Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 02-09-2011, 10:26 PM #31
RpzInc's Avatar
RpzInc RpzInc is offline
RpzInc is on a distinguished road
RpzInc's Avatar
I learned this in a 2wd truck but it wokrs with unlocked 4wd trucks as well. if you come to a point where a rear spinning tire is keeping you stuck, try using the e-brake 1 click at a time with steady increase until the other wheel gets power. it doea wear your rear pads fast but in an emergency its a life saver.
Working hard pays off in the long run, but procrastination pays off now!
RpzInc is offline   Reply With QuoteReply With Quote
Old 12-11-2013, 07:46 PM #32
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
ive done that before. it actually allowed me to make it up a climb I never should have been able to. it was crazy.
I thought of something recently, and more along an extreme situation.
to use logs/limbs in place of straps or chains.
im thinking more if you're trying to use a high lift or come-a-long to get unstuck, but don't have enough cable to reach a good tree.
you could find a length of tree or branch, and using your belt, shoe laces, rope or whatever else you may have to secure it. it might be JUST enough to get you out the that predicament.
I once used several lengths of chain, and a couple small trees as levers to pull my truck out. not in the way I was describing above, as I had no mechanical pulling devices, nor any other vehicles. it was some full on MacGyver shit...
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 12-13-2013, 02:42 PM #33
CAN-03runner's Avatar
CAN-03runner CAN-03runner is offline
CAN-03runner is on a distinguished road
Are you saying that you use a small tree or branches as a catapult....? In that you bend them down, tie them up to the truck and let go of the branches and then the pull back force of the branches might give you just enough of a tug to help you along. Interesting.
2003 4Runner Sport 4.7 V8 Silver/Grey - Fr/Rr ARB Locker - OME 885/895 - LR UCA - BFG KM2 255/80/17- RCI Skids - Demello Sliders - Bud Hidden Winch- Runva Winch - Synthetic oils- Trail Stripes - Two Baby Seats...
1984/86 4runner In Progress....... V6 swap - High Steer - 33" MTZ - 4.88 Gears - welded rear - ARB front - axle gaussets - Diff covers - Longfields - 4.7 crawler - Titan Winch http://www.toyota-4runner.org/classi...ner-build.html
CAN-03runner is offline   Reply With QuoteReply With Quote
Old 12-13-2013, 03:42 PM #34
nevada's Avatar
nevada's Avatar
not exactly. i'll see if I can come up with some in mspaint that shows what I did.
it may be a couple days..
Old 12-23-2013, 08:31 PM #35
nevada's Avatar
nevada's Avatar
this is crude, and the distances arent to scale, but I think you get the idea.
Old 12-23-2013, 08:36 PM #36
nevada's Avatar
nevada's Avatar
I thought of something else ive encountered on the trail.
when you get stuck attempting to pull out another vehicle. now both are stuck, and the strap is tight.
hopefully you have a second strap..
connect it to along side the tight strap, and try to do it in such a way that you get as much slack out.
then using a shovel, or high light handle, slide it between the straps start twisting the straps together. as they twist, they will get shorter, ONE of the rigs will move.
use caution, as the shovel will have a lot of tension against it, if you let go, it will spin....violently.
it can be a bit dangerous, but may be just enough to get you unstuck.
at least enough so you can reposition a vehicle.
Old 12-24-2013, 10:48 AM #37
I think I get it now. And it quickly reminded me of this recovery video.
Russian fishermen caught the car on Lake Baikal in 2013 - YouTube
Old 12-24-2013, 10:54 AM #38
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
That could work - you'd want the short side of each log closer to the truck for maximum leverage.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 12-24-2013, 11:05 AM #39
nevada's Avatar
nevada's Avatar
yes, it DID work.
agreed, they were a bit closer, like I said, it wasn't to scale.
but, its not like we have a choice where the trees grow tho
things worked out just right for it to work that time.
Old 12-24-2013, 11:19 AM #40
Real Name: Kevin
Real Name: Kevin
yes, it DID work.
Oh, I didn't get that part. Sorry!
Old 12-27-2013, 09:26 PM #41
wallytoo's Avatar
wallytoo wallytoo is offline
wallytoo has a spectacular aura about wallytoo has a spectacular aura about
wallytoo's Avatar
Originally Posted by Thai View Post
Mud usually tends to hide obstacles such as tree roots and sticks just waiting to slash your sidewalls, so its best to avoid reducing tire pressures if you can avoid it..
i fully realize this was posted back 11 years ago, but nobody took exception to it, and it is wrong.
sidewalls are more susceptible to being punctured at higher pressure, not lower pressure. where sharp objects are likely to be encountered, run the lowest pressure that you are comfortable running that will maintain the bead. that will vary by tire type, make, and wheel combination (beadlocks/no beadlocks, etc).
this applies to rock surfaces, too, not just mud.
puncture resistance, and sidewall strength are one of the reasons i prefer running bias-ply tires where i wheel (new england). i've got over 20 years experience wheeling, and 15 of that running bias swampers (ltb and "plain"). another advantage is being able to run very low pressures w/out beadlocks. i typically run 2 to 4 psi when wheeling my cj, vs the 7 to 10 psi when running radials on the cj. those numbers would/will be slightly higher for the 4runner, since it weighs more. i think i could get away with 4 to 6 psi for bias, and 8 to 12 with radials.
