Originally Posted by mysticz
So your running the 701's which is model C59-701V. Which is rate at 250kg (550lbs) constant load.
The 677's which is model C59-677V Rated at constant load 160kg (350lbs)
Please post in the future your further experience on the 701's those might be better suit for my Runner. Thx
Sound about right on the numbers.
As far as i can tell, if i loaded down with firewood, i might come down to the bump stops on harder extreme trails.
My rides front suspension isn't normal to others also, harsher ride at 4.5" on the front also. So that might not allow some of the weight to distribute to the front and rest on the rear.
With all this said, and you having constant weight on top(RTT), my personal experience with different coils, 701s might be a better choice,
If you wish to try these to see for yourself in practical use, I have no problem with that.
If you decide to move up to to heavier coils later, just pass these along to a worthy/needy person.
