02-20-2015, 10:35 AM
Real Name: Matthew
Real Name: Matthew
Highlift Jack?
Hey,
I've purchased the Yakima load-warrior and high-lift jack mount, was about to buy my high-lift jack and realized I may have jumped the gun.
I have a 2014 SR5 stock, so stuck bumpers/wheel-wells. Is this thing basically useless to me unless I have modded body gear? or is there a way around it?
Thanks,
02-20-2015, 10:56 AM
In general that's true, you usually need a slider or metal bumper to jack up.
One thing you can get though is an adapter that allows you to jack up using your wheel. It has a couple of hooks that go around a couple of your wheel spokes and allows you to lift that wheel off the ground to get sand/rocks/traks or whatever under it. http://www.hi-lift.com/accessories/lift-mate.html
Once you have sliders which you should have for doing any offroading that might involve something other than sand, you can jack using those...
02-20-2015, 11:00 AM
Real Name: Kevin
Real Name: Kevin
Check out the Liftmate. It'll lift the truck by the wheels, if there's openings in the wheels large enough for the hooks. If you're feeling thrifty, you can do the same thing with a ratchet strap around the tire or hooked to the wheel openings, make sure it's a hefty one. Either way, you'll need to improvise a jackstand (or pack one) to keep the truck in the air if you intend to change the tire you're lifting. Most guys with stock/mildly lifted trucks just pack a crib of 2x4s or some such to use under the stock bottle jack.
You can winch with your hilift too, it's not as nice as an electric or hydro winch but it's better than nothing. You can assemble a set of chains and hooks and such to do that with, or check out the ORK if you want a packaged solution for that too.
Go ahead and buy the hilift, it's got a million uses and is a pretty basic part of your offroad kit.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
02-20-2015, 11:31 AM
Real Name: Matthew
Real Name: Matthew
[QUOTE=Once you have sliders which you should have for doing any offroading that might involve something other than sand, you can jack using those...[/QUOTE]
Thanks, I've been shopping sliders, looks like a spendy but needed element. Suggestions? I'm in the Portland area.
Real Name: Matthew
Real Name: Matthew
Originally Posted by KidVermicious
Check out the Liftmate. .
I was looking at that, seems like it makes it unstable?
02-20-2015, 11:38 AM
I'd rather lift with the liftmate than lift from my sliders. It is quite stable but you are still using a hi-lift, caution is a must.
2014 TE-KDSS
OPOR sliders, RCI aluminum full skids+(gas tank & A-arms), Icon Stage 2 w/ 3in overland springs, Cooper ST Maxx 255/80, Undercover HWMS w/ Superwinch Talon, K9 2.2
Daily:99 rav4 - OME baby lift, 31s, 5 speed Past:91 LC - built
02-20-2015, 11:46 AM
@ Mietsko
Also, do yourself a favor and spend a few more bucks on the 60in. It might be bigger to lug around but when it comes time for you to use it you will thank yourself.
2014 TE-KDSS
02-20-2015, 11:50 AM
Real Name: Matthew
Real Name: Matthew
Originally Posted by st8rocks
@ Mietsko
Awesome, this was my next question as I stare at the Amazon screen wondering if I need those 12"
Thanks!
02-20-2015, 11:54 AM
Thanks!
Another useful investment is the off-road base. Many uses for this thing on the trails. And beats the 2x4 block of wood you might use for your normal driveway jacking.
2014 TE-KDSS
02-20-2015, 12:14 PM
Real Name: Matthew
Real Name: Matthew
yep, also considering this item, it's spendy, but it looks better
Bogert 51M-SJS48 Safe Jack Stabilizer for 48" Hi-Lift Style Jack at SkyGeek.com
03-02-2015, 07:19 PM
I have these on my truck, I have used the heck out of them on the trails and they work great i even had the truck resting on them for 4 months while it was down
you just need to weld them on
1990 - 2013 Toyota 4Runner Off Road Rock Slider
2005 4runner sport, v8, magnaflo muffler, removed resonator, de-badged Drop in K&N pioneer 3300bt, back up camera, interior led upgrade Icon 2.5" external reservoir front, Icon 2.5" CDC external reservoir metaltech long travel rear shocks and system with Addicted offroad shock relocated 1" outward to work right protected by RCI full skid plates 295/70/17 toyo open country mt http://www.toyota-4runner.org/4th-ge...read-05-a.html
2014 november truck of the month
02-02-2020, 10:31 PM
Can anyone confirm whether the liftmate works well in the stock Pro wheels? I want to get one for use on my 19pro.
02-09-2020, 07:48 PM
That looks like a sturdy one.
2004 Toyota 4Runner SR5 4WD Auto
02-10-2020, 10:18 AM
if you don't need to remove the tire/wheel then lifting the wheel is actually more stable since you have to lift it less high. when you lift from a slider you have to lift higher than the suspension droop before you raise a wheel, but when you lift from the wheel it comes right up.
so if you are stuck and your goal is to lift the vehicle and stack rocks under the tire, then the wheel straps are helpful and can be more stable, but lifting from the wheel means you can't use your hi-lift to change a tire or do things like jack the vehicle over an obstacle and drive off the high lift
it's worth noting that the factory jack still works offroad if you need to stack rocks, and also if you're doing offroading serious enough to need a hi-lift you should really get some sliders
