Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 09-04-2015, 11:16 PM #46
laufer's Avatar
laufer laufer is offline
laufer is on a distinguished road
laufer's Avatar
wheels and tires
Originally Posted by suzanne View Post
forgive me, I could find a new post to type some comments about my 4runner limited - wheels and tires
I purchased 2015 Toyota 4runner limited6 months ago. I asked sale rep if this suv is able to drive - off road. She said Yes. 6 months later - I learned that my limited suv is not fitting for off road bec of tires - 245/60/20 and luxury. I wish I could buy 4runner trail, but I was wondering if I could buy other wheels and tires for off road? Please share your experience with me. Thanks
Hi Suzanne, I just noticed your post from April, so you've probably resolved your problem by now. In case you haven't:
The vehicle will become very capable as soon as you switch to 17" wheels and tires with a taller sidewall. This video, featuring the same model as yours, is a great example of this mod:
Epic Drives: Alaska's Dalton Highway in a 2014 Toyota 4Runner Limited
You can use this tire fitment guide to pick a tire size that doesn't require additional modifications and where the spare still fits underneath the vehicle. I would go with 265/70/17 (the stock 17" size) or 255/75/17 for the taller sidewall.
http://www.toyota-4runner.org/5th-ge...ent-guide.html
That setup should get you through most trails rated 3-4 out of 10 on TrailDamage.com, possibly higher. Whether you need more aggressive mods will depend on your priorities: scenic backcountry driving versus heavy off-roading.
laufer is offline   Reply With QuoteReply With Quote
Old 10-14-2015, 06:14 PM #47
SonomaT4R's Avatar
SonomaT4R SonomaT4R is offline
SonomaT4R is on a distinguished road
SonomaT4R's Avatar
Originally Posted by wake_rider View Post
No joke, I once lifted a 2wd F150 that was buried to it's rear axel in sugar sand on a riverbed here in Oklahoma that could not be mitigated with the assistance of a tug strap and my trusty 4Runner. However, we were able to resolve it with a simple lever made out of a long log and a stump.
We rolled the stump over just behind the truck, and it was so large that we had to use a few walking-stick sized branches to wedge it towards the truck on about a 150' run. Then, we found a dried out log that was about 20' long and at its thickest point near its base, probably 2' in diameter, tapering up to about 10" in diameter at its broken off top. Luckily, it was a completely dried out driftwood log that was remarkably round and easy to roll with 3 guys.
So we rolled it about 50 yards or so to the back of the truck, placed the smallest diameter end up underneath the rear hidden hitch (which was touching sand, he buried it so deep before I got there), and then lifted the heavier, wider end up as high as we could and put the large stump underneath it as close to the truck as possible (that acted as the fulcrum, and was about 4' away from the tailgate).
Once under, just the weight of the trunk with the mechanical advantage was enough to start lifting the rear end a bit. Then, I walked out to the end of the lever-log and started to lift the truck pretty well with just my weight (around 180 lbs), then my 200 lbs friend jumped up there and we were able to completely pick up the back end of the truck, rear axle and wheels completely suspended. However, just getting it in the air did nothing.
So while we sat on the end of the log, our third friend started back-filling in the holes with sand, sticks, tall river-weeds, a few cardboard beer boxes, and even a large scrap piece of carpet that someone dumped out there. We set it back down on all the junk and it compressed it pretty good and still could not get out of its own holes, so we moved the fulcrum (the large stump) to about 1.5' away from the tailgate and repeated the process. This time, GREAT SUCCESS! lol. It freaking worked. Unbelievable.
My buddy then told me that I was the smartest man alive. I took the compliment, but honestly, had I not just seen the first massive stump just sitting there, the thought would have never crossed my mind. It just so happened to be in the perfect spot to spark an idea.
My rendition of the event:
That is freakin classic. Nice work. Better drawing!
2003 SR5 V8 Dorado Gold Pearl, Tacoma TRD Socks and Springs (Stock Rear Springs), Toytec Spacers: Front 1/2", Rear 1.5", 265/70/17 Nitto Terra Grappler G2.
SonomaT4R is offline   Reply With QuoteReply With Quote
Old 10-17-2015, 11:16 AM #48
4runner4ever1 4runner4ever1 is offline
4runner4ever1 is on a distinguished road
Need help
I drove my 2014 4runner off road, and while doing so, I accidently drove a large rock that got stuck behind my left lower control arm. I put the car in reverse and forced it over the rock. Now my steering column appears to be shifted to the left ( not sure if it was like that before), and on inspecting the bottom, the LCA is scraped, and the brackets where the LCA inserts in the frame is bent. The left front wheel is now 5mm ahead of the right one. Alignment is within specs. what could have happened to the steering column and to the left wheel?
4runner4ever1 is offline   Reply With QuoteReply With Quote
Old 12-20-2015, 02:57 PM #49
ColtonAdkison's Avatar
ColtonAdkison ColtonAdkison is offline
ColtonAdkison is on a distinguished road
Red face
Thanks for the info!
ColtonAdkison is offline   Reply With QuoteReply With Quote
Old 03-08-2016, 04:11 PM #50
PTYvrashko's Avatar
PTYvrashko PTYvrashko is offline
Real Name: Daniel
PTYvrashko is on a distinguished road
PTYvrashko's Avatar
Real Name: Daniel
I got a couple of questions:
Does the 4runner TRD 2015 needs to be lifted in the front to be completely level ?
PTYvrashko is offline   Reply With QuoteReply With Quote
Old 03-08-2016, 04:29 PM #51
PTYvrashko's Avatar
Real Name: Daniel
PTYvrashko's Avatar
Real Name: Daniel
And if its need to be lifted. How many inches?
