Old 10-27-2019, 01:58 PM #1
rockwind1 rockwind1 is offline
rockwind1 is on a distinguished road
dust getting in, normal?
been doing a lot of off roading in nevada last few weeks, the roads are super dry and full of that super powdery poofy dust. it's getting in somehow and all over the inside of my rear door. i can smell it sometimes when i driving very fast on a powdery road, like 40-60 mph.
anyone else have this problem?
is it a known problem? any fixes for it?
2016 4runner trail KDSS, 3" icon lift w/ uca's, Icon rims, Falkens E rated, 10k smitty winch, heftyfab alum front bumper, heftyfab sliders, frontrunner roof rack, ARQ awning, LED lights everywhere, home made magnetic paint protectors, bunch of recovery gear i never use, a mentally disabled driver, big stupid tires and a million gallon gas tank cause it's a 4runner
rockwind1 is offline   Reply With QuoteReply With Quote
Old 10-27-2019, 02:20 PM #2
Jarheadoo7's Avatar
Jarheadoo7 Jarheadoo7 is offline
Jarheadoo7 will become famous soon enough
Jarheadoo7's Avatar
It’s a car not a Hyperbaric chamber. Dust will get in eventually when you drive a lot of dusty roads. Unless you have piles of dust like if you left a window down, the only think you can do is keep a few rags in the door pockets to wipe things down. Check your cabin filter often 👍🏻
Jarheadoo7 is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 12:51 AM #3
Teamoatmealpie's Avatar
Teamoatmealpie Teamoatmealpie is offline
Teamoatmealpie has a spectacular aura about Teamoatmealpie has a spectacular aura about
2 things
1. you can adjust the latch tension on the rear door, which is the common culprit for dust getting in.
2. You can also run you heat/AC fan on high, this will slightly pressurize the cabin, and keep the dust seep from getting in.
I always seem to slow down with the my windows down and stop then the cloud catches up..... I try to learn and not do this, roll up windows before I stop.
Teamoatmealpie is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 12:36 PM #4
Originally Posted by Teamoatmealpie View Post
2 things
interesting on the latch tension, i will check that out. thanks
Old 10-28-2019, 02:21 PM #5
actually, i paid extra for the hyperbaric option so,,,,,don't think I should be getting dust
Old 11-06-2019, 11:04 AM #6
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
Would the door seal mod help a little?
https://www.toyota-4runner.org/5th-gen-t4rs/271995-my-$45-door-seal-mod.html
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 11-06-2019, 02:40 PM #7
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
Your hyperbaric option is probably working just fine. You will find that when driving, dust accumulates around the door seals, then when you stop and open a door the seals flex and air movement disturbs the dust layers causing faint clouds to enter the cabin. In Australia we call it bulldust, and not matter what you do, it's getting inside.
techno is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 05:23 PM #8
Cranberry's Avatar
Cranberry Cranberry is offline
Cranberry is on a distinguished road
Cranberry's Avatar
Have to admit, its an off road vehicle... lol I think dust wasn't really a big concern at the time of its design, but that being said I also know its been a little much on occasion. I personally found a lot of the dust was coming in through the rear cargo hatch. so much so that the fabric pull down cable for the hatch would turn yellow from all they sand and dust coming in through the little hook it attaches to.
I just ended up making a decent clean job after each trip. Just a part of the vehicle I guess
2019 4Runner TRD Off Road / Bilstein 5100 Lift 2.5 F 1.5 R / TRD Pro Front Skid Plate / BFG KO2's 275/70/17R / Rhino Rack Pioneer SX Roof Rack / N-Fab Nerf Bars / Yellow Lamin-X Fog / ARB 12V Compressor
Cranberry is offline   Reply With QuoteReply With Quote
Old 12-19-2019, 12:47 AM #9
DAW89446's Avatar
DAW89446 DAW89446 is offline
Real Name: Dave
DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light
DAW89446's Avatar
Real Name: Dave
Being a boxy shape, vacuum allows dust to be sucked up and held against the body. The 5th Gen 4Runners hatch door design allows a substantial amount of dust and dirt to build up on top of the bumper and kept in place until it gets washed or swept out. My ‘18 Runner doesn’t allow dust inside ... yet. I imagine as the seal wears it will soon creep in, given the depth and amount of dust that gets sucked in under the door and held in place, even after ten miles of maintained dirt road driving. And where I live, that ten miles is just to visit the neighbor ...
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
DAW89446 is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 12:00 PM #10
i checked that out, i think it is all coming in thru the rear door,,,, appears to just be an ill fitting rear door at this point.
apologies to other posters for not thanking them for their posts,
driving , dust , powdery , problem , super
Dust Sealing TheRandyMan 3rd gen T4Rs 16 07-05-2021 12:25 AM
Dust!!! namsag General Discussions 3 06-12-2015 07:31 AM
Another one bites the dust! :( Awz Classic T4Rs 7 01-02-2014 12:31 AM
Dust! cliwel 5th gen T4Rs 29 12-01-2011 10:02 PM
Brake dust - this much normal? T4R_Finally 5th gen T4Rs 8 03-02-2011 12:52 PM
