Old 07-03-2019, 11:52 AM #1
Ripper238's Avatar
Ripper238 is on a distinguished road
Ripper238's Avatar
4H/4L - A-trac/crawl control & Multi-terrain settings?
So from my understanding A-trac, crawl control & Multi-terrain settings are only to be used in 4L. The only setting that can be used on 4H is the Multi-terrain setting for sand and mud. Is this correct?
So if Multi-terrain setting for sand and mud can be used in 4H when would it be okay to engage Multi-terrain setting for sand and mud? Max recommended speeds to use and engage it?
Thinking of snow driving and on the highway.
Old 07-03-2019, 05:21 PM #2
Stephencovar Stephencovar is offline
Stephencovar will become famous soon enough
Check this video out, it really helped me understand all of the controls and when to use what.
YouTube
Stephencovar is offline   Reply With QuoteReply With Quote
Old 07-03-2019, 10:40 PM #3
Ripper238's Avatar
Ripper238's Avatar
YouTube
Excellent video!
Then hopefully somebody can give me more detail for Multi-terrain setting for sand and mud. So far it seems it can be activated up to 50 miles an hour. I just don't know whether that's ideal, or if it could be used for higher speeds than that? LOL
Sent from my SM-N960U using Tapatalk
Old 07-04-2019, 09:09 AM #4
Check out this blog post, towards the bottom. This also helped me understand the different modes.
5th Gen 4Runner Off-Road Features, 4Runner Off-Road Settings Guide
Old 07-08-2019, 11:19 PM #5
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R is a jewel in the rough MAST4R is a jewel in the rough MAST4R is a jewel in the rough
MAST4R's Avatar
Originally Posted by Ripper238 View Post
Excellent video!
No, it can only be activated while stopped or barely rolling. However, it can be canceled at any time.
It is a great idea that they made it available in 4H.
Old 07-09-2019, 07:36 AM #6
Ripper238's Avatar
Ripper238's Avatar
Thank you this is really helpful. I'll need it for when there's heavy snow so I'll just make sure to activate it for my ride home from work rather than mid-trip. hopefully it's not an issue leaving it on for a 45 minute to an hour ride. LOL
Old 07-09-2019, 10:29 AM #7
MAST4R's Avatar
MAST4R's Avatar
I am pretty sure it can be used indefinitely in 4wd, just as road traction control is always on in 2wd. The difference is that if you turn the engine off, it turns off.
I find it more effective than A-trac in rock and loose terrain (when not using the rear diff at all) but I have not really seen the kind of mud or snow that would test it. I am sure it will perform admirably.
Old 07-09-2019, 10:50 AM #8
Ripper238's Avatar
Ripper238's Avatar
So to clarify: I can specifically use only the Multi-terrain setting (first setting) for sand and mud in 4H indefinitely (The rest i know is for 4L exclusively). But to engage the sand/mud setting i must be at a stop.
engage , mud , multi-terrain , sand , setting
A-Trac vs. Multi-Terrain Select Narkhelek 5th gen T4Rs 18 04-27-2018 08:19 AM
Multi Terrain Select (Crawl Control) Demo lmturne1 5th gen T4Rs 23 01-13-2016 11:15 AM
Crawl control/Multi Terrain Select BrockT 5th gen T4Rs 0 10-27-2010 02:25 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