Old 05-04-2016, 08:33 PM #52
propain's Avatar
propain propain is offline
propain is on a distinguished road
propain's Avatar
Arrow
Always look under the truck after off-roading. Especially if you don't have skid plates yet.
Off-roading Tips-img_2016-04-30_08-53-24-85-jpg
2016 TRD Pro (MGM) / OME BP51's / Heavy Duty OME Springs / JBA UCA / ARB Safari Snorkel / SSO Slimline Hybrid Front Bumper w/Rigid Industries LED Light Bar / Smittybuilt Winch / ARB Fridge / Firestone M/T2 285-70-17 / C4 Fab Rock Sliders / Rago Ditch Brackets w/Baja Design Ditch Lights / RCI Skidplates (All) / aFe power MACH Force-Xp 2-1/2" 304 Stainless Steel Cat-Back Exhaust / Sprint Booster. flickr Noisia Radio
propain is offline   Reply With QuoteReply With Quote
Old 05-04-2016, 09:13 PM #53
Porqupine82's Avatar
Porqupine82 Porqupine82 is offline
Porqupine82 will become famous soon enough
Took a wealthy friends brand new land Rover into a creek when I was 16. This creek was running through a highly populated apartment complex at the time. Somebody called the police and the cops came. Thankfully he came in an explorer, and pulled us out.
Instagram: overland_tennessee
Website: www.redclayrally.com
Porqupine82 is offline   Reply With QuoteReply With Quote
Old 07-31-2016, 04:36 PM #54
Toffees's Avatar
Toffees Toffees is offline
Real Name: Micah
Toffees will become famous soon enough Toffees will become famous soon enough
Toffees's Avatar
Real Name: Micah
Reading through all the tips and comments, would be glad if anyone can add to or revise what this noob understands:
1) practice driving off road in a safe environment, with help, before trying anything crazy/fun
2) carry first aid, food and water, communication devices
3) bring a tow strap/set
4) a working hi-lift jack
5) what about a portable warn winch set?*
6) any need for a portable compressor for light driving?
Anything else in your basic noob locker? I'm in an unmodified 16 LE so I don't expect to use this stuff, but who does at first?
-T
*1,000 lb limit on this, that's not likely to help anything
Toffees is offline   Reply With QuoteReply With Quote
Old 07-31-2016, 09:31 PM #55
theMayor's Avatar
theMayor theMayor is offline
theMayor is on a distinguished road
theMayor's Avatar
-T
I'm a strong believer that a hi-lift jack is unnecessary for 99% of the off-roading population. I have several friends with rock crawlers that have never used theirs. A tow strap and/or traction mats are more than enough for most situations. But I could see how they'd be necessary for changing a flat on the trail, I guess...
I would add a collapsible shovel to your list. Get one with a serrated edge. You can cut tree limbs and make your own traction mats with branches (for mud or snow)
theMayor is offline   Reply With QuoteReply With Quote
Old 08-01-2016, 11:31 AM #56
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
until you actually need one. then, much like a winch, or a parachute, you will wish you had it. cheap insurance as far as im concerned.
this was from one of my last trips this winter.
we were able to reseat the bead, and air the tire up. after about 30 minutes, we were back on our way. it would have been VERY long night without that jack...
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 08-01-2016, 01:54 PM #57
4by4th's Avatar
4by4th 4by4th is offline
4by4th is on a distinguished road
4by4th's Avatar
-T
Is it even possible to lift a 2016 with a hi-lift jack? Where do you attach it? I was going to get one for my 2004 but cancelled it when trying to figure out where it could go to lift the 4R.
My 4th 4x4: 2004 V6 4Runner 4x4 (dealer replaced engine at 70,000 miles 2006 - http://www.toyota-4runner.org/showth...ight=nightmare), Mich. Cross Terrains, Nitto T/G, now BFG AT KO's 265/70/17, Leather, Husky mats, Escort, iPhone (phone, GPS, iPod), USA Spec Bluetooth Interface, Fumoto Valve
Current daily driver: 2008 Honda Accord EX-L w/Navi
4by4th is offline   Reply With QuoteReply With Quote
Old 08-01-2016, 02:50 PM #58
Toffees's Avatar
Real Name: Micah
Toffees's Avatar
Real Name: Micah
I'm guessing it fits any appropriate frame/lift point, just like they stowable jack in the spare tire changing kit. Not that I've used either yet.
Old 08-01-2016, 03:38 PM #59
4by4th's Avatar
4by4th's Avatar
The stock stowable jack goes under the 4R and lifts the frame. A Highlift jack lifts a steel bumper or sliders, neither item stock on a 4th or 5th Gen 4R.
Old 08-03-2016, 09:59 AM #60
Toffees's Avatar
Real Name: Micah
Toffees's Avatar
Real Name: Micah
OEX recommends using the HLJ with a wheel lift attachment. I'm guessing someone here has used a similar setup.
http://www.overlandexperts.com/docs/..._gear_list.pdf
Some 4WD tips for novice wheelers. Jay Off-Roading 12 12-01-2019 09:33 PM
manual vs. auto for off roading? brian2sun 3rd gen T4Rs 69 03-20-2014 10:29 PM
tips for waxing roof LBeard87 Maintenance/Detailing 8 05-05-2010 05:49 PM
Looking for Tips on Driving the Dempster Highway (YK, NWT) Dycker_98SR5 4th Gen T4Rs 7 03-28-2008 04:47 PM
First Time in Snow...Any Tips?? MikeinCincy 4th Gen T4Rs 2 12-14-2007 07:30 AM
