Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 11-15-2002, 10:00 AM #1
Thai's Avatar
Thai Thai is offline
Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold
Thai's Avatar
Off-roading Tips
Common 4WDriving Techniques
The following techniques are common to all types of terrain. Techniques for particular types of terrain are mentioned under the different terrain headings.
Hand Position
When driving off road, it is important not to place your thumbs on the inside of the steering wheel. When driving over any large ruts or potholes, the wheel could suddenly turn. This may result in the thumb being bruised or even dislocated if it is left inside the rim. Remembering to leave your thumbs on the outside of the steering wheel is a very easy skill to acquire and should become second nature to you. With power steering fitted to most 4Wdrives these days, this technique is not as critical as the power steering unit dampens out sudden steering wheel movements as well as steering stablizers. Owners of non-power steering vehicles will have undoubtedly experienced at some time the force at which the steering wheel turns when hitting an obstruction.
Diff Position
It is important to know the position of your front and rear differentials as they are usually the lowest ground clearance point of your vehicle. Similarly, any other low ground clearance points should be noted e.g. exhaust, spare tyre etc. When a large rock or other obstacle is on a track that you must drive over, you should ensure you avoid driving directly over it with the lowest ground clearance point of your vehicle.
Braking
When using the vehicle
My 2019 Land Cruiser
My 2023 Ford F150 Platinum FX4 Powerboost with 7.2 kW ProPower Onboard
2023 Lexus GX
2024 Subaru Impreza RS
Lets Go Brandon!
Thai is offline   Reply With QuoteReply With Quote
Old 11-15-2002, 10:00 AM #2
Thai's Avatar
Thai's Avatar
Water Crossing tips
http://www.offroaders.com/info/tech...er-crossing.htm
Watercrossing Summary
Vehicle Preparation
Walk the crossing to check its depth.
Don't cross fast flowing water.
Place markers at hidden obstacles.
Place a tarp across the front of the vehicle.
Disconnect the fan belt if a viscous coupling fan is not fitted.
Spray water repellent on distributor and ignition wires.
Pack recovery gear on top, ready for use.
Driving Technique
Take off seat belt and wind down window.
Use low range 2nd gear (in most situations).
Drive at a steady speed to create a bow wave.
Avoid using the clutch.
Do not over-rev engine if you lose traction.
If engine stalls, place in neutral without using clutch to restart. Takeoff in 1st low.
Post Watercrossing maintenance
Check diffs etc for water if depth above axles.
Check winches if fitted.
2023 Lexus GX
Lets Go Brandon!
Old 11-15-2002, 10:01 AM #3
Thai's Avatar
Thai's Avatar
How to tackle a hill!
Vehicle Rollover
Hills should always be tackled straight up or down, and sideway slopes avoided like the plague! A vehicle has to be at an extreme angle for it to roll head to tail, whereas a sideways roll can occur at much more modest angles. The way your luggage is packed has a pronounced affect on the angle a vehicle will roll sideways. You should avoid placing containers of extra fuel and water on the roof of your vehicle, as this will significantly decrease the angle at which a rollover is possible. This occurs because the extra weight on the top of a vehicle increases the 'center of gravity'. Heavy gear should always be packed low inside the vehicle and as centered as possible while only lightweight gear should be placed on roof racks.
The type of terrain will also affect the sideways rollover angle. In sand, mud or other soft terrain the weight transfer to the downhill wheels will cause them to sink, increasing the actual slope angle. So what may appear an acceptable angle on firm terrain may result in a rollover on soft terrain.
2023 Lexus GX
Lets Go Brandon!
Old 11-15-2002, 10:01 AM #4
Thai's Avatar
Thai's Avatar
Dust Control
Dust Control
When driving on dusty roads, its a good idea to have all your windows closed and the ventilation control set to outside air with the fan on high. This pressurises the vehicle interior slightly and helps reduce the amount of dust sucked into the vehicle. When another vehicle approaches, move the ventilation control to "recirculate" to stop dusty air coming in. Remember to move the ventilation back to outside air once you have passed through its dust trail or else the pressurisation effect will be lost. In hot weather, vehicles without air-conditioning have to make a choice between minimizing dust intake or winding the windows down for the (cough) fresh air.
The biggest problem area for dust intake is from the rear tailgate. Check that the rubber seals are in good condition and that they seal when closed.
2023 Lexus GX
Lets Go Brandon!
Old 11-15-2002, 10:02 AM #5
Thai's Avatar
Thai's Avatar
Mud Driving!
