Transfer Case Leak -- Output Shaft Seal
Hey folks,
It looks like I have a leak at my transfer case where the drive shaft connects. Doesn't seem to be the actuator, fortunately.
I've seen some of the threads (and how the problem area is knocking the staked 30mm nut) and want to give this a try.
1. But what are the part numbers for the 2 front seals?
Transfer case drive shaft output shaft isn't revealing anything for me. I'm driving a 2008 T4R Limited V8 w/125,000 miles.
I noticed a few drops on the driveway after off roading so went in and cleaned up, and saw a nice bash into the little skid plate. So changed the fluids again while I was at it (Shell Spirax at 35k) and it doesn't look like it's gotten worse (I did make a mess so it's not any not a stream or any larger puddling).
I've hearing good things about the White Shepherd Stop Leak and Conditioner from the other threads dealing with the actuator.
2. Anyone see any harm in tossing in a bottle?
Thanks!
