Old 05-09-2006, 02:30 PM #1
AlexJet's Avatar
AlexJet AlexJet is offline
AlexJet is on a distinguished road
AlexJet's Avatar
Downey Skid Plate
I'm trying to install Downey Skid Plate on my 4Runner, but it won't line up as it should be. I called Downey and talked to their technician, but still have some questions.
Does anyone has Downey skid plate? If so, could you post some pictures how you mounted it?
This skid plate is for 01-04 Tacoma, but it may fit 96-00 Tacoma with some modification, 03-06 4Runner.
2005 4Runner Limited V6
Safari Snorkel, Custom 5”, ARB Lockers, 4.56 Nitro Gears, 285/65-R18 + 18x9 (-12), 315/70-R17 + 17x9 (-6), ARB Front Bumper, WARN 9.5xp, Custom Full Undercarriage Protection: bumper to bumper, Custom Rock Sliders/Steps, CBI Rear Bumper.
2016 4Runner Limited
Safari Snorkel, 3" OME, 285/65-R18, 18x9 (-12), Custom Rock Sliders/Steps,... work in progress
AlexJet is offline   Reply With QuoteReply With Quote
Old 06-05-2006, 01:24 PM #2
jj8111's Avatar
jj8111 jj8111 is offline
Registered User
jj8111 is an unknown quantity at this point
Registered User
jj8111's Avatar
You need to drill 2 holes near the rear (flat) end of the plate so you can mount it to the cross member.
jj8111 is offline   Reply With QuoteReply With Quote
Old 06-05-2006, 01:31 PM #3
AlexJet's Avatar
AlexJet's Avatar
Actually I did mount it. Yes it need be drilled out two holes in the back, hole for "C" brackets at the center (another "C" bracket has to be welded up at the outer side of the skid + more holes for oil and transmission drains.
Old 06-05-2006, 01:42 PM #4
jj8111's Avatar
Registered User
Registered User
jj8111's Avatar
I didn't have to weld anything to the plate to get it mounted. I welded 2 brackets to the front crossmeber to hold the front of the plate on I also drilled 2 holes in the rear of the plate to have it line up with the tapped holes in the other crossmember.
What is this "C" bracket you refer to?
I also didn't open any holes to change the oil. I remove the plate each time. I "lost" my stock plate when it got hung up on the oil drain access hole.
Old 06-05-2006, 01:45 PM #5
AlexJet's Avatar
AlexJet's Avatar
"C" brackets are two big brackets holding the skid in the middle.
Old 06-05-2006, 01:56 PM #6
jj8111's Avatar
Registered User
Registered User
jj8111's Avatar
do you have a pic?
Its been a while since I got mine from Downey. I would like to see what changes they have made.
There were no mount points in the middle of the plate when I installed mine.
Old 06-05-2006, 02:23 PM #7
AlexJet's Avatar
AlexJet's Avatar
I'm planning to take it of in a couple of day for some modification. So I'll place couple pictures right after it.
Old 06-05-2006, 09:45 PM #8
Falls Falls is offline
Super Moderator
Falls is on a distinguished road
Super Moderator
Did you know it was'nt a bolt on item ? or did that take you by surpise. I too thought od getting this skid but seem's to be to much of a hassle after reading your story. Good luck & keep us posted.
< 2016 Classic Silver TE w/KDSS >< Bone stock at the moment >
Falls is offline   Reply With QuoteReply With Quote
Old 06-05-2006, 09:56 PM #9
AlexJet's Avatar
AlexJet's Avatar
I knew it wasn't a bolt-on.
Nothing wrong with the skid. It's good piece of art. At least 3 times thicker then stock. The down point - it's too small and need custom fabrication. Overall it's fine for me.
V-8 skid plate mod for oil filter change loner Maintenance/Detailing 16 12-31-2023 09:01 AM
Measurement needed 1999 skid plate ground clearance martini 3rd gen T4Rs 4 03-22-2010 07:17 PM
Skid plate access question howieb 4th Gen T4Rs 5 02-21-2010 09:35 AM
New Downey Skid Plate (socal) purplehazek4 Classifieds - buy & sell (no commercial ads please) 12 09-05-2007 08:10 PM
Downey Off-Road Skid Plate AlexJet 4th Gen T4Rs 6 04-27-2006 04:38 PM
