Old 08-24-2019, 06:15 PM #1
calimero calimero is offline
calimero is on a distinguished road
Recovery gear brand recommendation
Hi all,
I am looking for the usual recovery gear:
- D-ring shackles
- snatch block
- tree saver
- winch damper.
Would any of you have a recommendation for a good US brand that has served them well?
I have found by browsing online GearAmerica but have no idea if it is any good (seems so).
Thanks
Eric
calimero is offline   Reply With QuoteReply With Quote
Old 08-25-2019, 02:26 AM #2
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Originally Posted by calimero View Post
Hi all,
- D-ring shackles
- snatch block
- tree saver
- winch damper.
Thanks
Eric
They wont have everything you're looking for but check out Treaty Oak Offroad
Treaty Oak Offroad — Recovery Gear
I have their Kinetic rope and winch extension and have been very pleased with them!
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 08-25-2019, 04:50 PM #3
Thanks Kevin,
Checking them out
Old 08-26-2019, 11:28 AM #4
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
Brands that I've had no problems with for recovery stuff are ARB, Warn and Pro-Comp and Smittybilt. ARB are Australian and I'm pretty sure the others are all owned by the same US company but I have no idea where their stuff is manufactured.
techno is offline   Reply With QuoteReply With Quote
Old 01-21-2020, 10:45 AM #5
dade73 dade73 is offline
dade73 will become famous soon enough
Hi all,
- D-ring shackles
- snatch block
- tree saver
- winch damper.
Thanks
Eric
Your budget will probably be the biggest determining factor on this.
Good rule of thumb: working load be at least 1.5x the weight of your vehicle (loaded and trailer include if hauling a trailer). ARB probably one of the most reliable on the market but are Australian based company. I pieced mine together. Also look at local FB market (local clubs that have a fb page also have a market page).
D-ring shackles:
I have: GearAmerica 4.75T 3/4" (Currently looking for soft)
Most any will work but ensure they are marked for proper working load and proper size for weight. If they are not marked and no documentation on the working load and breaking load limits DO NOT BUY.
If budget isn't much of an issue, then I would look into soft shackles - less weight more strength, safer if in the event of equipment failure.
Snatch block:
I have: Orcish 10T work load
There are many options out there not just for cars, but also marine grade. Choose based on if for synthetic rope or steel cable. Verify correct diameter for your rope/cable.
Tree savers:
I have: ARB treesaver (bought used from someone getting out of wheeling)
Again brand not a huge thing if there is documentation to working load limit and breaking load limit. Don't limit your search to tree saver - marine slings will also work (verify vertical hitch capacity if choosing this route)
Winch dampener:
I have: used firehose
Most any weighted vest or dampener will do (preferably 2 - one at 25% distance the other at 75% distance). Used firehose is a good option (also great for covering sharp edges to reduce abrasion).
I would also look for a snatch strap. I currently have an ARB (again used from someone getting out of wheeling). This I would stick to ARB or Smittybilt or Bubbarope.
*** Warning *** Some will advertise or labeled as a snatch strap but will actually be a tow strap that has 0 kinetics built into it (requirement for snatch strap)
Also good set of working gloves, tire puncture kit, valve stem kit (had to use this weekend) https://www.amazon.com/dp/B0722WR8TV...ing=UTF8&psc=1
traction boards: I have Boaroffroad (orcish/ Xbulls). maxtraxx are great stack smaller then mine.
Shovel and axe as well. I bought a combo kit, so far not issues. https://www.amazon.com/LIANTRAL-Surv...dp/B07P1S9L9G/
Humankind cannot gain anything without first giving something in return. To obtain, something of equal value must be lost.
dade73 is offline   Reply With QuoteReply With Quote
Old 01-26-2020, 08:38 PM #6
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
Shackles: Crosby
Straps: I'd strongly consider a kinetic rope from Yankum for recovery. Tow straps are generally less useful but if you have the room and budget, Factor 55 makes good ones. If you only have money or room for one, definitely go with the kinetic rope.
Tree saver: Warn makes one
Snatch block: Warn makes a nice one
Winch line damper: Whatever weighted piece of fabric you have on hand. A jacket, a piece of firehose as mentioned above etc. This is also less important if using synthetic line as it typically just lays down if it snaps but still not a bad idea.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 02:56 PM #7
slider76 slider76 is offline
slider76 is on a distinguished road
Ronnie Dahl has a couple videos that are eye opening in terms of application and why it’s important to follow best practices. If I recall, dampers do next to nothing in case of a catastrophic failure. I believe he was using cable as opposed to synthetic line.
2018 SR5 Premium, LFD steel crossbars on OEM side rails, Shrockworks sliders, Ironman 4x4 Foam Cell Pro Stage 3, Morimoto XB headlights, Baja Designs Squadron Pros (driving/combo) on Rago ditch light mounts
slider76 is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 11:09 PM #8
revox92's Avatar
revox92 revox92 is offline
revox92 is on a distinguished road
revox92's Avatar
Been using Smittybilt stuff without any issue.
2004 Toyota 4Runner SR5 4WD Auto
revox92 is offline   Reply With QuoteReply With Quote
Old 05-13-2021, 09:13 PM #9
AMLOR AMLOR is online now
Real Name: Kirk
AMLOR has a spectacular aura about AMLOR has a spectacular aura about
Real Name: Kirk
Currently using Factor 55, BubbaRope, Gator Jaw, and Overland Vehicle systems.
HOWEVER, the only two STEEL shackles I can recommend are either:
Crosby or Van Beest. I have a family member who works for a company who sells equipment to Offshore Oil rigs in the Gulf. The ONLY shackles they sell are Crosby (lighter duty) or Van Beest up to 175 tons WLL.
Crosby, mostly American made or Van Beest, made in the Netherlands.
All of their shackles (both companies) can be ordered with the copies of the testing paperwork, engineering ratings etc., that back up the listed WLL.
Try that with Chinese or Amazon stuff.
I only use Van Beest shackles.
AMLOR
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
AMLOR is online now   Reply With QuoteReply With Quote
Old 05-14-2021, 11:04 AM #10
onspithr onspithr is offline
onspithr is on a distinguished road
Smittybilt is highly recommended.
onspithr is offline   Reply With QuoteReply With Quote
Old 05-14-2021, 02:31 PM #11
Seattle206's Avatar
Seattle206 Seattle206 is offline
Seattle206 is just really nice Seattle206 is just really nice Seattle206 is just really nice Seattle206 is just really nice Seattle206 is just really nice
Seattle206's Avatar
All my recovery gear is from Bubba Rope, Factor 55, ASR Offroad, ARB, Hi-Lift, and I have a Smittybilt X2O 10k Synthetic winch. I have a couple USA made D-ring shackles I got off eBay but I stick with soft shackles for everything.
As long as you buy from a brand name you are good to go. Everything I have has done it's job well so far.
Seattle206 is offline   Reply With QuoteReply With Quote
brand , gear , good , recommendation , recovery
Got Recovery Gear? Wheeler's Off-Road, Inc. Wheeler's Off-Road 0 01-10-2018 01:32 PM
Recovery Gear YotaDan Wheeler's Off-Road 10 02-13-2017 06:26 PM
Recovery gear ricktcole Engines / Suspension / Wheels / Tires / Audio / Accessories 2 06-20-2011 06:05 PM
Recovery Gear? Nashvillerunner 4th Gen T4Rs 9 03-18-2011 11:06 AM