member, new hampshire timberland owners association (NHTOA)
1987 4runner sr5, 22re, 5-speed
1988 4runner sr5, 3.0, auto (parts rig)
1987 4runner, sr5, 22re, 5-speed (#2)
wallytoo is offline   Reply With QuoteReply With Quote
Old 09-23-2014, 02:34 AM #42
wake_rider's Avatar
wake_rider wake_rider is offline
Real Name: Michael
wake_rider is on a distinguished road
wake_rider's Avatar
Real Name: Michael
No joke, I once lifted a 2wd F150 that was buried to it's rear axel in sugar sand on a riverbed here in Oklahoma that could not be mitigated with the assistance of a tug strap and my trusty 4Runner. However, we were able to resolve it with a simple lever made out of a long log and a stump.
We rolled the stump over just behind the truck, and it was so large that we had to use a few walking-stick sized branches to wedge it towards the truck on about a 150' run. Then, we found a dried out log that was about 20' long and at its thickest point near its base, probably 2' in diameter, tapering up to about 10" in diameter at its broken off top. Luckily, it was a completely dried out driftwood log that was remarkably round and easy to roll with 3 guys.
So we rolled it about 50 yards or so to the back of the truck, placed the smallest diameter end up underneath the rear hidden hitch (which was touching sand, he buried it so deep before I got there), and then lifted the heavier, wider end up as high as we could and put the large stump underneath it as close to the truck as possible (that acted as the fulcrum, and was about 4' away from the tailgate).
Once under, just the weight of the trunk with the mechanical advantage was enough to start lifting the rear end a bit. Then, I walked out to the end of the lever-log and started to lift the truck pretty well with just my weight (around 180 lbs), then my 200 lbs friend jumped up there and we were able to completely pick up the back end of the truck, rear axle and wheels completely suspended. However, just getting it in the air did nothing.
So while we sat on the end of the log, our third friend started back-filling in the holes with sand, sticks, tall river-weeds, a few cardboard beer boxes, and even a large scrap piece of carpet that someone dumped out there. We set it back down on all the junk and it compressed it pretty good and still could not get out of its own holes, so we moved the fulcrum (the large stump) to about 1.5' away from the tailgate and repeated the process. This time, GREAT SUCCESS! lol. It freaking worked. Unbelievable.
My buddy then told me that I was the smartest man alive. I took the compliment, but honestly, had I not just seen the first massive stump just sitting there, the thought would have never crossed my mind. It just so happened to be in the perfect spot to spark an idea.
My rendition of the event:
2000 Desert Dune Limited 4x4
wake_rider is offline   Reply With QuoteReply With Quote
Old 12-05-2014, 12:21 AM #43
BettysNephew BettysNephew is offline
Real Name: Dave
BettysNephew is on a distinguished road
Real Name: Dave
Another good tip for driving on snow and ice is when you want to stop, shift into neutral and gently use the brakes. You will have better braking balance without the power train pushing you forward. On level ground most hehicles in drive will creep forward. This makes it more difficult to brake effectively.
2017 Blizzard Pearl Limited
Redwood guts
Gone but not forgotten:
2015 Attitude Black 4Runner Trail
BettysNephew is offline   Reply With QuoteReply With Quote
Old 04-06-2015, 03:11 PM #44
suzanne suzanne is offline
suzanne is on a distinguished road
wheels and tires
forgive me, I could find a new post to type some comments about my 4runner limited - wheels and tires
I purchased 2015 Toyota 4runner limited6 months ago. I asked sale rep if this suv is able to drive - off road. She said Yes. 6 months later - I learned that my limited suv is not fitting for off road bec of tires - 245/60/20 and luxury. I wish I could buy 4runner trail, but I was wondering if I could buy other wheels and tires for off road? Please share your experience with me. Thanks
suzanne is offline   Reply With QuoteReply With Quote
Old 07-22-2015, 09:34 PM #45
mikeromeo1968 mikeromeo1968 is offline
mikeromeo1968 is on a distinguished road
recovery points
i searched this thread looking for advice on using the recovery points on the 15 4 runner. i couldnt find anything specific regarding them. anyone like to direct me or provide some advice on using them for recovery? are they just tie downs? thanks in advance
mikeromeo1968 is offline   Reply With QuoteReply With Quote
Some 4WD tips for novice wheelers. Jay Off-Roading 12 12-01-2019 09:33 PM
manual vs. auto for off roading? brian2sun 3rd gen T4Rs 69 03-20-2014 10:29 PM
tips for waxing roof LBeard87 Maintenance/Detailing 8 05-05-2010 05:49 PM
Looking for Tips on Driving the Dempster Highway (YK, NWT) Dycker_98SR5 4th Gen T4Rs 7 03-28-2008 04:47 PM
First Time in Snow...Any Tips?? MikeinCincy 4th Gen T4Rs 2 12-14-2007 07:30 AM
