Old 11-30-2016, 02:57 PM #1
OffRoadWarehouse OffRoadWarehouse is offline
Official Vendor
OffRoadWarehouse is on a distinguished road
Official Vendor
OffRoadWarehouse & Bilstein 5100's 2010-2016 4Runners
Bilstein 5100's 0-2.5" lift & Improve your ride!!
***Will Fit 2010+***
Let's face it, We buy our 4Runners and hope that it will handle like a dream, Sadly, it doesn't.. It nose dives while braking, feels like it wants to roll over in mid turn, it bounces all over the road. Adding Bilsteins is an affordable option compared to "lift kits" it levels out your 4Runner giving you a better look without the aid of 2" spacer kits. Bilstein shocks dramatically improve the look of the 4runner and gives you back what you deserved! ~A BETTER RIDE!! Feel at ease that your truck doesn't nose dive while braking, feel confident taking that turn faster and safer. You can also add a bigger tire size for that lifted look. You don't have to spend LOTS of money to achieve this look.
Front Bilsteins #24-196499
Rear Bilstein 5100's #33-187174
Crafted specifically for lifted trucks, SUVs and Jeeps, your Bilstein 5100 Series Shocks & Struts deliver superior control, handling and comfort. Their super damping ability makes Bilstein adjustable shocks ideal for heavy hauling and off-roading in comfort.
Bilstein 5100 leveling shocks & struts boast a mono-tube design that instantaneously adjusts to the road surface for a smooth and quiet ride. The large-diameter shock body delivers fade-free performance, while the multi-layer zinc finish ensures your shocks last for the long haul.
Your Bilstein 5100ís are engineered for an array of specific vehicle and lift combinations so youíre sure to get dialed-in precision. Easy bolt-on installation and a Lifetime Limited Warranty make your Bilstein 5100 Series Shocks & Struts a must-have mod.
We Made it easier for you to shop
NO PromoCode Needed
$380.00/SHIPPED!!
Fits:
2010-2017 Toyota 4Runner
2010-2014 Toyota FJ Cruiser
www.OffRoadWarehouse.com
Toyota 4Runner Specialists
800.341.7757 x 158
Chat Directly with us Online
OffRoadWarehouse is offline   Reply With QuoteReply With Quote
Old 11-30-2016, 03:28 PM #2
JT_SHARK JT_SHARK is offline
Real Name: Jimmy
JT_SHARK is on a distinguished road
Real Name: Jimmy
Would that be the total price? Would this also be compatible with my 2WD?
JT_SHARK is offline   Reply With QuoteReply With Quote
Old 11-30-2016, 03:30 PM #3
Official Vendor
Official Vendor
$380.00/SHIPPED + CA tax & YES compatible with Both 4x2 & 4x4.
800.341.7757 x 158
Old 11-30-2016, 04:54 PM #4
Real Name: Jimmy
Real Name: Jimmy
Any coils required with this mod?
Old 11-30-2016, 04:56 PM #5
Official Vendor
Official Vendor
You re-use your factory Coils and top upper strut mount. There's no need to install after market springs with stiffer spring rate or taller. $ave your money!
These 5100's are one of the BEST BANG for your BUCK!!
800.341.7757 x 158
Old 11-30-2016, 08:33 PM #6
Official Vendor
Official Vendor
FYI, I have PLENTY of front available and 3 sets for REARS. Rears are on Nationwide Backorder.
800.341.7757 x 158
Old 11-30-2016, 08:43 PM #7
Real Name: Jimmy
Real Name: Jimmy
Have any set for a 3rd Gen? OffRoadWarehouse & Bilstein 5100's 2010-2016 4Runners
Old 11-30-2016, 08:52 PM #8
kcsaysngo's Avatar
kcsaysngo kcsaysngo is offline
Real Name: KC NGO
kcsaysngo is on a distinguished road
kcsaysngo's Avatar
Real Name: KC NGO
seems like a good deal; curious to see how it looks. any photos of rigs with this setup installed?
-INSTAGRAM: @kcsaysngo
kcsaysngo is offline   Reply With QuoteReply With Quote
Old 12-01-2016, 12:16 PM #9
Official Vendor
Official Vendor
Created a new page just for Bilstein 5100's 3rd Gen. 4Runners
800.341.7757 x 158
Old 12-01-2016, 12:28 PM #10
Official Vendor
Official Vendor
I don't have any pics but there are alot floating on the web or here on the forum with these installed. I don't have permission to post any users rides otherwise i would. Let me know if i can help! Thanks!! btw, Bilsteins is a GREAT alternative to spacers.
