Old 02-12-2014, 12:07 AM #31
volcom440 volcom440 is offline
Real Name: Nick
volcom440 is on a distinguished road
Real Name: Nick
The instillation process on this would pretty much be the same for my '06 V6 correct?
volcom440 is offline   Reply With QuoteReply With Quote
Old 02-12-2014, 09:15 AM #32
aha2988's Avatar
aha2988 aha2988 is offline
Real Name: Austin
aha2988 will become famous soon enough aha2988 will become famous soon enough
aha2988's Avatar
Real Name: Austin
I don't see any reason why it would be much different. Its been a little while since i've looked under the hood of a V6, but im pretty confident that the air filter inlet is in the same location as the V8.
-Austin
A-Ha's Build
aha2988 is offline   Reply With QuoteReply With Quote
Old 02-12-2014, 02:22 PM #33
Real Name: Nick
Real Name: Nick
Right above the right tire. I play in a lot of mud / water mix so this seems like a pretty solid mod for me.
Old 02-12-2014, 05:25 PM #34
Real Name: Nick
Real Name: Nick
Well my Home Depot doesn't carry the abs plastic but lowes does.
Old 02-14-2014, 09:20 AM #35
aha2988's Avatar
Real Name: Austin
aha2988's Avatar
Real Name: Austin
yeah and you have to purchase an entire piece which kind of sucks since you only need 2ft lol
-Austin
A-Ha's Build
Old 02-14-2014, 05:47 PM #36
Real Name: Nick
Real Name: Nick
Yea but it was only like $5 so I'm not to worried about it.
Old 02-16-2014, 02:22 AM #37
emelianenkov's Avatar
emelianenkov emelianenkov is offline
Real Name: Alex
emelianenkov is on a distinguished road
Real Name: Alex
As I've tried to say I would do so many times finally here is a video you can watch and listen in on the sound the internal snorkel produces.
internal snorkel sound - YouTube
It shows different RPM ranges, speeds, variations of getting on an off the throttle as well as just cruising at normal speeds.
took the video on the way home from work hope it answers any questions you may have.
yeah the inside of my truck is as muddy as the outside so what...
Sounds good when you get it up close to blue line
-07 FJ Cruiser 6MT. 185k. Camburg 3.5" Long Travel.
-17 Subaru WRX STI. 305AWHP/311AWTQ. Warranty delete.
-13 Subaru Crosstrek CVT. / 05 Subaru Outback limited 5MT. Flip project.
-99 Ford F-250 Super Duty Lariat 4x4. 7.3 PowerStroke. SCLB.
-93 Toyota Pickup Crawler 5MT Solid axle swap. 37's. / 82 Yota Pickup.
emelianenkov is offline   Reply With QuoteReply With Quote
Old 03-02-2014, 12:48 PM #38
Real Name: Nick
Real Name: Nick
Did this mod this weekend and i ended up breaking some fasteners on the fender flare. If anyone does the same as me here's a site to buy the replacement fasteners!
Toyota Rocker Moulding Clip With Sealer 75495-35010
Old 03-25-2016, 10:21 PM #39
VidRunner's Avatar
VidRunner VidRunner is offline
Real Name: Vid
VidRunner is on a distinguished road
VidRunner's Avatar
Real Name: Vid
Smile Just did this mod
Just did this one today. Thank you for the inspiration!
VidRunner is offline   Reply With QuoteReply With Quote
Old 03-25-2016, 10:46 PM #40
VidRunner's Avatar
Real Name: Vid
VidRunner's Avatar
Real Name: Vid
Arrow
Old 08-17-2016, 09:15 PM #41
zidaro's Avatar
zidaro zidaro is offline
zidaro is on a distinguished road
zidaro's Avatar
bump to the top for a badass mod!!
Couple Yotas
Iluv4xToys!
zidaro is offline   Reply With QuoteReply With Quote
Old 02-16-2019, 07:35 PM #42
RazzRoach's Avatar
RazzRoach RazzRoach is offline
RazzRoach is on a distinguished road
RazzRoach's Avatar
No cabin pressure issues windows up, or down, a/c on or off. (i keep the a/c on the auto switch it regularly cuts on and off as it should) hasn't been running any more or less than usuall we're in the high 80's temp wise so far.
no smells, gasses, co2 levels, nothing negative to report.
when throttle is just barely cracked theres zero noise added inside the cabin(this is 90% of the time on the road just barely pushed to maintain speed other than hill climbs or towing)
when throttle is about a 3rd opened you can hear a hiss/small hollow suction noise
when throttle is 2/3rds opened you can hear the motor destinctly running up its power band similar to the sound of a performance exhaust at same throttle position
when throttle is 3/3rds opened (fully opened) yes the engine sounds like its running inside the truck with a performance exhaust (so still muffled) I've injoyed the tune of it from my V8, unsure of how a V6 would sound.
and as stated before the radio tunes out all noises from the first three throttle positions mentioned. The engine sound still slightly overpowers the radio at full throttle but IMHO it sounds great! and have zero mud/water in airbox after this... sorry would've takin picks of the playground after rushing out to help my buddy out (i.e. the second pic) we played around some more after i got him out. and i never thought once about the camra until i got home lol.
clean
RazzRoach is offline   Reply With QuoteReply With Quote
Old 03-24-2019, 06:36 PM #43
RazzRoach's Avatar
RazzRoach's Avatar
how hard is it to pull of the front fender? I need to fix my safari snorkel connection and would be much easier with fender removed instead of going up through the wheel well
Old 05-21-2019, 01:23 PM #44
eternalsoil eternalsoil is offline
eternalsoil is on a distinguished road
Has anyone used PVC for this instead of ABS? I can get a smaller section of PVC DWV and it's cheaper. Would I still be able to heat up the PVC DWV to shape it?
Sent from my SM-N920T using Tapatalk
eternalsoil is offline   Reply With QuoteReply With Quote
Old 06-22-2019, 12:03 PM #45
texasrimfirenut texasrimfirenut is offline
texasrimfirenut is on a distinguished road
Great tutorial, thanks for sharing.
texasrimfirenut is offline   Reply With QuoteReply With Quote
Internal snorkel waterproofing question DewRunner 3rd gen T4Rs 17 04-23-2012 09:20 PM
Air Cleaner & Internal Silencer/Resonator Bretski1 For Sale: T4R Items 1 04-19-2012 01:03 AM
Internal Trim Removal phillyd2 5th gen T4Rs 15 10-01-2011 06:55 PM
internal bike rack silversx 5th gen T4Rs 16 06-23-2011 11:21 AM
Is there an Internal Filter in the car? ssabripo 4th Gen T4Rs 2 09-21-2004 11:20 AM
