Old 06-05-2006, 11:58 PM #16
C-4Runner's Avatar
C-4Runner C-4Runner is offline
C-4Runner is an unknown quantity at this point
C-4Runner's Avatar
You are correct my friend. I had about 1000 miles on my Dunlops. I think the most they'll give you is $50/tire for a trade in and they'll even try to give you less. Stand your ground... hold your breath if you have to.
If they won't match the price just for asking, ask them if they'll match one of their own store's price. I'll email you my receipt if that'll help.
Initial Success... or Total Failure.
'06 SR5 V6 4WD
C-4Runner is offline   Reply With QuoteReply With Quote
Old 06-06-2006, 10:29 AM #17
Ruta Ruta is offline
Ruta is on a distinguished road
Wow...im going to get me some BFG AT's this weekend....please send me a copy of that receipt to [email protected] and also if you can send me a pic of your 4runner with those tires that'll be great just to see how the truck looks with those tires on....should be pretty sweet. They should be able to match them...my stock dunlops have about 1800 miles on them. but definetely want the All terrains.
Ruta
2008 Black 4runner Sports Edition
Ruta is offline   Reply With QuoteReply With Quote
Old 05-27-2008, 02:25 AM #18
GRIMACE GRIMACE is offline
GRIMACE is an unknown quantity at this point
Tire Size for Stock 18s with OME lift.
So I've finally got my OME lift installed and I want to run my stock 18s. Do you guys have any new recommendations on the size and brand of tires I should run without any further modifications. I really want to get some Revos.......... is that possibe?
Thanks again
Dave
community.webshots.com/user/grimace888
GRIMACE is offline   Reply With QuoteReply With Quote
Old 12-18-2013, 04:27 PM #19
MinnesotaYota MinnesotaYota is offline
MinnesotaYota is on a distinguished road
I'd like to weigh in on this thread despite it being half a decade old. I own a 2006 4Runner Limited which came with 18" rims and 265/60R18 stock tires. Wanting to go with a slightly taller tire I purchased and installed a set of 265/70R18 Yokohama Geolander A/T-S all terrains. The tires stand exactly 32" tall under load and definitely rub (stock suspension) in the front (not the back) but only on the plastic splash-guard so no rubbing on metal.
To get a little lift to prevent the rubbing, the solution I've opted for, and what I've found are very popular, is a lift/leveling kit made by Daystar (Daystar? - Driven by Design). There are others available too (Velocity, Rough country, etc.). Gives the front a 2" lift, the rear ~1.5", and removes the built-in rake that these 4th gen 4Runners have. Also, since the spacers are installed on top of the struts/springs, the install is much easier than a suspension or body lift. If there's interest, I can post pics.
MinnesotaYota is offline   Reply With QuoteReply With Quote
Old 04-05-2016, 03:58 PM #20
Tricorp Tricorp is offline
Tricorp is on a distinguished road
Bump
Tricorp is offline   Reply With QuoteReply With Quote
Old 04-07-2016, 02:34 PM #21
NPSt4r NPSt4r is offline
NPSt4r is on a distinguished road
Bfg a/t ko2
I have a 07 sport 4wd and I plan to swap the XREAS for 5100s. What would be a good setting to run on the front while keeping stock coils? Also will 265/70r17 BFG K02 fit with this setup? Thanks
NPSt4r is offline   Reply With QuoteReply With Quote
Old 05-16-2018, 11:55 PM #22
Erv_308 Erv_308 is offline
Erv_308 is on a distinguished road
If I go with a 16inch wheel how big of a tire can I put without scraping on stock height? On a 2006 4 runner sport 4wd
Erv_308 is offline   Reply With QuoteReply With Quote
Old 05-21-2018, 09:56 AM #23
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
Double check that a 16" wheel will fit. I suspect the brake components are too big for that size wheel, so you might need to downgrade to base model parts too.
But either way, anything that results in greater than a 32dia x 10width will rub without mods.
techno is offline   Reply With QuoteReply With Quote
Old 11-26-2019, 05:29 AM #24
RUN4YODA RUN4YODA is offline
RUN4YODA is on a distinguished road
Originally Posted by Thai View Post
Why not?? Does 17" rims not fit on '06 4runner??
My 06 has 17s from factory. But I also am wanting something meaty
Sent from my SM-N960U using Tapatalk
RUN4YODA is offline   Reply With QuoteReply With Quote
Old 12-10-2019, 09:07 AM #25
RitsE RitsE is offline
RitsE is on a distinguished road
Originally Posted by Ruta View Post
Let me get this straight...you told them that you had found them at $165 a piece somewhere else and they matched it and they also bought back the dunlop stock tires?? so basically the cost per tire was $165-$50=$115 a tire? Any chance this was in atlanta??? I going to a discount tire the weekend for sure.
Thanks,
the tires will hold but what radius they could understand from the photo
RitsE is offline   Reply With QuoteReply With Quote
Old 10-26-2021, 12:20 PM #26
kevinMc kevinMc is offline
kevinMc is on a distinguished road
Upgrading Rims and Tires 2014 4Runner limited
Hey guys, new here. I have a 2014 4runner limited with leveling kit. Going to get rid of the stock 20" rims and move to a 18x9 with 285 / 65 R18 Open Country A/T III. Will these fit and also what offset will i need? Thanks
kevinMc is offline   Reply With QuoteReply With Quote
92 4Runner Max Tire Size Stillrunning Classic T4Rs 12 03-09-2011 08:38 PM
2010 4Runner TE Max tire size Marcopolo Engines / Suspension / Wheels / Tires / Audio / Accessories 0 09-10-2010 09:21 PM
2002 4runner tire size Waldo General Discussions 1 08-31-2010 02:05 AM
New 2006 4Runner Limited Silver Mark86 Gallery 5 01-30-2006 12:06 PM
Complete Information on 3rd Generation 4Runners Thai 3rd gen T4Rs 9 04-17-2003 01:10 PM
