Old 01-28-2014, 08:35 PM #1
Brutalguyracing Brutalguyracing is offline
Real Name: 03 v8 Limited
Brutalguyracing is on a distinguished road
New 4Runner Owner Here Former Tacoma Owner
so i had a 09 tacoma up until last week when it got totaled
now i just picked up a 2003 4Runner limited with 81k on odo
have many question but here is a start...
......will my king coils from my 09 tacoma work on the 4 runner?
what other parts if any are interchangeable ?
i need skids, sliders, bumpers in near future...
but for now...cv's,
timing belt and water pump i think
how hard is the timing belt to change
does the water pump need to be replaced at 90k also?
what else should be done?
i am planning on doing the vvvv
rear diff breather mod?
im looking to go 33's and lift it?
i also have a slight belt chirp i will have to look into.....
let the fun begin.....
any tips or advise is welcome......
Brutalguyracing is offline   Reply With QuoteReply With Quote
Old 01-28-2014, 10:07 PM #2
zopperman's Avatar
zopperman zopperman is offline
Moderator
Real Name: Zak
zopperman is on a distinguished road
Moderator
zopperman's Avatar
Real Name: Zak
WELCOME TO T4R.ORG
your kings will fit, the front ends are identical. UCA's etc. will fit too. Get some 33s'. Use the kings for front lift. You will need 3" to clear 33's.
Get a rear coil spring lift. OME is popular for added rear weight. Check out the link in my sig for 4th gen suspension stuff. 33's may rub a little on the frame and you *might* have to do a body mount chop.
The T belt is hard. I'm doing mine in the spring, hopefully with a guy from TW in PA. There are a few write ups.
2UZ-FE R&R T-Belt & Water Pump
rear diff breather is stickied at the top of the offroading section.
zopperman is offline   Reply With QuoteReply With Quote
Old 01-28-2014, 10:15 PM #3
Originally Posted by zopperman View Post
WELCOME TO T4R.ORG
ome is the way i want to go.....
i carry allot of junk in the truck...
planing on rear with swing out 2 (5) cans..my cbi can holder, hi lift...and a big ass cooler inside......
so i dont know if there is something better suited for my needs
i am trying to do this once......
so your saying tacoma uca's will work
what about wheel bearings and cv's, spindles
are they the same as well....
i have tons of parts and before the fire sale starts id like to know what works....
thanks for all the help.....as you might know i need it.....
the timing belt and pump...is there a average price guys have been paying at the stealership??????
Old 01-28-2014, 10:25 PM #4
zopperman's Avatar
Moderator
Real Name: Zak
Moderator
zopperman's Avatar
Real Name: Zak
Yeah any time man. All that stuff will work. You're not talking lift spindles are you? Are yours gusseted or something?
Wheel bearings are the same, CVs i'm not sure but I would imagine they are. I'm not sure about the front diffs which would be the determining factor, but I would imagine they are.
Just be warned, the CBI dual swing out rear bumper is almost 2500 when all is said and done. Definitely go OME 895e's in the back and 886 in the front for all the added weight. The 895e's are like 45% stiffer than stock rate IIRC which (stock is around 180) - I guess you're new to the whole coil sprung 4 linked rear thing. Way better than leafs.
T belt is around 1k usually. Seen it as cheap as 650 and as much as 1400.
Old 01-28-2014, 10:45 PM #5
nope reg spindles.....
never know when you need one....might gusset these and when i get ready to do the cv's install them....
i will just your my kings 700lb spring ext travel on the front if they will fit....
its nice to know my spare wheel bearing will work......
will have to check and see what diff is in there tho......
pretty sure i saw a hydraulic line to my shock .......
and is cbi the only one who makes one with swing out?
might have to have one fabbed that's allot of money
and whats it weigh of it........
yea coils in the rear will be a whole new adventure.....
if the front ends are the same i am like a chop shop...have whole front end out in an hour......
i also have a second set of lca's
i wonder if my skids would fit
Old 01-28-2014, 10:50 PM #6
zopperman's Avatar
Moderator
Real Name: Zak
Moderator
zopperman's Avatar
Real Name: Zak
Skids won't fit, LCAs will. Rear bumper options are limited. CBI is by far the best. It's heavy. The rear is easier than the front. I can do shocks in 10 mins a side, springs in 20
KILL IT WITH FIRE. That is XREAS, cross linked fp and rd and rp and fd shocks. You have to eliminate the whole system or do the two linked shocks together. search around for more info but don't just throw the kings on without replacing rear shocks too. I'd pair OME shocks & springs.
Old 01-28-2014, 11:14 PM #7
are you saying sell the kings and go full OME ?
ok so skids go for sale
Old 01-28-2014, 11:29 PM #8
zopperman's Avatar
Moderator
Real Name: Zak
Moderator
zopperman's Avatar
Real Name: Zak
Sorry should have clarified. Keep the kings for the front, I would go OME springs in back paired with their shocks. IF you have extra cash to blow, fox makes nice remote resi shocks, icon and radflo are also good to look at. Not totally sure how some of these bigger name kits go with rear weight. I know OME springs are the stiffest available, but I am not sure what shock is best to pair them with for comfort. I can't imagine a fox or icon wouldn't do the trick. Bilstein 5160's are a cheaper remote resi, not sure how aggressive their dampening is though.
Old 01-29-2014, 07:58 PM #9
So i need to add some 12v outlets
Where is everyone putting theirs
Also need new bluetooth radio
Old 01-29-2014, 08:46 PM #10
zopperman's Avatar
Moderator
Real Name: Zak
Moderator
zopperman's Avatar
Real Name: Zak
Check out @gshadow325 's outlet mod, it's pretty cool. Start posting up in the 4th gen section, people are less incline to read over here, especially when the forum is running like it has been
Old 01-29-2014, 08:54 PM #11
gshadow325 gshadow325 is offline
gshadow325 will become famous soon enough
you rang? click on the link in the sig, as you read the thread, you should see link for my DIY/MODS link....its in there, since you have a 03...lots of my mods should apply to you...cluster on all the time, 12v socket in door, underhood lighting, etc
Also welcome to T4R...go vote for zopperman for t4r of the month...he needs like 2000 more votes to win or else he is the first loser LoL!!!
gshadow325 is offline   Reply With QuoteReply With Quote
Old 01-29-2014, 09:58 PM #12
Thats awesome
And the last part is priceless
Old 01-30-2014, 11:10 AM #13
Speedy Gomez Speedy Gomez is offline
Banned
Real Name: Joe Gomez Jr.
Speedy Gomez is on a distinguished road
Banned
to T4R.ORG!
Speedy Gomez is offline   Reply With QuoteReply With Quote
Old 02-02-2014, 02:17 AM #14
momo.75's Avatar
momo.75 momo.75 is offline
Registered User
Real Name: Morris
momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of
Registered User
momo.75's Avatar
Real Name: Morris
Welcome to T4R.ORG!......
momo.75 Build ThreadClick to order T4R.ORG Decals • @urban_overland
momo.75 is offline   Reply With QuoteReply With Quote
Old 02-02-2014, 08:26 AM #15
Thanks guyz
First 4 Runner (Recovering Tacoma Owner) GRAY_GHOST New Members 0 08-22-2012 09:15 PM
Tacoma owner looking in to a 3rd Gen 4Runner SodakTaco 3rd gen T4Rs 8 07-15-2012 11:01 PM
New tacoma owner from miami mgrande New Members 2 03-24-2010 10:17 PM
Tacoma owner looking at a 4runner, I have some questions vicnads New Members 12 09-14-2009 12:51 AM
