Old 07-25-2020, 10:25 AM #1
mystereons41 mystereons41 is offline
mystereons41 is on a distinguished road
The New Girl
Hello, new member here. This is a little unconventional but my vehicle is actually a 2009 Lexus GX470, which I’m told is similar to a Runner. Unfortunately it was jumped in reverse and I am having some issues. I tried a Lexus forum but no one responded to my question. Hoping someone can help, because it may be pretty expensive through a mechanic. I posted my question as a reply to a thread where someone is having a similar problem here:
Crossed Jumper Cables--no brakes, all maintenance lights on and beeping
I couldn’t start a new thread bc I haven’t met the 15 post requirement yet. Up to 9!
If anyone can help and reply to my question, would be really appreciated.
mystereons41 is offline   Reply With QuoteReply With Quote
Old 07-25-2020, 01:03 PM #2
Harlock's Avatar
Harlock Harlock is offline
Harlock will become famous soon enough
Harlock's Avatar
Welcome to the forum. Sorry to hear about your GX470. You may have blown one or more fuses and/or burned out some electrical component such as the ABS controller or ECU. I would start by checking for blown fuses and inspecting the fuse box itself for damage. Also, sniff around the engine compartment for a burned plasticky-smell and investigate those areas to localize the source.
No matter where you go, there you are.
2007 4Runner SR5 4WD | 4.0L V6 1GR-FE VVT-i
Philips Ultinon LED Interior Lighting, Weathertech FloorLiners, Toyo Open Country AT3 265/75/R16, Victory 4x4 Roof Rack, RacksBrax Brackets, ARB 2500 Awning & Awning Room, IceCo JP42 Refrigerator, Anker 757 LifePO4 Generator, Renogy 100w Monocrystalline Solar Panel, JVC KW-V660BT Head Unit
Harlock is offline   Reply With QuoteReply With Quote
Old 07-25-2020, 02:04 PM #3
Thumbs up
Thanks so much for your reply. It’s the ABS MTR fuse that is blown, and will blow right away when replaced. A bunch of dash lights are on with a lot of beeping, and the brakes are soft. The incident happened several months ago, I’m not sure if the sniff test would work??? I was thinking I would disconnect the Skid Control ECU (first component after the fuse) and then pop a new fuse in. If the fuse still blows, I would know if the wire that goes from the fuse to the ECU is shorted to ground. If it doesn’t blow, I guess I would assume it’s the Skid Control ECU?? I am trying to find the location of the ECU on this model through Google searches, but so far no luck.
Old 07-25-2020, 03:52 PM #4
Harlock's Avatar
Harlock's Avatar
Sounds like you're further along in determining the problem. The smell doesn't really ever go completely away. But if that much time has passed, most of it will have dissipated. Check out this thread. Start at post #10:
and this one:
Check engine light, vsc light, traction light all on after a short circuit
You might also try looking at the 2006 4Runner manual here:
Service Manual Download Links
Old 07-25-2020, 05:42 PM #5
Thanks for the links! The first link you mention is actually how I got started on this forum because it’s my exact same problem. So I had originally posted my question there but I wasn’t sure if anyone would respond since it wasn’t a new thread. The manual is super helpful. I spent several hrs today trying to Google the location of the Skid Control ECU to no avail. The manual says it’s part of the Hydraulic Brake Booster assembly. I’m not sure how far the similarity between the 4Runner and GX470 goes, but I did see one other reference when I was researching the GX that it is mounted to the Master Cylinder, which is also part of the Hydraulic Brake Booster. So hopefully that’s where it actually is on my model! Now I just need to figure out how to access it. From the drawing (attached) I can’t tell if I get to it from under the hood or from behind the dash, and I don’t have access to the vehicle right at the moment. So I guess I’ll have to wait and see. At least I have a starting point now. Any other insights, let me know. Thanks!
The New Girl-99980afb-cddd-4cf4-987d-617ba1334ecd-jpg
Old 08-06-2020, 05:42 PM #6
In case anyone else ends up having the same problem, here is what I have discovered. The Skid Control ECU is part of the Master Cylinder Solenoid, which is why you can’t find the Skid Control ECU as a separate part online. After I finally located the ECU, I disconnected it and was able to test it. The power pin and the ground pin are at the same potential, so pretty sure the thing is fried. I used a 2006 4Runner manual to figure out which pins are which. I plan to replace the entire Master Cylinder, because I think you have to take the whole thing out anyway and partially disassemble it to replace the Master Cylinder Solenoid. They sell the whole unit used on eBay for $400-$600. So hopefully that works!
lexus , question , reply , similar , thread
Ole girl needs some TLC Vansnxtweek 3rd gen T4Rs 9 05-07-2018 07:20 PM
New Girl On the Block Scotchy024 New Members 6 03-31-2014 12:21 PM
new girl lololeandra New Members 53 02-01-2014 11:41 AM
New girl from WV WVmtnmomma New Members 9 05-11-2013 07:53 PM
Another new girl :) Mercy New Members 9 10-30-2012 11:44 PM
