Real Name: Kyle
Real Name: Kyle
Update. I went ahead and swapped my abs sensor wire out and turned on the key to find the flashing continued. I unplugged the battery for a few minutes. Turned on the key and it was gone. Started the engine for a few seconds and it was still off. Turned key back on a couple minutes later and it was back. Then it occurred to me that when I was repairing the initial broken wire, a similar situation arose where I could not get the truck to let go of the flashing lights.. Although at that time it was a different set of flashing lights. What the common denominator was/is is the fact I have a Scangauge 2 plugged in. And although it isn't storing any codes, it seems to if not cause, certainly agitate these issues when I'm trying to hunt them down. I unplugged the Scangauge. Then I turned the key back on. Flashy lights gone. Plugged the Scangauge back in. Noticed all data strangely was now absent in the Scangauge, but no blinky lights anymore. I think for me from here on, first thing I will do is unplug the Scangauge if/when this occurs. What was the original cause? No clue. I've since driven 50 miles with no return of the blinky lights.
03 Limited V8 4WD
