01-21-2019, 01:39 AM
Tow strap question
This sounds elementary, but every so often I need to pull someone out of a simple snowdrift or mud puddle, usually a car. Right now I have a decent tow strap and receiver d-ring, but how exactly do you pull a car out with only those transport tie-down hooks...or nothing? I can't thread the strap through those tiny hooks.
2006 Sport V6
Bought used @ 185k miles
My first T4R, previous XJ owner
01-21-2019, 09:42 AM
Real Name: John
Real Name: John
2004 4Runner V8 Limited - TRD Exhaust, LED Interior Swap, Pioneer HU, Tacoma TRD Front Suspension, FJ Rear Springs, 10" + 32" Light Bars, Prius Shift Knob, 275/65R18 Falken Wildpeak, 18x9 Level 8 MK6 Et0, GOBI Ladder, 06-09 Headlight Swap, TOTALED NOV 2019, RESURRECTED APR 2020 Build Thread
1998 Volvo S70 T5 - Custom Airlift Suspension, BBS Nebula Wheels, Brada Seats, Engine Bolt Ons - StanceWorks Build Thread
2010 Subaru Forester 2.5X - Wifes Car
01-21-2019, 03:29 PM
Thank you, the shackle d-ring makes sense now. Some of those car transport tie down holes are not very big.
2006 Sport V6
01-21-2019, 05:15 PM
Real Name: John
Real Name: John
Yeah, some tow hooks are really small and even a big hook might not fit!
If you haven't already, there's a pretty active Facebook group called Bluegrass 4Runners with a bunch of guys from Louisville/Bowling Green area, just a heads up as I see you're in Louisville!
01-22-2019, 01:52 AM
Thanks, I'll check it out!
2006 Sport V6
01-22-2019, 09:19 PM
If you’re talking about the screw-in “eye bolts” that are often used a 3/4” screw pin shackle will fit. (Obviously you’ll have to insert the pin through the eye as the shackle won’t fit. Many, if not all cars, have shipping transport “keyways” in their frames used for shipping. You can actually buy a set of transport keys to fit these. Don’t be tempted to wrap straps around axles or tie rods or bumpers. And if you are using a tow strap then do just that - tow. Don’t try to snatch a vehicle with a static strap.
01-24-2019, 01:35 PM
Originally Posted by JVC8790
I would tend to agree. I personally run a 22,000 LB rated Shackle.
2019 4Runner TRD Off Road / Bilstein 5100 Lift 2.5 F 1.5 R / TRD Pro Front Skid Plate / BFG KO2's 275/70/17R / Rhino Rack Pioneer SX Roof Rack / N-Fab Nerf Bars / Yellow Lamin-X Fog / ARB 12V Compressor
01-26-2019, 01:27 PM
I actually had a question about using this one my 4runner as a recovery point. Is there any reason that these wouldnt be sufficient if someone had to tow or winch me out of mud?
01-26-2019, 09:43 PM
Winching, maybe if done slowly and not jerked. The openings to connect to these are usually small. Towing, I would use a snatch strap instead of a tow strap since the snatch strap will stretch and wont overload the recovery point.
If you are looking to do some wheeling, you should look at getting some sort of descent recovery points added (front and read). Many aftermarket bumpers have these welded on, but there are also some bolt on recovery points as well that don't require a heavy bumper. For there rear there are a lot of ones that just simply go right into your tow hitch receiver.
Humankind cannot gain anything without first giving something in return. To obtain, something of equal value must be lost.
02-01-2019, 02:09 AM
Real Name: keith and jenny
For the rear, put the loop end of the tow strap in the receiver hitch hole, and put the hitch pin in, through the loop. You can also wrap the strap around the receiver hitch tube. If you want to buy a cool device for the hitch, that's fine, but you don't need to.
02-03-2019, 04:08 PM
Moderator
Real Name: The Chosen One
Moderator
First off, you have to understand there is a big difference between a "tow strap" and a "snatch" or "recovery" strap.
Two different things with different properties.
Make sure you have the proper strap for what you want to do.
Hooking it up is secondary.
'89 4Runner SR5 - stock
02-07-2019, 09:11 AM
Right...some have stretch and elasticty and some do not.
