Old 05-26-2022, 07:23 AM #31
Skip2a's Avatar
Skip2a Skip2a is offline
Skip2a is on a distinguished road
Skip2a's Avatar
Chassis Saver is a great product for covering bare metal after you clean it up and it does help to stop rust. Fluid Film seems to be a good choice also.
See ya,
Skip
Skip2a is offline   Reply With QuoteReply With Quote
Old 06-01-2022, 09:06 AM #32
Cati22 Cati22 is offline
Cati22 is on a distinguished road
I’m going to use woolwax this fall.
Cati22 is offline   Reply With QuoteReply With Quote
Old 06-06-2022, 09:27 AM #33
ed0808 ed0808 is offline
ed0808 is on a distinguished road
Those original pics look much better than most I've seen, my '04 included. I used POR15 after extensive prep work (including new steel structure for areas that were already rusted through), but unfortunately mine seems to be rusting from the inside out in spots. I've seen the Eastwood products with the spray "straws" to try to coat the inside of the frame rails, but I'd imagine prepping those inside surfaces is almost impossible. I've thought about trying to just spray used motor oil or similar into the rails, something that doesn't need to adhere like paint
ed0808 is offline   Reply With QuoteReply With Quote
Old 06-12-2022, 11:06 AM #34
Jedi5150 Jedi5150 is offline
Jedi5150 is on a distinguished road
Rust scares me more than any other damage to my possessions, be they vehicles or firearms. And even with that in mind, the OP's photos looked pretty tame. But I did just order some INOX and LAMOX, based on the video link attached. Sounds like good stuff to put on my new 4Runner when it arrives. For the first time in decades, I now live in a state that puts salt on roads.
Jedi5150 is offline   Reply With QuoteReply With Quote
Old 06-12-2022, 10:57 PM #35
DevilIncarnate DevilIncarnate is offline
DevilIncarnate is on a distinguished road
My last 4Runner was a 2011 SR5 in Chicago, where salt is spread during winter by the ton. That said, the frame of the 11-year-old 4Runner barely had any surface rust. I mostly sprayed the frame at car washes after almost every time the snow plows and their salt spreaders were on the roads unless temps were sub-zero. My new TRD ORP will be brushed with Blaster lanolin undercoating that a friend in New York (another salty state) recommended.
DevilIncarnate is offline   Reply With QuoteReply With Quote
Old 06-18-2022, 08:54 PM #36
kallixtos's Avatar
kallixtos kallixtos is offline
kallixtos is on a distinguished road
kallixtos's Avatar
Being from SoCal we’re a little spoiled. The only problem I see with that amount of rust is when you actually go to work on it. On my old 3RD Gen the sway bar end links snapped on me because the hardware was seized.
kallixtos is offline   Reply With QuoteReply With Quote
Old 06-19-2022, 03:28 PM #37
Magnatic's Avatar
Magnatic Magnatic is offline
Magnatic is on a distinguished road
Magnatic's Avatar
From the month of delivery and every year thereafter, I treat my cars with a rustproofing product. I've used Zeibart, Krown, Corrosion-Free and Rust-Check. All had good results but some more messy than others.
Magnatic is offline   Reply With QuoteReply With Quote
Old 03-07-2023, 12:06 PM #38
rschmitt rschmitt is offline
rschmitt is on a distinguished road
Seems pretty clean - for a car thats not in the west. As others have said, some wire-wheeling will do wonders
rschmitt is offline   Reply With QuoteReply With Quote
Old 03-13-2023, 08:02 AM #39
Ascelad's Avatar
Ascelad Ascelad is offline
Ascelad is on a distinguished road
Ascelad's Avatar
It doesn't look bad. I'd coat where the frame paint has chipped off to reveal the primer though.
Ascelad is offline   Reply With QuoteReply With Quote
Old 03-15-2023, 11:07 AM #40
flaconinja's Avatar
flaconinja flaconinja is offline
flaconinja is on a distinguished road
flaconinja's Avatar
Looks reasonable to me, where is the truck located?
flaconinja is offline   Reply With QuoteReply With Quote
Old 03-18-2023, 03:21 PM #41
jgosse01 jgosse01 is offline
jgosse01 is on a distinguished road
Hoping to find a rust free example when the time comes.
jgosse01 is offline   Reply With QuoteReply With Quote
Old 04-28-2023, 05:18 PM #42
mrk00k mrk00k is offline
mrk00k is on a distinguished road
not too bad.
mrk00k is offline   Reply With QuoteReply With Quote
Old 07-08-2023, 05:38 PM #43
Rusty Jones Rusty Jones is offline
Rusty Jones is on a distinguished road
New York Salt
Having just traded my ‘16 Tacoma in on a new ORP, this thread is a little disheartening. The truck was recalled for inspection of the frame, where they applied generous quantities of seam sealer in various areas of the frame - right over the un-prepped rust. Pretty sure it did nothing. Anyway, they deemed the frame acceptable and sent me on my way. No pics to share unfortunately, but it looked far worse than the OP’s 4Runner.
Around me, I think it’s a calcium chloride brine they apply on the major roads, in addition to granular salt. Don’t know if that’s better or worse for our frames.
Rusty Jones is offline   Reply With QuoteReply With Quote
Old 07-18-2023, 02:52 PM #44
simpshm simpshm is offline
simpshm is on a distinguished road
You are fine, not bad at all.
simpshm is offline   Reply With QuoteReply With Quote
Old 08-13-2023, 08:09 AM #45
4RunnerGurl! 4RunnerGurl! is offline
4RunnerGurl! is on a distinguished road
I plan to have Woolwax installed. I'm in the Midwest, and rust is always a concern.
4RunnerGurl! is offline   Reply With QuoteReply With Quote
axle , found , rear , rust , wondering
Rust issue Texas_4Runner 3rd gen T4Rs 30 08-01-2018 12:27 PM
What to do with our '98 SR5 (rust issue) marcumac General Discussions 15 04-10-2015 08:27 AM
Radiator Rust Issue muddyRUN 3rd gen T4Rs 1 09-24-2014 08:38 AM
Rust issue mordad_2000 3rd gen T4Rs 2 04-09-2014 03:01 PM
4 Runner Rust Issue Razor128mh Problems & Warranty Issues 5 11-02-2011 09:40 PM
