Old 03-30-2016, 12:18 AM #1
Porqupine82's Avatar
Porqupine82 Porqupine82 is offline
Porqupine82 will become famous soon enough
Clinometer App
I've recently found myself puckering way too early on off camber and slope, and figured I'd share an app I found which helped easy my puckering when on a slope....
I have determined my pucker number is right around 20 degrees
The app is in the play store, and it's free.. just search "Clinometer" the developer is plaincode... I have no affiliation, but I do find it quite useful.
You can see how it works on my instagram, my IG name is the same as my screen name here... check it out if you like.
Porqupine82 is offline   Reply With QuoteReply With Quote
Old 03-08-2021, 12:48 AM #2
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
If you want to calibrate yourself a bit, (carefully) note the clinometer reading while briskly going around corners on pavement, especially roundabouts. I hit 20 degrees on the clinometer regularly while cornering, and it doesn't feel like a big deal at all. Not nearly as scary as 20 degrees of tilt on the trail. It''s more a psychological thing than physical.
The truck will do 40-45 degrees without rolling, but I could never bring myself to push it that far.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 03-08-2021, 02:50 AM #3
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Most I have done that I know is 30-33 at crawling speed and it felt fine, fully stock at the time, no roof cargo.
WTB: 1st Gen 4Runner clinometer Petrone For Sale: T4R Items 3 11-12-2015 11:08 AM
Clinometer Lego3k1 For Sale: T4R Items 5 05-28-2014 03:55 PM
Anyone have a clinometer on a 4th Gen? r3dh3ad84 4th Gen T4Rs 2 10-08-2008 01:38 AM
clinometer? captwalker87 Classic T4Rs 1 11-20-2005 11:26 PM
Clinometer le34ah56 Classic T4Rs 10 05-13-2005 11:06 PM
