Real Name: Ron
Real Name: Ron
My 2.0cfm VIAIR 400C is fused for 30 amps, so probably takes about 25. That's around 325 watts from a 13V system. So, a 400 watt inverter should power something similar. The question would be, can you find a 120VAC compressor that is only 2CFM? Most of the small ones are usually 4 CFM or so, and probably take 10 amps at 120VAC, or about 1200 watts. Your inverter won't be able to power that.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
