Originally Posted by TRD Am
Thanks!
Max Traxx specifically? They're crazy expensive, but younthinkntheyre worth it?
There are several other options... The MaxTraxx are good, I went with the Tred Pro as I liked their design better. Those are both fairly equivalent and rather top of the line.
If you have plenty of space, another option is the traditional aluminum ladders
Those are still pricy, but can be longer/shorter/wider/etc to meet your needs, and will probably hold up better in the long run, though performance will likely be slightly less than the plastic ones I mention above (less traction).
After that you get to things like the smittybilt option, which might be great, or might not be. FrontRunner have a pair of fiberglass sand ladders, but I wouldn't really recommend them for snow/ice.
There's also tools such as the x-jack, which might be nice on snow. Maybe something like a pull-pal if you don't have other places to attach your winch if you want to spend the money.
Anyways, you have a winch and a shovel (full size shovel, yes?). Get a pair of traction boards (do your research, see what's best for you) and some chains and you should be good. Oh, and a compressor maybe-so you can air down/up as needed.
