04-28-2019, 12:00 AM
Faulty ARB EZ Deflator?
Hello All!
I'm need some help determining if my ARB EZ deflator is faulty. I have followed the instructions but can't seem to get an accurate reading. With it screwed on and valve core removed, I can hear/feel air leaking out around the Valve stem handle. Definitely sure its not coming from the slider valve. Also the Valve core handle seems pretty lose/I can wiggle it a bit
Am I doing something wrong here?
Pic below of the components by Trail4Runner
04-29-2019, 02:33 AM
Real Name: Evan
Real Name: Evan
Originally Posted by SpeedyKevin
Hello All!
I use the same one. One thing with these is you need to be pushing forward on the slide valve when screwing onto the valve stem and also while unscrewing the valve core. If this isn’t done and you go to pull the slide valve back to release air, you’ll hear air escaping but it’s not much and this could be what’s happening.
Another mistake could be not removing the valve core all the way. It will still release air but like the slide valve scenario above, it won’t be releasing as much as it should.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
04-29-2019, 03:10 PM
Darn I tried this and its still letting out air/Not getting an accurate reading Time for an exchange!
Thanks for the suggestion!
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
04-29-2019, 04:02 PM
Your close,
Once threaded onto the valve stem, push #4 all the way forward until it stops. Turn the #4 valve core handle left while still pushing forward. You need the teeth of #4 to bite the valve core, you'll feel a click some times. Then keep turning left, more times then you think. Pull back on #4 to let air out, push into get pressure reading. Like I said keep turning left, it's sometimes more turns then you think- you'll know when you got the core out when you pull back as it will let out a big blast, not leak.
04-30-2019, 12:47 PM
Originally Posted by Teamoatmealpie
Your close,
Alright so I tried doing this and got a much better reading. However, I can still hear air releasing for quite some time. is this normal?
