Old 10-10-2016, 04:02 PM #1
OffRoadWarehouse OffRoadWarehouse is offline
OffRoadWarehouse is on a distinguished road
ORW Special Deal on Total Chaos!!
OffRoadWarehouse.com is an Authorized Dealer for Total Chaos Fabrication!
Toyota Uniball Upper Control Arm
4130 chromoly tubular upper control arms are 100% bolt on and hand crafted in the U.S.A.
UCA's are designed with added caster to aid in retaining factory alignment specs when aftermarket lift kits are installed. This reduces the darting or wandering in the vehicle's steering when 2.5"-3" lift kits are installed.
CNC machined tapered spindle adapters convert the factory ball joint to a 1" uniball for added component strength & maximum wheel travel.
TOTAL CHAOS includes 1" I.D. uniballs that feature a heat treated stainless steel ball & heat treated stainless steel race for maximum corrosion resistance and component longevity. These uniball's also features a military grade PTFE woven fabric liner that helps prevent noise.
Custom profile upper and lower hi-misalignment spacers maximize droop wheel travel and are machined from heat treated 17-4 stainless steel.
Upper control arms combined with extended length coil over shocks will allow for up to 1" of additional wheel travel.
Urethane bushings reduce bushing deflection compared to stock rubber bushings.
Control arm pivots include zerk fittings to grease the urethane bushings & inner sleeves without disassembly.
2 stage powder coat process includes a durable clear coat to provide a long lasting finish.
Complete grade 8 hardware kit is included.
Total Chaos Upper Control Arms
Fits: 2005+ Tacoma pickup, 2003-2016 4Runner and 2007+ FJ Cruiser
Total Chaos 03-16 Toyota 4Runner
Total Chaos 96-03 Toyota 4Runner
Total Chaos Heim Pivot UCA
Fits: Fits: 2005+ Tacoma pickup, 2003-2016 4Runner and 2007+ FJ Cruiser
Buy Me Here!!!
When modifying your 4Runner one thing to consider is replacing the Upper Control Arm's. Your stock Ball joints are 1/2" while these Total Chaos uses 1" uniballs. It gives you the strength you need, more clearance to clear the coilbuckets and more articulation angle. These UCA's are PERFECT for those who have Extended Coilovers from King Shocks, ICON, Fox Shocks and many more.
If you need us to put a kit together please let us know!! We carry the above mentioned.
ICON 2.5" 0-3" Extended Travel Coilovers 03-09
Fox Racing 2.5" 0-3" Extended Travel Coilovers
Fox Racing 2.5" 0-3 Extended Travel Coilovers
Who doesn't LOVE Total Chaos Products???
  • 3/16" main body stock length fully boxed lower control arms are CNC laser cut and include internal gussets.
  • Boxed arms feature replaceable urethane pivot bushings. Pivots include zerk fitting to maintain the equipment while bolted on the vehicle.
  • 1/4" thick steel skid plate is integrated into the control arm for rock crawling protection.
  • Features a billet machined uniball adapter. Lower ball joints are upgraded to a 1" stainless steel uniball for maximum wheel travel and added component strength.
  • Dual shock capable or Jounce Shock compatible.
  • Weld-on bump stop spacers are included.
  • *These arms will not fit the 05+ Hilux Vigo or on vehicles equipped with KDSS
Buy Me!! Total Chaos Stock Uniball Lower Control Arms with Dual Shock Capability CLICK ME!!
Part # 86500
Retail Price is $1679.59, PM or Email for T4R Pricing!
RACE SERIES STOCK LENGTH CHROMOLY BOXED LOWERS
  • Racer inspired and constructed from 100% laser cut 4130 chromoly.
  • The lightest weight bolt on lower arm @ 16.5 pounds.
  • Maximizes vehicle ground clearance with integrated lower uniball cup.
  • Dual 2.5 shock capability provides maximum dampening control.
  • 1" 100% stainless steel uniball replaces factory lower ball joints.
  • Replaceable polyurethane pivot bushings include zerk fittings for easy maintenance.
  • *1.25" wheel spacers are required.
Part # 86500R
Retail Price is $1889.67 PM or Email for T4R Pricing
CLICK ME!!! Total Chaos Stock Race Series Uniball Lower Control Arms with Dual Shock Capability - 05+ Tacoma 6 Lug, 07-09 FJ Cruiser, 03-09 4Runner CLICK ME!!!
Dual Shock Hoops - Stock Length Control Arms
  • Maximize vehicle dampening control when you install a dual 2.5" shock mount system.
  • 4130 prebent chromoly shock hoops are designed to install secondary 2.5" piggy back or bypass shocks for maximum IFS dampening control.
  • Reinforces the factory coil bucket and helps reduce flex.
  • Upper shock tabs are tacked in place to aid in secondary shock location set up.
  • Includes grade 8 hardware.
  • Installation of this system requires TC 86500 boxed lower control arms.
  • Lower shock mounting clevis is included.
  • Does NOT work with stock lower control arms.
Part # 86602
Retail Price is $420.00 PM or Email for T4R Pricing!
Please Call 800-341-7757, PM or email us for a Group Pricing, We WILL answer our phones!!
Free Shipping to US, Please contact us for shipping to Hawaii, PR, Canada, etc. We ship WorldWide!!
OffRoadWarehouse is offline   Reply With QuoteReply With Quote
Old 11-14-2016, 02:14 PM #2
Check out our 4th Gen in ACTION!!
Fitted with ICON CDCV shocks and Total Chaos Uppers and Lowers!!
Stop by our FaceBook page and LIKE US!!
Like OffRoadWarehouse on FaceBook
Old 12-02-2016, 01:23 PM #3
Thank you for your orders! All tracking numbers have been emailed. We still have the UCA's available.
Newly installed Fox with Res & Total Chaos UCA's on a 16' Tacoma
If you need Coilovers, We offer Fox Shocks, ICON, & King Shocks
#EyeCandy
Old 12-12-2016, 08:49 PM #4
Thanks for your orders! We appreciate your support!! All tracking numbers have been updated!!!
PM me for Pricing!! We will NOT be undersold on Total Chaos Products!!
Back in stock with Plenty of:
#96504 Total Chaos UCA's (we are OVERSTOCKED)
#96200 1" Diff Drop Spacers
HTML code is Off
Total Chaos UCA help SouthAl 4th Gen T4Rs 4 10-02-2016 03:59 PM
Total Chaos Desertrunner25 3rd gen T4Rs 36 10-17-2015 06:49 PM
total chaos bullydog 4th Gen T4Rs 0 09-16-2012 08:08 PM
Total Chaos ric Off-Roading 7 10-29-2009 12:28 AM
