Old 10-27-2019, 01:58 PM #1
rockwind1 rockwind1 is offline
rockwind1 is on a distinguished road
dust getting in, normal?
been doing a lot of off roading in nevada last few weeks, the roads are super dry and full of that super powdery poofy dust. it's getting in somehow and all over the inside of my rear door. i can smell it sometimes when i driving very fast on a powdery road, like 40-60 mph.
anyone else have this problem?
is it a known problem? any fixes for it?
2016 4runner trail KDSS, 3" icon lift w/ uca's, Icon rims, cooper discoverer at3 E rated, 10k smitty winch, heftyfab alum front bumper, heftyfab sliders, frontrunner roof rack, ARQ awning, LED lights everywhere, home made magnetic paint protectors, bunch of recovery gear i never use, a mentally disabled driver, big stupid tires and a million gallon gas tank cause it's a 4runner
rockwind1 is offline   Reply With QuoteReply With Quote
Old 10-27-2019, 02:20 PM #2
Jarheadoo7's Avatar
Jarheadoo7 Jarheadoo7 is offline
Jarheadoo7 will become famous soon enough
Jarheadoo7's Avatar
Itís a car not a Hyperbaric chamber. Dust will get in eventually when you drive a lot of dusty roads. Unless you have piles of dust like if you left a window down, the only think you can do is keep a few rags in the door pockets to wipe things down. Check your cabin filter often 👍🏻
Jarheadoo7 is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 12:51 AM #3
Teamoatmealpie's Avatar
Teamoatmealpie Teamoatmealpie is offline
Teamoatmealpie will become famous soon enough
2 things
1. you can adjust the latch tension on the rear door, which is the common culprit for dust getting in.
2. You can also run you heat/AC fan on high, this will slightly pressurize the cabin, and keep the dust seep from getting in.
I always seem to slow down with the my windows down and stop then the cloud catches up..... I try to learn and not do this, roll up windows before I stop.
2003-SR5 V8 TRD Supercharger - 2016 SR5RR- 1998 454 Chevy Express 15 Passenger Van 4x4 Conversion
Teamoatmealpie is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 12:36 PM #4
Originally Posted by Teamoatmealpie View Post
2 things
interesting on the latch tension, i will check that out. thanks
Old 10-28-2019, 02:21 PM #5
actually, i paid extra for the hyperbaric option so,,,,,don't think I should be getting dust
Old 11-06-2019, 11:04 AM #6
Akkording's Avatar
Akkording Akkording is offline
Akkording has a spectacular aura about Akkording has a spectacular aura about Akkording has a spectacular aura about
Akkording's Avatar
Would the door seal mod help a little?
https://www.toyota-4runner.org/5th-gen-t4rs/271995-my-$45-door-seal-mod.html
2012 SR5 | 285 Toyo OC ATII | Level 8 Slam | PC | X2Power w/ArcLightLeds V2 Booster | Borla 40665 | URD Y pipe & Maf Cal TRD tune | C4 Center LP | X20 10k Factor55 | Shrockworks sliders/skids/Bussmann RTMR mount | RCI LCA skids | LFD Offroad 7/8 Gobbi Ladder | TJM Airtec dry aFe HPS coupler w/TRD cai tube | 6112 7/5 clip w/650# King | ICON Delta Joint | 5160 | SAW 1.5" w/Dobinsons 15mm trim packs | .5" Headstrong top plate |
| 03 Tacoma OME equipped, 288k |
| Restoring 02 Tacoma, 230k |
Akkording is offline   Reply With QuoteReply With Quote
Old 11-06-2019, 02:40 PM #7
techno's Avatar
techno techno is offline
techno will become famous soon enough techno will become famous soon enough
techno's Avatar
Your hyperbaric option is probably working just fine. You will find that when driving, dust accumulates around the door seals, then when you stop and open a door the seals flex and air movement disturbs the dust layers causing faint clouds to enter the cabin. In Australia we call it bulldust, and not matter what you do, it's getting inside.
I got a 2000 and a 2008 SR5 4x4.
techno is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 05:23 PM #8
Cranberry's Avatar
Cranberry Cranberry is offline
Cranberry is on a distinguished road
Cranberry's Avatar
Have to admit, its an off road vehicle... lol I think dust wasn't really a big concern at the time of its design, but that being said I also know its been a little much on occasion. I personally found a lot of the dust was coming in through the rear cargo hatch. so much so that the fabric pull down cable for the hatch would turn yellow from all they sand and dust coming in through the little hook it attaches to.
I just ended up making a decent clean job after each trip. Just a part of the vehicle I guess
2019 4Runner TRD Off Road / Bilstein 5100 Lift 2.5 F 1.5 R / TRD Pro Front Skid Plate / BFG KO2's 275/70/17R / Rhino Rack Pioneer SX Roof Rack / N-Fab Nerf Bars / Yellow Lamin-X Fog / ARB 12V Compressor
Cranberry is offline   Reply With QuoteReply With Quote
driving , dust , powdery , problem , super
Dust Sealing TheRandyMan 3rd gen T4Rs 11 06-09-2018 09:40 PM
Dust!!! namsag General Discussions 3 06-12-2015 07:31 AM
Another one bites the dust! :( Awz Classic T4Rs 7 01-02-2014 12:31 AM
Dust! cliwel 5th gen T4Rs 29 12-01-2011 10:02 PM
Brake dust - this much normal? T4R_Finally 5th gen T4Rs 8 03-02-2011 12:52 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
