Old 12-01-2016, 02:47 PM #16
pipo6007's Avatar
pipo6007 pipo6007 is offline
pipo6007 is on a distinguished road
pipo6007's Avatar
Originally Posted by OffRoadWarehouse View Post
These shocks are LONGER than OEM to accommodate a 2.5" lift. Reason WHY bilstein stops at 2.5" to ensure that your drive line, upper and lower ball joints are not affected and do not prematurely wear out quicker than they should. Internal valving is made to match the OEM spring rate and length. Some guys have tested out other springs like aftermarket with stiffer spring rate or taller in length but you have to remember that you only have useable space. Taller Coils set at the 0" setting will make up the difference than the OEM Springs @ 2.5" (top setting). Taller springs MAY have the same spring rate not necessarily called an upgrade. Some install a spacer ontop of the Bilsteins but then you'll run into maxing out your ball joint in the UCA and possibly hitting the coil bucket with the upper arm. Before you spend more money on buying other coils rather than use OEM. Money is better spent on getting a Coilover like ICON, KING or FOX because they are designed for taller than 2.5" with extended travel & an aftermarket upper control arm.
Bilstein 5100's for the rear are good for 0-1.5", But def. Over 2" you will need another shock.
Thank you for the detailed explanation. From what I understand I would basically be at the same height I am now with the DS spacer kit but the main difference would be the ride and handling improvement. Do the 5100's hold weight any better than stock? Towing for example.
pipo6007 is offline   Reply With QuoteReply With Quote
Old 12-01-2016, 02:50 PM #17
OffRoadWarehouse OffRoadWarehouse is offline
Official Vendor
OffRoadWarehouse is on a distinguished road
Official Vendor
I would install Bilsteins on ANY truck i own and YES they will make a BIG difference over stock. We also sell Airlift bags (in coil) to help with weight.
www.OffRoadWarehouse.com
Toyota 4Runner Specialists
800.341.7757 x 158
Chat Directly with us Online
OffRoadWarehouse is offline   Reply With QuoteReply With Quote
Old 12-09-2016, 12:27 PM #18
Official Vendor
Official Vendor
^^^^^^^^^^^^^^^^^SEE LINKS IN THE #1 POST FOR PURCHASE^^^^^^^^^^^^^^^^^^^^^^^^
RE-STOCKED AND READY TO SHIP!!!!!! PLACE YOUR ORDERS NOW!!!
Good READ!!! Take a LOOK!!!
Why Bilstein 5100 Series Leveling Shocks are far superior to coilover spacer kits
800.341.7757 x 158
Old 12-14-2016, 04:29 PM #19
Official Vendor
Official Vendor
Thank you for your orders!!! I've updated ALL tracking numbers.
PLENTY of FRONTS & only 3 sets of REARS in stock!!
Please let us know if we can help!!! Thanks for your support!!
800.341.7757 x 158
Old 01-27-2017, 03:54 PM #20
Official Vendor
Official Vendor
Bilstein 5100's BACK IN STOCK!! Please use the links above or contact via PM or Email.
800.341.7757 x 158
Old 02-05-2017, 01:16 PM #21
rdavis rdavis is offline
rdavis is on a distinguished road
I am new to the 4runner community. I am trying to confirm on exactly what I need and what actually needs to be done to level the ride on my 17 TRD off road premium. Will the 5100's alone do the trick? Do I need new struts? How difficult is the installation? I wouldn't do it myself but would like to understand what needs to be done. Thank you for any and all info.
rdavis is offline   Reply With QuoteReply With Quote
Old 02-06-2017, 12:32 PM #22
Official Vendor
Official Vendor
These Bilsteins if set on the top setting you should be at 2.5" You reuse your factory Springs and top mount. Rear shocks will be replaced pretty easily. Ride quality is Greatly improved for both ON/Off road use. Great value for the price!!
800.341.7757 x 158
Old 04-27-2017, 06:52 PM #23
Official Vendor
Official Vendor
PLENTY of FRONTS & REARS are in stock!!
800.341.7757 x 158
Old 08-23-2018, 03:53 PM #24
tristanle tristanle is offline
tristanle is on a distinguished road
I am looking into this setup for my 2012 Limited. I still have 2 questions: 1) From what I research, 5100 works for Xreas, correct? 2) Some people use 5100 front and rear and add a 1.5" spacer in the back. Is it necessarily? If so why? Thanks!
tristanle is offline   Reply With QuoteReply With Quote
Old 08-23-2018, 04:01 PM #25
Official Vendor
Official Vendor
X-Reas is a good option while stock. Upgrade to a set of Bilstein 5100's where you can lift/level your front end and eliminate nose dive while into turns/braking. If you install on 2.5" front some 4Runners need the 1.5" to be leveled. If you plan on using the 1.75" setting it won't need the rear. We have plenty in stock please let me know. Thank you!!!
800.341.7757 x 158
Old 08-23-2018, 04:54 PM #26
Hi Mike - so how much do you sell for a set of 5100 all around? thanks.
Old 08-23-2018, 06:13 PM #27
Official Vendor
Official Vendor
https://offroadwarehouse.com/i-23039...runner-fj.html
use the welcome 5% promocode on our site for more savings
800.341.7757 x 158
Old 10-27-2019, 08:38 PM #28
jake1398 jake1398 is offline
jake1398 is on a distinguished road
So just so i'm sure, and sorry for being repetitive, but this lift would not require a diff drop correct?
jake1398 is offline   Reply With QuoteReply With Quote
HTML code is Off
FS: 2010+ 4runner Bilstein 5100's & Cornfed Rear Spacer. c4inam2n For Sale: Suspension/Wheels/Tires 2 10-10-2016 11:54 AM
Shopping for Bilstein 5100 for 2016 SR5 4x4 spawn 5th gen T4Rs 3 04-26-2016 09:25 PM
WTB Bilstein 5100 for 2016 4runner 4x4 SR5 spawn Want to Buy/Trade 0 04-26-2016 04:03 PM
Bilstein 5100's Specific to 2010+ 4Runners ATL4R 5th gen T4Rs 29 11-02-2014 11:33 AM
2010 4 runner Bilstein 5100 Level Ponyfvr 5th gen T4Rs 5 06-16-2014 08:24 PM
Copyright © 2019