Mud Driving
Driving through mud is a cross between ice skating and walking through quicksand. Some types of mud have a greasy top layer with a hard baked surface underneath, while other types can be a bottomless quagmire of gooey mush.
Different types of mud require different driving techniques and equipment. Greasy mud with a hard bottom layer is best suited to narrow tires to allow them to cut through the top layer to bite the hard surface below. Wide tires in this situation tend to float on the greasy top layer without reaching the hard surface underneath.
Thick gooey mud tends to favour wide tires as they give some flotation, similar to wide tires favoring sand driving. Lowering your tire pressures can help just like when sand driving, though its best not to lower tire pressures below 20-25psi for mud.
Regardless of what type of mud and what width tires are fitted, the tread pattern needs to have large lugs to allow the tire to 'clean' itself. If they don't, the lugs fill with mud and the tire becomes a 'slick' with little chance of getting traction. Road orientated tread patterns tend to have closely spaced lugs to put more rubber on the road and to reduce tire noise at highway speeds. When it comes to mud, road tread tires are at a significant disadvantage, whereas in sand they help avoid 'digging in'. Dedicated mud tires have large open spaced lugs to keep the tire clean. However, they handle worse on bitumen as there is less rubber in contact with the ground and in sand they tend to dig in. Also they can have an annoying drone at highway speeds.
Mud Driving Techniques
Unlike some other types of terrain, mud-driving techniques vary on the type of mud. Reducing tire pressures can help in 'bottomless' mud whereas it can make things worse when a hard surface is below the mud. Mud usually tends to hide obstacles such as tree roots and sticks just waiting to slash your sidewalls, so its best to avoid reducing tire pressures if you can avoid it..
Driving on the peaks between tire tracks can provide firmer ground, as water tends to collect in the wheel tracks. Though sometimes the existing wheel tracks have cut through to the firmer surface underneath and provide the best traction.
Moving the steering wheel left to right about 90
2023 Lexus GX
Lets Go Brandon!
Old 11-15-2002, 10:02 AM #6
Thai's Avatar
Thai's Avatar
Sand Driving!
http://www.offroaders.com/info/tech...ng/sand_dri.htm
Summary-Sand Driving
Lower tire pressures to greatly improve traction and reduce track erosion
Drive smoothly with gear changes at high revs
Ensure wheels are pointing straight ahead when taking off
Avoid the soft sand at the base of dunes and gullies
Make turns as wide as possible
ONLY travel straight up or down dunes
Follow in others tire tracks to drive on compressed ground
Avoid braking by coasting to a stop
Do not floor the accelerator if you are bogging down
When bogged, try to reverse on your own tracks
Thoroughly hose down your vehicle after a beach trip
2023 Lexus GX
Lets Go Brandon!
Old 11-15-2002, 10:03 AM #7
Thai's Avatar
Thai's Avatar
A Beginner
Here's an article from Truck Trend
quote:
A Beginner
2023 Lexus GX
Lets Go Brandon!
Old 01-16-2003, 02:12 PM #8
stylishauto's Avatar
stylishauto stylishauto is offline
stylishauto is an unknown quantity at this point
Gotta see it to believe it!!!
Here is a site that will give you some really wild trail shot's and some great eye candy to go along with all of the hints.Just go and visit www.4x4wire.com , WARNING! seat belts are required!lol;)
"Driven By A Higher Standard"
stylishauto is offline   Reply With QuoteReply With Quote
Old 02-04-2004, 12:46 AM #9
TeryT's Avatar
TeryT TeryT is offline
TeryT is on a distinguished road
TeryT's Avatar
Who RU?
Thai - I've enjoyed your many & lengthy posts on here, but who are you? (since I can't send an e-mail to you, I will use this format) Do you work for Toyota?
Thanks - jus' wonderin':awais:
2003 V8 4x4 Sport 4Runner TRUCK OF THE MONTH SEPT. 06 - still tows a 25' ultralite Rockwood 2502 travel trailer all over creation!
MODS: GlowShift tranny temp gauge; Hayden 526 tranny cooler/fan combo; Hopkins Insight brake controller; Bilstein 5100 shocks
Hensley Arrow hitching system - quite simply the best for zero sway towing!
TeryT is offline   Reply With QuoteReply With Quote
Old 02-21-2004, 01:22 AM #10
Thai's Avatar
Thai's Avatar
Re: Who RU?
