Old 02-18-2004, 03:58 AM #1
nathannookie's Avatar
nathannookie nathannookie is offline
nathannookie is an unknown quantity at this point
Question Driving in Beach Sand with 2WD
Is it possible to drive in beach sand, or small dunes, with 2WD if you air down the tires?
nathannookie is offline   Reply With QuoteReply With Quote
Old 02-18-2004, 01:08 PM #2
rando's Avatar
rando rando is offline
rando is on a distinguished road
rando's Avatar
Yes, I've done this with my Toyota pickup and other vehicles at Pismo. If you stay down on the hard stuff near the water, you won't even need to air down. For soft flat sand, you'll probably need to let out air (each vehicle and tire combination is different). As far as dune rolling, you CAN make it with 2wd though you will need to be really careful and even then you MUST be able to enlist the help of other people when you get stuck. Another 4wd with a tow strap can usually get you out. As a backup, you can try getting a couple of guys to jump up and down on your rear bumper ... this is a good technique with pickups but I'm not sure how you'd do it safely with a 4runner.
You should be aware that even with a 4wd system, it is entirely possible (even common) to get stuck in the dunes. Worst case you can always call for a tow but be prepared to pay the big $$$ for that 'emergency' service. If it were up to me, I'd avoid the dunes and stick to the flatland nearer the beach. Getting stuck isn't really much fun.
It's good to see a fellow Redondo member here.
Have fun!
rando is offline   Reply With QuoteReply With Quote
Old 02-18-2004, 07:16 PM #3
Thumbs up I'll stick to the flatlands sand
Thanks,
Yeah, I used to have a 4WD, and yes, even then, got stuck in the bigger dunes.... UNLESS I aired down quite a bit. In the morning, or at night, when the sand was damp, it was much easier too.
Guys have told me that if you air down 'enough' you can do a lot with 2WD, but, like you suggested, I'll stick to the beach area. And yes, "All Tow" is expensive up there.
Old 02-20-2004, 02:34 PM #4
Good Times's Avatar
Good Times Good Times is offline
Good Times is on a distinguished road
Good Times's Avatar
I've seen a few 2wd do some crazy stuff on the dunes. Heck even saw a 2wd pull out a 2wd that was stuck
As long as you air down ALOT and I mean down to single digits, then you should be fine.
EDIT:
Make sure you have friends that can pull you out if you get stuck ;)
Good Times is offline   Reply With QuoteReply With Quote
Old 02-21-2004, 01:25 AM #5
Thai's Avatar
Thai Thai is offline
Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold
Thai's Avatar
Momentum...keep momentum!!!!
Oh yeah, you should have an air compressor to air UP when you finish playing!
My 2019 Land Cruiser
My 2023 Ford F150 Platinum FX4 Powerboost with 7.2 kW ProPower Onboard
2023 Lexus GX
2024 Subaru Impreza RS
Lets Go Brandon!
Thai is offline   Reply With QuoteReply With Quote
Old 02-22-2004, 12:31 AM #6
Talking
I wonder how much one can 'air down' before the tires could come off the rims? Maybe 8-9 lbs.
Yeah, I need a compressor.
2004 Black Sport Edition V6
Redondo Beach CA
Old 03-20-2004, 06:37 PM #7
patin22's Avatar
patin22 patin22 is offline
Registered User
patin22 is an unknown quantity at this point
Registered User
patin22's Avatar
Yeah, I can't imagine going any lower than that. I once saw a guy reseat the tire bead on his rim with starter fluid - I guess it's a relatively well known emergency practice, but it's still a little freaky!
patin22 is offline   Reply With QuoteReply With Quote
Old 08-31-2004, 01:53 AM #8
zworker zworker is offline
zworker is an unknown quantity at this point
letting air out in snow also helps..
'91 Toyota 4runner *MINT*$5000.00
New Baja tires $ 377.34
Never getting it stuck....
http://www.northcountytoyotaparts.com/menu/4runner.gif
zworker is offline   Reply With QuoteReply With Quote
Old 06-30-2023, 03:39 AM #9
Chief_Surf Chief_Surf is offline
Chief_Surf is on a distinguished road
Have you been doing much off-roading with your 2wd. I just got one and I'm trying to figure out how to do it without breaking the bank. Is there a specific lift you did or other modifications? And what about speed vs slow? Does that change the kit at all?
Chief_Surf is offline   Reply With QuoteReply With Quote
Old 06-30-2023, 10:14 AM #10
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
~19 yr old thread, a new forum record?
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 07-21-2023, 04:21 PM #11
Gotta ask somewhere I suppose!
Old 09-13-2023, 04:53 PM #12
Useatorquewrench Useatorquewrench is offline
Useatorquewrench is on a distinguished road
Sure, with some proper skill and cahones
Useatorquewrench is offline   Reply With QuoteReply With Quote
Off-roading Tips Thai Off-Roading 113 11-11-2023 12:05 PM
2wd Offroading Help andyman32392 4th Gen T4Rs 4 09-22-2010 11:06 AM
Changing from 2WD to 4HI question 4Runner168 Problems & Warranty Issues 3 06-01-2009 02:28 PM
First Driving Impressions on New 4R Brazos 4th Gen T4Rs 5 07-12-2008 02:56 PM
Driving in the Sand BigDogMoney 4th Gen T4Rs 15 06-26-2004 06:53 AM
