Home Menu
Site Navigation
User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 01-08-2020, 08:00 PM #1
Bumbo's Avatar
Bumbo Bumbo is offline
Senior Member
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Senior Member
Bumbo's Avatar
Recovery Gear Refresh - Does my tow strap expire?
I was going through my recovery gear and noticed some of it is quite old (4-7 years)… some used, some new.
Thinking of items like helmets, first aid kits, or even various chemicals like the green tire slime… I know things can either expire or degrade overtime, especially with heat cycles when it just sit in the car 24/7. As an example items like helmets have a recommended service life regardless of how good a condition it’s in. I am replacing almost all chemical and rubber items because I know those can degrade… tire slime, patch kits, air lines and hoses, spare belt.
Would you replace your tow straps on age alone? Does the materials degrade in any way or become brittle which would limit its effectiveness or safety in a hard pull. Really bad things can happen when a winch or strap cable breaks. I don’t mind replacing them, but I also don’t want to toss something if it’s perfectly good.
Bumbo is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 11:02 AM #2
pDubs's Avatar
pDubs pDubs is offline
Member
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
Member
pDubs's Avatar
Eh, my vote is a strap will last a few decades as long as there are no abrasions/fraying anywhere.
If it were left out in the sun and discolored/faded I would be worried... but stored away in the vehicle, I see no problem and wouldn't worry about that.
__________________
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 11:36 AM #3
Iffykid Iffykid is offline
Member
Iffykid is on a distinguished road
Member
I believe abrasion and UV light would be my biggest concerns.
Iffykid is offline   Reply With QuoteReply With Quote
Old 01-13-2020, 02:09 PM #4
Bumbo's Avatar
Senior Member
Senior Member
Bumbo's Avatar
Aside from being a bit sandy, they have been pretty well taken care of. Stored out of direct sunlight and no damage / frayed bits.
Thanks, I will continue to use them.
Old 01-16-2020, 10:59 PM #5
derbytown derbytown is offline
Junior Member
derbytown is on a distinguished road
Junior Member
moisture and light kill everything quicker
derbytown is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 03:53 PM #6
dade73 dade73 is offline
Member
Real Name: Mike
dade73 will become famous soon enough
Member
Real Name: Mike
If you have discoloration, frays, or melting (stretching). Also if it has been used extensively. Then replace it.
If it doesn't have any of those like other have stated and not stored in the sun then it should be good.
I keep all my recovery gear in a ridged box, so its out of moisture and sunlight.
__________________
Humankind cannot gain anything without first giving something in return. To obtain, something of equal value must be lost.
dade73 is offline   Reply With QuoteReply With Quote
Reply
Tags
don’t , helmets , items , kits , recovery
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Tow strap/Recovery strap?? piccrazy30 4th Gen T4Rs 35 12-04-2013 01:21 AM
recovery strap gbc 4th Gen T4Rs 12 07-26-2011 04:22 PM
Recovery strap questions vthokie 3rd gen T4Rs 12 01-23-2011 03:23 AM
Towing with a recovery strap Spencer 3rd gen T4Rs 1 05-27-2010 12:06 PM
How do you attach a recovery strap to a 4th Gen? Dansnare 4th Gen T4Rs 9 09-01-2006 09:32 PM
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Copyright © 2020
