil TopRunner 3rd gen T4Rs 2 07-31-2008 09:02 PM
