Real Name: Justin
Real Name: Justin
Welcome!
With 165k miles, the timing belt should have been changed once already. (90k mile intervals)
A fairly rare problem exists with the 3rd gens where the in-radiator transmission cooler ruptures/cracks, mixing coolant and transmission fluid together. This mixing of fluids can and will probably cause damage to some degree to the transmission. Search "strawberry milkshake" or "pink milkshake" for more info. This issue can get messy and costly, but this can be easily prevented by bypassing the in radiator cooler and installing a separate external transmission cooler or by just replacing the radiator itself with a new one.
Around 100k miles, the rear axle seals on the 3rd gens usually go bad and leak oil. You can tell if the seal is leaking by looking to see if the rear brakes look wet from underneath.
That's all the major problems that I can think of right now. But they really are reliable vehicles as long as they were taken care of by the PO.
Check out my Instagram! @808_hiker
1998 4Runner Limited Desert Dune 3.4 V6 Auto 4x4 ToyTec Ultimate/Superflex 3” Lift ~83k miles
2008 Tacoma Regular Cab Desert Sand 2.7 4banger 5MT 4x4 Bilstein 5100/AAL/Block 3” lift ~101k miles
2010 Tacoma Access Cab Black Sand Pearl 4.0 V6 Auto 4x4 TRD Off Road ToyTec Ultimate/Dakar 3” lift ~22k miles
2018 Tacoma DCSB Quicksand 3.5 V6 6MT 4x4 TRD Sport ToyTec Boss/Dakar HD 3” lift ~6k miles
