Old 01-11-2025, 07:34 PM #1
Sixthirteen Sixthirteen is offline
Sixthirteen is on a distinguished road
New guy with a used 4th. Gen question.
As the title says, I am new to the forum and I have a used 21 Venture edition with less than 17,000 miles. The Runner looks great both in and out. Its my first 4Runner and I have to say that on idle the engine sounds like there are things slapping and maybe clacking in there. Its only at idle after its warm. Step on the gas and it is smooth and quiet, shifts smooth also. Engine oil looks very clean. So I guess I am asking if any of you out there notice this sound on idle and if its a normal thing. Thoughts??? Thanks.
Sixthirteen is offline   Reply With QuoteReply With Quote
Old 01-11-2025, 09:40 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Model year '21 is a 5th gen.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 01-12-2025, 08:18 AM #3
Yes it is...I am new to the to the 4Runner world.
Old 01-15-2025, 02:30 PM #4
runner9999 runner9999 is offline
runner9999 is on a distinguished road
I also have a 4th gen 4Runner. Do not have these sounds. Open the hood and see where in the engine it is coming from?
runner9999 is offline   Reply With QuoteReply With Quote
Old 02-13-2025, 11:02 PM #5
- Rita - - Rita - is offline
- Rita - is on a distinguished road
What was it?
- Rita - is offline   Reply With QuoteReply With Quote
Old 02-14-2025, 11:28 AM #6
Hungryhawk Hungryhawk is offline
Hungryhawk will become famous soon enough
There is the old school auto stethoscope of taking a piece of hose and put it to your ear and onto a part-like valve cover - and see if it helps source the noise.
Be careful not to get tangled in moving parts!
And old piece of garden hose should work. Use a length that you can fully control both ends
Hungryhawk is offline   Reply With QuoteReply With Quote
Old 02-14-2025, 10:42 PM #7
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I've heard on here that the V6 makes a little noise at start up, maybe someone will chime in. It has a timing chain, tensioners, etc. and variable valve timing (I think), There is a plug you can pull and check the screens for the oil supply to the VVT for debris, I think, again maybe someone familiar with the V6 will chime in.
Old 02-14-2025, 11:56 PM #8
I have 2017 SR5 and I think your engine description is succinct!
The little filters for the valve camshaft oil, in the side of the engine block are cone shaped screens accessible behind a bolt like plug. They are rarely serviced if good clean oil is maintained always.
The 4.0 V6 is noisy. It is a truck engine and has camshafts chain not a belt.
The 0W20 recommended oil is said to add to the clatter on start up. Some owners use 0w-30 and claim it quiets start up a lot. These same "shade tree engineers" accuse Toyota of using the 0W-20 to meet fuel efficiency goals at the expense of engine life.
My miles are about 63,000 . I switched my Honda Pilot with VVT at 100,000 miles to 5w30 from 0W20 recommended. I ran it to 240,000 miles and had no engine oil related issues.
So I am currently undecided about future oil weight for my SR5.
Old Today, 07:10 AM #9
I believe it is the normal sound on startup. Ive asked other owners and they say its normal to be loud as long as it quiets down after its warms up.
Old Today, 08:05 AM #10
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
My 2012 sounds the same way. Same engine. Sometimes resembles a diesel school bus lol. Over 150k miles, bought it with 58k. She's never missed a beat. These engines are very stout. 6 bolt main bearings, over engineered internals and cylinder sleeves. Apparently they can handle a lot of boost if done right.
https://www.youtube.com/watch?si=GYDvbaSuZWHyo_j0&v=Qkwh3TBvjaw&feature=youtu.be
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
engine , idle , smooth , step , warm
Quick question tundra fabtech dirt logic question Diggo 3rd gen T4Rs 3 06-09-2016 02:33 PM
Question about FJ suspension swap (not a common question) cacarbuff 4th Gen T4Rs 2 02-18-2014 10:37 PM
2003 V8 90k Maint. Question + Steering Question zerowkul98 Maintenance/Detailing 1 10-21-2010 07:35 AM
Pro Comp Light Bar Question- Tire Rim Question rngesci 3rd gen T4Rs 1 10-25-2008 03:04 PM