Thanks! Nope, i don't work for Toyota. I am a consumer just like you. This is my hobby...reading about SUVs is my hobby.
2023 Lexus GX
Lets Go Brandon!
Old 07-06-2004, 11:22 AM #11
GatorGreg's Avatar
GatorGreg GatorGreg is offline
Self-Appointed SUV Expert
GatorGreg is on a distinguished road
GatorGreg's Avatar
Thanks to Alpine for finding this article:
4WD TIPS: SAFE BEACH DRIVING
Most people take their 4x4s to the waterfront, where there's much fun to be had -- but there are hazards. Here are some helpful hints about driving on the sand.
No matter how many times people see photographs of drowned 4x4s we still have a regular supply of beachfront disasters. The beach is seen as a 'soft' 4x4 destination, but nothing could be further from the truth.
If you get stuck in a mud hole on a forest track there's unlikely to be any serious damage as a result, but get stuck on a windswept beach with the tide rising and it's quite a different story. More than one vehicle has been floated out to sea by the tide and hundreds have been drowned and buried. The servo picture galleries on Fraser Island are full of images of these disasters.
The light-hearted approach to beach driving isn't helped by TV ads that continue to illustrate in glorious colour how NOT to drive a 4x4 on a beach. The 4x4 dealer network must hate these ad campaigns, because some dealers are faced every Monday by owners of towed-in 4x4s expecting warranty repairs on waterlogged machines. In some car dealerships salt encrustation and beach sand lodged in a 4x4's underbody is enough to have warranty denied.
Believe us, if you drive your 4x4 like the TV ad drivers do you'll be denied warranty under the heading of 'driver abuse' and the salesman who extolled the virtues of your new 4x4 will have become as forgetful as Alan Bond when you revisit him.
Sand driving is a wonderful experience, but there are necessary steps to take to ensure that your vehicle and its occupants are safe at all times. Strange things happen to some 4x4 owners when they experience the freedom of beachfront driving.
One of the biggest assets to the beach driver is tyre pressure. Lower tyre pressure helps the vehicle 'float' on the soft sand, while higher pressures will give the vehicle a tendency to dig in to the sand. Pressures should be lowered to around 18-20psi for a start. Remember, two of your greatest assets in sand driving are your tyre-pressure gauge and pump.
Speed is dangerous on a beachfront, because the soft nature of the ground means that all vehicle responses are slowed and steering has a delayed reaction. Because you've dropped your tyre pressures their speed capability is reduced drastically and their 'soggy' sidewalls won't resist vehicle sway.
Also, if you're travelling quickly you can't see obstacles far enough ahead to take gentle avoiding action. Sudden manoeuvres have led to many a beach roll over. Splashing through water looks great on TV, but it's dangerous -- hit a deeper or softer patch and the steering wheel can be jerked out of your hands and you'll lose control.
Water spray is harmful to vehicles -- at best it will pool underneath and start corrosion and at worst it will blast its way into mechanical components and damage them. Water passes easily through an air-cleaner element and into the inlet manifold, and can completely destroy an engine in seconds.
Fitting a snorkel will help keep water out of the inlet manifold, but won't stop it getting into axle
and transmission housings. There's a lively myth that 4x4s are somehow more water resistant than normal cars, but they're not -- they're just higher off the ground.
Sand dunes are a real trap for the uninitiated. However, with common sense and a little knowledge, they can be a heap of fun. Here are a few tips:
• Never drive over a dune without knowing what's on the other side. There might be a vertical drop-off, another vehicle, or worse, some people there.
• If you look like getting stuck on an ascent, don't try to turn around. Reverse back down on your own tracks.
• Don't try to traverse the dunes -- drive straight up and down. The added load on the downhill wheels can dig them in and cause a rollover.
• Momentum will get you up the dune but don't use too much. Just enough to crest the dune and you won't inadvertently fly over the top.
Remember, the beach is there for all users. Act responsibly and they won't be closed off to the responsible majority of 4x4 drivers.
2005 Pacific Blue Metallic SR5 4x4
2003 Dorado Gold Pearl GX470 (2003 Four Wheeler & 4x4 of the Year)
2000 Millennium Silver Metallic SR5 4x4 5spd - RIP
GatorGreg is offline   Reply With QuoteReply With Quote
Old 07-06-2004, 01:38 PM #12
TeryT's Avatar
TeryT's Avatar
Thanks for the info. However, this (quoted portion) doesn't seem to be entirely accurate to me. Most 4x4s have things like breather tubes & check valves on the axles, transmissions, transfer cases, etc.
