Real Name: Ron
Real Name: Ron
I would drive it on a minimum 10-20 mile trip at least twice per month, to heat up the oil and get the gear oil splashed around in the gear boxes again. Vehicles deteriorate more when neglected than when used regularly. That will also keep the battery charged and help keep mice/squirrels from taking up residence, etc. Plus, if you do need it in an emergency, you know it'll be ready to go.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
