Old 06-07-2019, 02:04 PM #16
Pathfinder5243's Avatar
Pathfinder5243 Pathfinder5243 is offline
Pathfinder5243 is on a distinguished road
Originally Posted by Jazz30-06 View Post
2H or 4H unlocked
Defender LTXs
What recall? I have my VIN registered on Toyota's owner site, but it shows no recalls active for my VIN.
Depending on the pressure you're running in the tires and that they're street tires will make you slide more off road. I have similar issues with the VCS turned on. Make sure it's off and you shouldn't have this issue.
If you don't have an open recall then it's already been done. They updated the software to kill power if the brake is applied. Keeping you from being able to use them at the same time.
06' T4R 4.0 LTD 4X4
Pathfinder5243 is offline   Reply With QuoteReply With Quote
Old 06-07-2019, 02:53 PM #17
Jazz30-06 Jazz30-06 is offline
Jazz30-06 is on a distinguished road
I was on dry dirt. Once I was able to use my brakes again, it stopped instantly.
I'll probably stop at a dealer to check for the recall. It was originally a Canadian vehicle, so things might be weird in their system.
Jazz30-06 is offline   Reply With QuoteReply With Quote
Old 06-07-2019, 03:14 PM #18
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
The first was that when I had tires spinning in snow and tried to brake them to avoid creating ice, the ABS kicked in and wouldn't let me use the brakes. So, the tires just kept spinning and created the ice anyways. I justified this one as "tires are all spinning at a different rate, so OK, I guess".
The second was actually at very low speeds in uneven terrain. I was parking behind someone and when I tried to stop (at like 2 mph) the ABS kicked in again and locked me out of my brakes. I almost hit the guy because of this and it greatly concerns me that this is an issue if I ever find myself on a hill and this system kicks in.
In your first example, I'm wondering if traction control activated at the same time you applied the brakes, purely coincidentally. As you know, atrac is ABS based and only kicks in when the wheel(s) start spinning. Perhaps your brain and the 4runner brain came to the same conclusion simultaneously?
In your second example, it sounds similar to something I experienced last year, but I was driving at about 40mph instead. In my case, a wheel speed sensor (elcheapo ebay one) failed and was sending false readings to the computer. With abs kicking in and me trying brake, I got pretty much no braking at all. After it happenned a few times, the check engine light came on with ABS error codes. If you have the same thing happen again and you have access to a code reader that read ABS codes, it would be worth looking for a pending code.
techno is offline   Reply With QuoteReply With Quote
Old 06-07-2019, 03:31 PM #19
The first example happened multiple times in a row, so I don't know that that could be considered a coincidence.
As far as a scanner, any idea if that is something that can be picked up via techstream? I don't have a cable right now, but I'd rather buy the cable than hand the stealership $80 to do the same thing.
Old 06-11-2019, 12:39 PM #20
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
2H or 4H unlocked
Defender LTXs
Even if I don't really need to be, I always drive with the center locked when off-road because it disables or changes various systems to assist in driving off-road.
You should toggle between the two and test off-road because for me it makes a huge difference.
Old 06-29-2019, 03:19 PM #21
So, there is something wrong with the brake assist pump. I haven't really had a computer for the last few weeks, so that's why I've been AWOL from this thread, sorry guys.
I got the codes that the system was throwing w/o a check engine light:
C1223
C1256
From what I have been able to find, that eludes to a major issue with the assist pump. It sounds like it can be anything and Toyota doesn't sell small parts, only the complete unit for ~$2500
So, I have to figure out what I am going to do.
abs , atrac , ice , spinning , tires
anyone in nor cal wanna hit slick rock rich dog Off-Roading 0 11-09-2018 01:30 AM
Slick Rock rochmpr Nor Cal 14 10-10-2018 09:09 AM
slick rock anyone? ConstantFix 3rd gen T4Rs 9 03-09-2014 03:10 PM
Too Slick For VSC jpalaska 4th Gen T4Rs 16 01-15-2009 05:32 PM
Slick 50 2003_4Runner Maintenance/Detailing 5 02-13-2006 12:47 PM
