Old 07-24-2019, 06:56 PM #1
Johncmng Johncmng is offline
Johncmng is on a distinguished road
Is there a common GMRS channel that you guys use when on the trails?
It would be nice to see if anyone can help out in the area if need be.
Johncmng is offline   Reply With QuoteReply With Quote
Old 07-24-2019, 08:04 PM #2
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Negative... I don't think there is a common or standardized channel for such a thing. It's really more about what you decide to establish to use with the group of people you are wheeling with.
There are also different power levels associated with channels.
General Mobile Radio Service - Wikipedia
Old 07-26-2019, 10:27 AM #3
Ripper238's Avatar
Ripper238's Avatar
Ideally the higher numbers if you get a good GMRS radio (4 watt+). Less likely you will get kids cross talk.
Old 08-17-2019, 07:33 AM #4
tx_shooter's Avatar
tx_shooter tx_shooter is offline
tx_shooter will become famous soon enough
tx_shooter's Avatar
This ^^
Last big trip I did we specifically used the higher channels because they would offer less cross talk with other people. I am not sure if there is enough of a GMRS network built up to really use one for emergency communications. I usually look up any repeaters in the area I am going to and try to keep that in my notes for the trip. Repeaters mean traffic and better odds of reaching someone.
tx_shooter is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 01:50 AM #5
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
Speaking of gmrs radios what's everyone's opinion about this model. Just need something portable to swap in and out of rigs if I happen to swap rides or jump on a buddies
MXT275 MicroMobile(R) Two-Way Radio | Midland USA
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 07:57 AM #6
GreenMountainOwl GreenMountainOwl is offline
GreenMountainOwl is on a distinguished road
For the same amount of money, get a slightly used Kenwood or Icom and programming software. Program it anywhere you go, 256 channel versions are easily affordable, and get something P25 capable if you want.
Those Midlands can’t be end user programmed. And from what I hear, RX is narrow while TX is “old school” wide, so older wide repeaters (probably most repeaters on the air today) will sound like crap. Think I read that on QRZ but could have been Radio Reference.
GreenMountainOwl is offline   Reply With QuoteReply With Quote
Old 08-30-2019, 01:25 PM #7
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
technically you shouldn't be using those on GMRS frequencies
jhguth is offline   Reply With QuoteReply With Quote
Old 08-30-2019, 01:31 PM #8
Which, the Midland MXT series? Those are Part 95 certified.
Old 08-30-2019, 02:17 PM #9
Akkording's Avatar
Akkording's Avatar
It's ok if you purchase a license from my understanding
Old 08-30-2019, 02:21 PM #10
any of the programmable Ham radios, you're not supposed to be using those on GMRS. if you're going to anyways, at least reduce your power.
^not for the ham radios
Old 09-01-2019, 03:23 AM #11
Kamalani Mahie's Avatar
Kamalani Mahie Kamalani Mahie is offline
Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough
No common channel. Just establish a channel with your group beforehand. In general stick with the higher channels though in my experience. But I've used lower channels with no issues as well. Just really depends on who is on what channels in your area.
Originally Posted by RysiuM View Post
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
Kamalani Mahie is offline   Reply With QuoteReply With Quote
Old 09-05-2019, 12:30 PM #12
Bumbo's Avatar
Bumbo's Avatar
I’m pretty big on radio gear… I am a licensed HAM and have mobile and handheld radios in the truck and have over 10+ years of experience with this stuff. HAM radio is literally the pinnacle of radio coms for the general populace. I’ve talked around the world with the equipment, and it’s amazing how much capability the FCC allows us. You can talk directly to the international space station with one just as an example.
I’ve used it for hobby, safety, emergency preparedness, long range and short range group communications, but it doesn’t come without challenges. Primary licensing and being familiar with your equipment and maintaining proficiency. Understanding frequency, tone, shift, and how to use and program it into your radios as you travel is also pretty important. Unless you are wheeling with a group of nerds, chances are most won’t be licensed. It’s the best radio tool for emergencies, but I rarely use it for car to car communications because most of my friends are not licensed.
MURS (Multi-Use Radio Service) - I feel this is a lot better than GMRS. This is free and unlicensed, you can run more power with external antennas, and is very easy to use because once a radio is programed there is nothing else to do but use it. I carry a few of them in a Pelican case which I give out to others who I wheel with if they don’t have one. Perfect for talking on the trail, but crap for emergency use just like FRS and GMRS.
I still carry a HAM radio for emergency, but someone still needs to be on the other end of it to help. I also think in a true emergency I need absolute reliability. These days I carry a satellite communicator as a budget option to a sat phone. As much as I like radio, I absolutely LOVE this thing and feel it’s worth every penny. If you wheel outside of cell coverage, I really don’t think there is a better tool. What I like about it the most is that you can use it as a satellite modem and though the Garmin app, just text people from your smartphone. Friends or family can also track you live and keeps tabs on you too if you allow it. It also has an SOS button, which puts you in contact with GEOS (Emergency Response Coordination Center). Plus for $18/year extra, that includes $100k of search and rescue coverage. All your GPS data is automatically sent on all communications too.
Garmin inreach mini 2-way satellite communicator
(Global Coverage via Iridium satellite constellation)
Old 09-06-2019, 01:10 PM #13
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
Except for the ham part (still working on getting licensed - just gotta get around to taking the exam), I'm with Bumbo. MURS for vehicle-vehicle comms on the trail, and Inreach for back-home communication and for emergencies.
I was even able to use the Inreach to make campground reservations at Needles Outpost when our plans changed within the Elephant Hill backcountry area of Canyonlands NP in Utah. A couple of text messages and we were all set.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 09-06-2019, 02:35 PM #14
Bumbo's Avatar
Bumbo's Avatar
In case anyone wants to know… here is some data on MURS along with frequency and radio options.
Multi-Use Radio Service - Wikipedia
Multi-Use Radio Service (MURS) | Federal Communications Commission
I have a couple old commercial Motorola radios, but these are about as cheap/easy as you can find for type accepted equipment.
https://www.amazon.com/dp/B075VBP9YG..._JrQCDb4KFQZV8
That said, a ton of people do use ham equipment, even though technically it’s illegal to do so. So don't do it.
MURS
151.820 MHz (11.25 kHz)
151.880 MHz (11.25 kHz)
151.940 MHz (11.25 kHz)
154.570 MHz (20.00 kHz)
154.600 MHz (20.00 kHz)
Old 01-08-2020, 03:07 PM #15
Milhaus Milhaus is offline
Milhaus is on a distinguished road
Can you tune a handheld Aviation radio like the Yaesu FTA-550AA NAV/COM Aviation Radio to the GMRS and/or MURS frequencies?
Milhaus is offline   Reply With QuoteReply With Quote
area , channel , guys , nice , trails
Mounting GMRS and CB Aznisegi 5th gen T4Rs 9 01-10-2021 12:44 PM
GMRS vs CB and whats the protocol to connect? wlfmachine 3rd gen T4Rs 0 12-05-2018 11:45 AM
FRS vs GMRS radio Expat 4th Gen T4Rs 5 01-16-2005 05:26 PM
GMRS radios. dcampen Off-Roading 3 09-15-2004 12:33 AM
