Just gonna post a little update with a list of all the parts that I've purchased for this rig so far. It's bordering on insanity. I've spent about $2,500 in parts (keep in mind, this is Canadian dollars and taxes) and I'm wondering if it's even worth it. It's not like my T4R is in its prime anymore. I just hope all of this keeps it going for at least 5 trouble free years.
- INTERSTATE MEGA-TRON PLUS 35 BATTERY [MTP-35] (x1)
- GROMMET, CHECK VALVE [90480-24015] (x1)
- VALVE ASSEMBLY, VACUUM CHECK (FOR BRAKE) . VALVE,CHECK [44730-60060] (x1)
- BRACKET SUB-ASSEMBLY, CATALYTIC CONVERTER, REAR . BRACKET [17503-62050] (x1)
- BAND SUB-ASSEMBLY, FUEL TANK, No.1 . STRAP,TANK [77601-35060] (x1)
- PIN (FOR FUEL TANK BAND) . PIN [90240-08118] (x1)
- BEARING (FOR FRONT AXLE HUB INNER LEFT); BEARING (FOR FRONT AXLE HUB INNER RIGHT) . BEARING [90369-54002] (x2)
- CLAMP (FOR STEERING RACK BOOT No.1); CLAMP (FOR STEERING RACK BOOT No.2) . CLAMP [90460-62006] (x2)
- COVER, DUST (FOR FRONT DRIVE SHAFT); COVER, FRONT DRIVE SHAFT DUST, LEFT; COVER, FRONT DRIVE SHAFT DUST, RIGHT . COVER,DUST; F SPORT [41336-35020] (x2)
- END SUB-ASSEMBLY, TIE ROD, LEFT . END,TIE ROD [45047-39215] (x1)
- END SUB-ASSEMBLY, TIE ROD, RIGHT . END,TIE ROD [45046-39335] (x1)
- INNER TIE-ROD [MOOG-EV433] (x2)
- JOINT ASSEMBLY, FRONT UPPER BALL, LEFT; JOINT ASSEMBLY, FRONT UPPER BALL, RIGHT . JOINT,BALL [43310-39016] (x2)
- JOINT ASSEMBLY, LOWER BALL, FRONT LEFT . JOINT,BALL [43340-39465] (x1)
- JOINT ASSEMBLY, LOWER BALL, FRONT RIGHT . JOINT,BALL [43330-39585] (x1)
- LBJ BOLT . BOLT [90080-10066] (x8)
- RING, HOLE SNAP (FOR DIFF SIDE GEAR INTERMEDDIATE SHAFT); RING, HOLE SNAP (FOR DIFFERENTIAL SIDE GEAR SHAFT); RING, HOLE SNAP (FOR FRONT DRIVE SHAFT LEFT); RING, SHAFT SNAP (FOR FRONT DRIVE INNER SHAFT OUTER); RING, SHAFT SNAP (FOR REAR DIFFERENTIAL SIDE GEAR SHAFT) [90521-29002] (x2)
- RING, HOLE SNAP (FOR FRONT AXLE HUB LEFT); RING, HOLE SNAP (FOR FRONT AXLE HUB RIGHT) . RING,SNAP [90521-99114] (x2)
- SEAL, OIL (FOR FRONT AXLE HUB LEFT); SEAL, OIL (FOR FRONT AXLE HUB RIGHT) . SEAL,OIL [90312-95001] (x2)
- SEAL, OIL (FOR FRONT AXLE HUB OUTER LEFT); SEAL, OIL (FOR FRONT AXLE HUB OUTER RIGHT) . SEAL,OIL [90316-69001] (x2)
- SHAFT ASSEMBLY, FRONT DRIVE, LEFT; SHAFT ASSEMBLY, FRONT DRIVE, RIGHT. SHAFT,DRIVE [CARDONE SELECT 665134] (x2)
- ELEMENT SUB-ASSEMBLY, AIR CLEANER FILTER . ELEMENT,FILTER [17801-07020] (x1)
- FILTER SUB-ASSEMBLY, OIL . FILTER,OIL [90915-YZZD1] (x2)
- 10pcs White T10 Wedge LED 5 SMD Light Bulbs 5050 (x10)
- 2 Pcs AC 250V 15A ON-ON 2 Position SPDT 3 Screws Terminals Toggle Swith (x2)
- 20pcs T5 74 White 1-LED Wedge Dashboard Side Light Lamp Bulb DC 12V (x20)
- Black Housing Green LED Two Line 3 Digital Voltmeter 3.5-30V (x1)
- White T10 194 192 W5W 1206 SMD 30 LEDs Bulbs Side Wedge Light 8PCS (x8)
- BELT, TIMING. BELT,TIMING (W/LABEL) [13568-69095/YZZ03] (x1)
- GASKET, WATER INLET HOUSING, No.1 [16325-62010] (x1)
- GASKET, WATER PUMP. GASKET [16271-62011] (x1)
- IDLER SUB-ASSEMBLY, TIMING BELT, No.1. IDLER [13505-62070] (x1)
- IDLER SUB-ASSEMBLY, TIMING BELT, No.2. IDLER [13503-62040] (x1)
- SEAL (FOR OIL PUMP). SEAL,OIL; (J) [90311-40022] (x1)
- SEAL, OIL (FOR CAMSHAFT SETTING). SEAL,OIL [90311-38051] (x2)
- TENSIONER ASSEMBLY, CHAIN, No.1. TENSIONER [13540-62021] (x1)
- THERMOSTAT [90916-03075] (x1)
- V-BELT (COOLER COMPRESSOR TO CRANKSHAFT PULLEY), No.1 [993642-087078] (x1)
- V-BELT (FOR FAN & ALTERNATOR) . BELT,V; L=1050 [900809-109083] (x1)
- V-BELT (FOR VANE PUMP) . BELT,V; L=1070 [900809-112683] (x1)
- WATER PUMP [161006-939883] (x1)
- Auto Meter 2258 Short Sweep Electric Temperature Gauge Sender [2258] (x1)
- Auto Meter 2640 Z-Series 2-1/16" Short Sweep Electric Transmission Temperature Gauge [2640] (x1)
- B&M 70268 - SUPERCOOLER OIL COOLER [70268] (x1)
- Energy Suspension 9.5156R 3/4" Greasable Sway Bar Set [9.5156R] (x1)
- Energy Suspension 9.5161G 1" Greasable Sway Bar Set [9.5161G] (x1)
- MOOG K90681 SWAY BAR LINK KIT [MOOG-K90681] (x2)
1997 4Runner Limited V6 Auto 4x4 w/E-Locker - 184K Miles
OME 881/890 Springs, Tokico TrekMaster GU3535/GE3536 Shocks, 1" Front Diff. Drop, Front Frame Mounted D-Rings
All-Pro 1.25" Hubcentric Wheel Spacers, 265/75R16 ETS Trail Master M/T, B&M 70268 Cooler (bypassed)
2010 Matrix XRS 2.4L 5-Speed - 130K Miles