800.341.7757 x 158
Old 12-01-2016, 12:37 PM #11
pipo6007's Avatar
pipo6007 pipo6007 is offline
pipo6007 is on a distinguished road
pipo6007's Avatar
I have my original shocks and springs with 158K miles. The only thing I did was add the 2.5/1.5 Daystar spacer lift. Would I sit the same if I remove the Daystar and add the 5100's only? Or will I lose or gain height all around? Also if I choose to add a front or rear steel bumper would I need to swap out the shocks again? And what is the largest tire combo I can it without maxing out the shocks adjustable height? I plan on getting new rims and tires next year. Thanks!
pipo6007 is offline   Reply With QuoteReply With Quote
Old 12-01-2016, 01:10 PM #12
Official Vendor
Official Vendor
The 5100's are good for 0-2.5" for the front. You should be able to install on the top clip for 2.5". What you will gain is BETTER ride control as the stock shocks are weak from the factory. With that many miles and bigger tires it puts more strain on the shocks. The 5100's are valved and up to the challenge for the taller stance and tires. The Bilstein 5100's are also designed to give you the stance (leveled) look. However, when increase weight like a steel bumper may require you to jump up to 2.5" Coilovers and if adding a winch you can opt to a stiffer spring rate. We offer other brand of Coilovers.
Take a look at this... it's a GOOD write up!!
Simple Facts:
Why Bilstein 5100 Series Leveling Shocks are far superior to coilover spacer kits
Bilstein Rear shocks should be okay with the Spacer kit..
If you DO plan on adding a Bumper / Winch combo you CAN upgrade to a 2.5" Coilover with Extended Travel and Upper Control Arm. Contact me for options!
800.341.7757 x 158
Old 12-01-2016, 01:16 PM #13
Official Vendor
Official Vendor
800.341.7757 x 158
Old 12-01-2016, 01:38 PM #14
pipo6007's Avatar
pipo6007's Avatar
Simple Facts:
If I were to load the front shock on the top clip would that stiffen the ride more than on a lower clip? Are they made to run on the highest level all the time? If I add rear FJ coils along with the 5100's does that improve anything such ride and lift height? I'm trying to be at 3" lift total if possible.
Old 12-01-2016, 02:34 PM #15
Official Vendor
Official Vendor
These shocks are LONGER than OEM to accommodate a 2.5" lift. Reason WHY bilstein stops at 2.5" to ensure that your drive line, upper and lower ball joints are not affected and do not prematurely wear out quicker than they should. Internal valving is made to match the OEM spring rate and length. Some guys have tested out other springs like aftermarket with stiffer spring rate or taller in length but you have to remember that you only have useable space. Taller Coils set at the 0" setting will make up the difference than the OEM Springs @ 2.5" (top setting). Taller springs MAY have the same spring rate not necessarily called an upgrade. Some install a spacer ontop of the Bilsteins but then you'll run into maxing out your ball joint in the UCA and possibly hitting the coil bucket with the upper arm. Before you spend more money on buying other coils rather than use OEM. Money is better spent on getting a Coilover like ICON, KING or FOX because they are designed for taller than 2.5" with extended travel & an aftermarket upper control arm.
Bilstein 5100's for the rear are good for 0-1.5", But def. Over 2" you will need another shock.
800.341.7757 x 158
HTML code is Off
FS: 2010+ 4runner Bilstein 5100's & Cornfed Rear Spacer. c4inam2n For Sale: Suspension/Wheels/Tires 2 10-10-2016 11:54 AM
Shopping for Bilstein 5100 for 2016 SR5 4x4 spawn 5th gen T4Rs 3 04-26-2016 09:25 PM
WTB Bilstein 5100 for 2016 4runner 4x4 SR5 spawn Want to Buy/Trade 0 04-26-2016 04:03 PM
Bilstein 5100's Specific to 2010+ 4Runners ATL4R 5th gen T4Rs 29 11-02-2014 11:33 AM
2010 4 runner Bilstein 5100 Level Ponyfvr 5th gen T4Rs 5 06-16-2014 08:24 PM
Copyright © 2019