Otherwise, great stuff!
Old 09-18-2005, 03:02 AM #13
SurfingDrunk's Avatar
SurfingDrunk SurfingDrunk is offline
SurfingDrunk is an unknown quantity at this point
Exclamation Re: Off-roading Tips
I found this on my tacoma forum, TTORA.
I compiled this checklist from several sources
This is a list of items that you should consider having when you travel on 4-wheel drive trails, in the mountains, or other remote areas where help could be delayed or not received. Even if you only plan a short trip, it could turn into a long trip due to mechanical or navigational issues.
Information listed was obtained from California Association of 4 Wheel Drive Clubs, Esprit De Four 4 Wheel Drive Club, Backcountry Adventures (ISBN: 1-930193-08-4), Guide to California Backroads & 4 Wheel Drive Trails (ISBN: 0-9664976-5-1), last and least: my personal experience.
WEB LINKS:
United Four Wheel Drive Clubs
Blur Ribbon Coalition
Tread Lightly
***DISCLAIMER: (Please read all of this!!)***
Using this list and having all of these items does not guarantee you or your vehicle
"Sh!t happens, gotta roll with it, adapt, Darwin, I Ching."
Fallen in the line of duty: '93 Toyota, '00 Tacoma, '97 4Runner
SurfingDrunk is offline   Reply With QuoteReply With Quote
Old 08-09-2006, 12:38 AM #14
rustyrazor's Avatar
rustyrazor rustyrazor is offline
rustyrazor is an unknown quantity at this point
rustyrazor's Avatar
Off-roading = getting stuck
A slight change of pace here. I know that it's been mentioned in passing but this is essential. You need to be prepared to get unstuck.
The fact is if you're seriously off roading, and I don't mean going from a paved road to a dirt road, eventually you'll get stuck.
Here's some of the essentials I carry for getting unstuck:
"Snatch" tow strap. If you have traction you can use a corolla to get your 4runner out. It's all about the slack.
A come-a-long and some extra chain. Bring a pair of heavy work gloves too. It can save you from some serious blisters.
It's nice to have a jackall or hi lift jack although you really need to make sure you know how to use it. I've heard of guys that have been knocked out by the bar. This can also be used as a winch (in a pinch) ha.
Traction aids like traction grabbers are usefull. I've used the floor mats for extra traction. I used to have a 2x10 board with a strip of an old snowmachine track nailed onto it. Rigth now I've got steel traction grabbers that fold up into a nice small box. Just remember to tie about a 6 foot length of rope to them so that you don't have to dig in the mud to get them out, or lose them altogether.
I'll probably think of some more later.
Ray
1992 SR5 3L-V6 auto
1990 SR5 4cyl manual - RIP
rustyrazor is offline   Reply With QuoteReply With Quote
Old 10-02-2006, 08:52 PM #15
4by4th's Avatar
4by4th 4by4th is offline
4by4th is on a distinguished road
4by4th's Avatar
Re: Water Crossing tips
How do I check this on a 2004 4Runner 4x4? Is there a link to directions on-line? We paid $150 labor and $75 for synthetic differential oil to have it changed on our Cherokee today. The 4Runner's recently been through the same creek crossing.
I didn't think we were up to the axles, but it's hard to tell what's going on underneath blasting across the creek.
My 4th 4x4: 2004 V6 4Runner 4x4 (dealer replaced engine at 70,000 miles 2006 - http://www.toyota-4runner.org/showth...ight=nightmare), Mich. Cross Terrains, Nitto T/G, now BFG AT KO's 265/70/17, Leather, Husky mats, Escort, iPhone (phone, GPS, iPod), USA Spec Bluetooth Interface, Fumoto Valve
Current daily driver: 2008 Honda Accord EX-L w/Navi
4by4th is offline   Reply With QuoteReply With Quote
Some 4WD tips for novice wheelers. Jay Off-Roading 12 12-01-2019 09:33 PM
manual vs. auto for off roading? brian2sun 3rd gen T4Rs 69 03-20-2014 10:29 PM
tips for waxing roof LBeard87 Maintenance/Detailing 8 05-05-2010 05:49 PM
Looking for Tips on Driving the Dempster Highway (YK, NWT) Dycker_98SR5 4th Gen T4Rs 7 03-28-2008 04:47 PM
First Time in Snow...Any Tips?? MikeinCincy 4th Gen T4Rs 2 12-14-2007 07:30 AM
