First off, let me say Hello and i hope to learn a lot from this forum. secondly I have looked quite a bit through here and I do know there is a search function to make use of. BUT ( there always is a big butt) i have to get this problem fixed and quick as my wife is a nurse and does not drive..... anyways here we go, I have a problem with my key not wanting to turn in the ignition. it used to do it for a bit then finally work, it has now come to the point that it will not turn at all anymore. i cannot get the key into the ACC position to remove the tumbler. right now i am at the part where i have removed the two bolts holding up the steering and could remove the screws on the ignition. but i do not know what to do at this point. will disconnecting the battery help with turning the key into the ACC position?
i have never seen that question addressed and that is the one i have been wondering i do not want to take anything apart or off that i do not have to. I can take pictures if that would help I am just broke and trying to fix this as cheaply as i can as i do not get my next student loan check till the end of September. thanks in advance. also if anyone needs help with computers, i can trade knowledge with you.. I am Toyota stupid. i guess admitting you have a problem is the first step, right?
