03-19-2019, 06:54 PM
Trail swapping CV axles?!?
I’ve changed my CV axles more than a few times in the comfort of my driveway and I always think to myself “how the hell do people do this on a trail?!??”
So yeah, how the heck do you manage to do this on a trail?!
2004 Sport Edition V8. 3" OME lift. 5th Gen Brakes. 285/70 Duratracs. JBA UCAs. SCS Ray10s. DT Headers.
1997 4-Runner Limited w/ factory locker. Totaled in February 2018. Still miss it.
03-19-2019, 10:05 PM
Originally Posted by atalarico
I always think to myself “how the hell do people do this on a trail?!??” So yeah, how the heck do you manage to do this on a trail?!
I'd be all ears on this how-to as well.
-- 1997 Tacoma v6 Std Cab
-- 2006 4Runner v8
03-20-2019, 02:55 PM
With tools, and a bottle jack.
Find a level spot and start working.
I've seen guys swap CV's in 30 min's on the trail.
98 Limited, DD with Sway Away coilovers, Camburg uniball uppers, OME 891's w/ Bilstein 5100's in back, 285 BFG, KO2, Factory elocker. custom sliders
97 LX450 is the fun toy
03-20-2019, 03:01 PM
Yup, that. ^^^^^^
The only difference for me compared to working in the driveway would be:
- finding flat ground can be challenging
- needing to use a ground sheet
- using a hi-lift instead of a trolley jack
Other than that, it's pretty much the same thing as doing it at home.
Mark
04 V8 SE, RST Twin stick conversion. 4x4 Labs rear bumper, SW Sliders & Bullbar, ARB Locked F&R, 5.39’s, Smittybilt 10,000lb winch, 1.5 4Crawler BL, Flowmaster, CB and 2m/70cm Ham, Sat. Radio, CO2 system, Lightforce, African Outback Rack, Budbuilt, Front Runner RTT. Rock Solid Toys Solid axles, Atlas Crawl Case, 40" Cooper STT Pro's on Fuel Anza D116 beadlocks, 5:38 gear set, ADS Coilovers.
04-01-2019, 08:55 PM
Yep - it’s like your driveway only dirtie and far from level... wait until you have to skid-out a truck with a busted rear axle (non-floating)!
04-02-2019, 11:35 PM
Ok, I mean I get that the location specifics and using a hi-lift, but do you guys seriously carry every single tool needed?
There’s the huge axle nut socket, handful of other sockets, a torch for me to ever hope to get the lbj bolts off, crow bar to get leverage to get it out of the diff, Allen wrench to loosen and tighten the sway bar link, diff fluid to refill what you lose, one of those seals that goes against the hub, loctite, and a torque wrench to make sure shit doesn’t fall off on your way home. I’m sure I’m forgetting things too.
04-04-2019, 10:27 PM
Real Name: Steve
Real Name: Steve
First, I've never done it on the trails. That being said, with the exception of my breaker bar, torque wrench and "special tool" to help tap out the axle, and of course the axle itself, I can bring everything needed in my tool bag which is probably 12x12X10. The other stuff can easily fit in my drawers or my OEM storage compartment in the trunk.
As for the seals, the new/replacement axle usually has the outer seal already on it, so you don't need to worry about that. If you need to salvage a seal for some reason, then be careful and replace it when you're back in the comfort of your driveway. If you want to, carry an extra bottle of diff fluid, or, since you can now get off the trails, limp your way off the trail to an advanced auto and top it off.
Just my opinion, and the way I see things if I ever have to deal with a broken axle.
'15 Mag Gray LE -- TOTALED | '14 TE wheels - dipped black, Falken AT3W 285/70/17 | SPC Adjustable UCAs | Daystar 2.5/1.5 top spacer lift | RCI Fuel Tank Skid (Steel) | Shrockworks Step Sliders (trimmed LE Rocker Trim) | SR5 front end conversion
'08 BP Urban Runner -- 5100 fronts at .85 with Toytec 620# springs | SPC Adjustable UCAs | Plastics Guy Front Bump Stops | ICON VS 2.0 Rear with Toytec Superflex 2 inch springs | RCI Transition, Front and Transmission Steel Skid | LT275/65/18 Falken Wildpeak A/T3W | 1.25 inch wheels spacers
www.4runnerfamily.com | IG: Runn4est
04-04-2019, 11:30 PM
I have minimal overall experience, but when I go out, I bring a lot of tools. Like a LOT. Deep sockets, shallow, 1/4" 3/8" 1/2", wrenches, and array of pliers, hammer, pry bars, a multimeter for electric diag, electrical connectors and wires, Allen sockets and more. I also bring one front axle, one UBJ, one LBJ, inner TR, outer TR, pitman arm, idler arm (mines a second Gen so a bit different steering), A front brake hose, rear brake hose, universal brake hard line, universal fuel hose 1/4 and 5/16, radiator hose, a heater hose "U" to bypass, belts and bunch of other little stuff. All these things I consider would strand me if they failed. So, I carry an extra of each. Packed right all the parts are in a 20"X10"x10" durable tool box, all hand tools fit in a carry tool bag about 14"x6"x6". Not much space for the value of it.
My point is that it's better to have it and not need it, than need it and not have it. Period. You don't need to do a 1,000,000,000 mile fix on the trail. The point is to finish the trail, limp home or tow it, and then fix it right if need be later on. All that being said, an ounce of prevention is worth a pound of cure. So keep up on your rig, and don't go overboard on abuse on the trail. Be aware. My uncle has off-roaded in an 87 pickup and has never broken an axle. He also knows what to do and what not to do. Challenge yourself? Sure. But be prepared for what the results of the challenge bring.
04-04-2019, 11:38 PM
Interesting stuff. I'm going to have to make a list of socket sizes and other tools I'd need and make an "Oh shit" bag to take. Thanks!
04-15-2019, 02:14 PM
Real Name: roGer
Real Name: roGer
you get two helpful doggos to help
2002 Toyota 4[thedog]Runner Limited BFGoodrich KO2's | Taco whip | Paranoid Fabrications switch panel | full length roof rack | Tundra brakes with SS lines | ARB Awning | ARB compressor and f/r lockers | ToyTec lift (ugh) upgraded to Kings | Total Chaos UCAs | WARN winch | 4xInnovations armors | Method Grids | KC Roof Lights | Lotus Development CV Axles | Whiteline Bushings | Spidertrax spacers | SnoMaster Fridge | ReadyLight | holy shit this adds up fast
Insta: wkendnomad | this is where the adventure begins
04-15-2019, 03:28 PM
Yup, I carry a ton of tools. And a lot of people have appreciated that over the years!
I carry four bags of tools. One is for battery operated tools - impact wrench, drill and an additional tire/mattress inflator. Then
(2) sockets and screwdrivers,
(3) wrenches, vice grips, circlip pliers,
(4) misc tools (including specialized tools, pry bars, hammer, mallet, fuses, electrical wires and plugs, and various sealants/lubricants eg JP Weld...)
Pay to play...
Mark
04-30-2019, 05:00 PM
I actually do have all the tools to change one of those on the trail. And a complete axle in the truck. You just need the big socket (or a pipe wrench if you dont' have the axle nut socket), an axle popper tool and a breaker bar for some 1/2 sockets and a ratchet. And a cross peen hammer- definitely a hammer. I have never gone on a trip and not used my hammer.
I don't think a 4runner will even start without a hammer installed.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
