Old 10-28-2018, 04:10 AM #16
mrblah's Avatar
mrblah mrblah is online now
mrblah's Avatar
I have both the stauns and the ARB unit.
I prefer the stauns for ease of use and have it set to 18 psi. If I want any other pressure, I break out the ARB.
mrblah is online now   Reply With QuoteReply With Quote
Old 10-29-2018, 11:18 AM #17
Lindenwood's Avatar
Lindenwood Lindenwood is offline
Lindenwood is on a distinguished road
Lindenwood's Avatar
I made my own . This is Version 2.0 that I clearly cobbled together.
To deflate, I hook up all for tires, then use the release valve to deflate them tires at the same time, to the same pressure. It takes about 10 seconds per 5 PSI, and I just stop periodically to check the gauge on the regulator. I initially thought I could leave the regulator set to a specific PSI and it would auto-deflate, but the release rate is so slow it took like 40 mins to actually deflate the tires from 40 to 15 PSI, heh.
To inflate, I hook the coupler to one affixed to my rear bumper that comes from my pump. However, because I used a regulator valve on the inflator/deflator, I can keep my pump's line pressure at 90+ PSI, and the valve on my inflator / deflator simply starts to hiss when I reach target pressure. It takes 9.5 minutes to go from 15 to 40 PSI, and they are all at the exact same pressure.
Deflators-20181027_104312-800x600-jpg
Mine: 2002 SR5, Lifted, Armored, and Accessorized on 33s. Build Thread
Hers: 2016 Quicksand TRDP, Lifted 2" on ~32s.
Lindenwood is offline   Reply With QuoteReply With Quote
Old 10-29-2018, 11:21 AM #18
J.F. Sebastian J.F. Sebastian is offline
J.F. Sebastian is on a distinguished road
That is a great idea! There's a profitable business in there somewhere?
J.F. Sebastian is offline   Reply With QuoteReply With Quote
Old 10-29-2018, 12:26 PM #19
Lindenwood's Avatar
Lindenwood's Avatar
Haha feel free! I have far less time than money these days so if you want to take the time to put a few of these together, have at it! I think it would have cost me something like $50-60 to make, but you could probanly get those costs down with a bulk order.
I used the following supplies, purchased from mostly ebay
--6mm Pneumatic tube (about 40ft I think).
--6x 1/4 NPT Male to 6mm Push Connector
----(2 on the inputs, and one for each tire).
--2x 6mm Push Connection Y fitting
--4x Closed locking shrader connections
--Basic inline regulator from Harbor Freight. (Hook the outlet side to the tire system, and plug the inlet side).
--Version 2.1 will replace all the brass T-fittings with a 5-way brass block so dramatically decrease the size of the object. There is one on Amazon for like $12.
Old 01-14-2019, 04:53 PM #20
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
I just purchased the Staun's. I'd rather pay for quality that will last. Seems much better to just screw these 4 in to each tire and wait 5 or 10 minutes and be done with it.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 01-14-2019, 08:18 PM #21
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
I use Coyote, no complaints and no issues.
I have each set up at different PSI for different scenarios.
Old 01-21-2019, 01:14 PM #22
00Spork's Avatar
00Spork 00Spork is offline
Real Name: N3ZZAR
00Spork is on a distinguished road
00Spork's Avatar
Real Name: N3ZZAR
I've never heard anything good about a cheap set of deflators. Nobody is ever satisfied.
I bought a set of Stauns about 10 years ago and still use them. I wouldn't buy anything but Stauns, but I'm the type to buy the nice stuff up front so I don't have to worry about buying crap and being upset.
00Spork is offline   Reply With QuoteReply With Quote
Old 01-22-2019, 02:17 AM #23
MAST4R's Avatar
MAST4R's Avatar
Yup, Staun or Coyote, same thing:
STAUN DEFLATORS - HOW THEY WORK - Coyote Enterprises
Old 02-21-2020, 12:06 PM #24
TacoTo4Runner TacoTo4Runner is offline
TacoTo4Runner is on a distinguished road
I ordered Real 4X4 4 Tire Air Deflators for Offroad Vehicles. Does anyone have any experience with these?
TacoTo4Runner is offline   Reply With QuoteReply With Quote
Old 02-21-2020, 12:21 PM #25
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
I made one also. It deflates (inflates) all 4 tires at once to exactly the same psi.
30 psi to 15 psi in about 2 minutes. Back to 35 psi in about the same with the home shop compressor. (had to go to 35 to turn off the TPMS light, then back down to 30)
Cost with 100' hose (only used 50') was around $50-60.
patkelly4370 is offline   Reply With QuoteReply With Quote
Smittybuilt or Staun deflators GHARP57 Off-Roading 3 10-29-2015 02:33 PM
Tire Deflators...? STRRAYNGE 3rd gen T4Rs 25 12-14-2012 07:47 PM
Ferret Tyre Deflators brockeverly 5th gen T4Rs 20 09-24-2012 09:47 AM
tire deflators akoda Off-Roading 2 08-06-2006 05:22 AM
