Originally Posted by mikey's2010SR5
@LT
So I bought my ICON Billet UCAs from you guys in December and got them a couple of months later. I have since put them on my 5th Gen 4Runner and got my alignment done twice. Both times the techs were not able to get every value within spec. The last time I brought it in the tech stated it appeared the arms were actually too long! I have the adjusters all the way in and he said they needed to go in further to get everything within spec.
As my truck sits the camber is within spec but the caster is out of range on the low end. The tech also maxed out the factory adjustments to achieve this.
Is it possible I was shipped the wrong set of arms? I need help, lot of money was spent on these arms and I can't get within spec.
Tried email you guys but have yet to hear.
Thanks
Mike
Mike,
That sounds rather odd that your guy cannot get the caster back to factory specs. There are only two UCA's that that could fit your 4Runner either the FJC/4Runner or Tacoma with the only difference being the spindle taper going into the spindle. When we have our alignments done the are usually around the 2.9-3.1 mark so if you are within specs I wouldn't worry about it.
We have installed a number of these and our alignment place hasn't had any problems. If you would like to discuss it further give Icon a call 951-638-4266 and they can see if there is anything unusual about your billet UCA's.
