aFe POWER 51-81932 Magnum FORCE Stage-2 Si Pro DRY S Cold Air Intake System
- Adds 34% Flow Increase
- +10 HP
- +15 Lbs x ft. Torque max
Dry Intake
Pro 5R
This Stage-2 Sealed cold air intake produces 10 hp. 15 lbs. x ft. torque and outflows the factory intake by 34%. Fully enclosed in a heat-shielding molded plastic housing; this air intake system features a washable/reusable conical air filter that improves airflow for increased horsepower and torque. The housing features an auxiliary inlet duct for better airflow as well as an attractive black aluminum cover that provides ready access to the filter for servicing. This intake system also features a heat-insulating molded plastic tube that replaces the stock intake tract and directs increased air flow with improved volumetric efficiency for maximum performance. The filter is constructed with 100% polyurethane for long life and multiple cleaning cycles.
5-1/2" 360 Degree Air Filter — This intake utilizes 5-1/2" Pro DRY S performance air filters for maximum flow. This 3-layer progressive, non-oiled synthetic air filter requires no oils for cleaning for maximum convenience.
Dyno Tested Intake Tube — The intake tube is designed to maximize air velocity and is dyno tested and flowed using the latest engineering tools for maximum performance, mileage and throttle response.
Black Aluminum Top — To add a touch of style to your 4Runner or FJ Cruiser, the engineers at aFe Power have added a black anodized brushed aluminum top with aFe urocal.
Hassle-Free Installation — aFe has developed this intake to provide a hassle-free installation that utilizes all factory mounting locations.
Note:
This intake system is not CARB exempt at this time and is not legal for sale in California or use on vehicles registered with the California Department of Motor Vehicles.
Also Fits:
Toyota FJ Cruiser/4Runner 10-15 V6-4.0L
2010-2015 Toyota Land Crusier Prado (J150) V6-4.0L
aFe POWER 51-81932 Magnum FORCE Stage-2 Si Pro DRY S Cold Air Intake System Retail $425.00
aFe POWER 54-81932 Magnum FORCE Stage-2 Si Pro 5R Cold Air Intake System Retail $425.00
*Special deal, Please PM, Email, or Call 800-341-7757
