Originally posted by Mr. Lambdebois
Let me ask you this.... How many mercedes and land rover's that were built to 4x4.... used atrac, and did not have a locking differential option also to lock up at least the rear if you needed it for a true split side to side?
Please read the summary below if you're in a hurry.
Mercedes started using ATRAC in their SUV in 1998 with the M-class introduction. Land Rover started a bit earlier i think with the previous generation of Range Rover...however, i am not too sure on this. For sure, the 2001 Discovery Series II had ATRAC and 2003 RR had it too.
Mercedes did not have any locker option...only in 2006 does the M-class have an off-road package with rear locker (not available in USA). The new 2007 Mercedes GL-class does have a rear locker as option (available in USA). Both today's M-class and GL-class use ATRAC.
Land Rover did not introduce a rear locker until the introduction of LR3. Before that, it was open diff with ATRAC (Discovery Series II). The Discovery Series I was open diff with no ATRAC. That was why Land Rover depended so much on wheel articulation to get over obstacles. The Discovery S1 did have a center diff lock that was not available in Series II until 2004. The current Range Rover does not have a locking center diff nor a rear locker...only Torsen center diff (non-lockable) and ATRAC.
Summary: (remember, this is based on MY MEMORY...so check these before committing to it. I am on a break from gardening.
Mercedes:
1979-1998 = Mercedes only SUV is G-wagen (not officially sold here)...front, center, rear lockers; no ATRAC
1998 = Mercedes M-class with ATRAC
2002 = Mercedes G500 official USA introduction with ATRAC & full set of lockers
2006 = Mercedes M-class 2nd generation with ATRAC and optional rear locker (in other parts of the world)
2007 = Mercedes GL-class with ATRAC and rear locker as option
Land Rover:
Before 2001 = Land Rover Discovery SI had open diffs and no lockers
2001 = Land Rover Discovery SII introduction with ATRAC (no center diff lock)
2003 = Range Rover MKIII was introduced with ATRAC, cross-linking air suspension, and Torsen center diff (not manually lockable however)
2004 = Land Rover Discovery SII with center diff lockable
2005 = Land Rover LR3 introduction with Terrain Response which totally incorporates ATRAC, center diff lock, and optional rear locker
2006-7 = Range Rover is supposed to also have Terrain Response....
Hope this helps.
