Old 01-17-2020, 05:32 PM #16
spartacus's Avatar
spartacus's Avatar
Start with a full tank of gas good maps gaia gps app, tire repair kit air compressor for tires',survival bag, blanket, recovery strap a good come along and you'are all set. Forest service roads etc you'll be fine without any of that stuff but it's good insurance Get out there enjoy God's green earth. Its a 4runner, 'Keep it wild".
Old 02-19-2020, 01:52 AM #17
Toxicity927 Toxicity927 is offline
Toxicity927 is on a distinguished road
X2 on what Bumbo said.
I have a lot of the “cool” stuff. What do I use the most? First aid kit, basic tools, a bottle jack (that will work with your lift), Jumper cables/pack, tire inflator, 5gal of water, tire repair.
After that stuff, Go to a good hardware store and get some good D-rings/shackles get a good tow strap/kinetic rope and make sure you have tow points on your truck. You can save a lot of money piecing together your own recovery kit.
Hi Lifts are a great tool. They can be dangerous but if you use/practice with it and understand how it works you should be ok.
Save the money and get a Garmin InReach or similar. They can really be a lifeline if needed.
Toxicity927 is offline   Reply With QuoteReply With Quote
Old 02-19-2020, 03:56 AM #18
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
I'm in rural AZ. I occasionally do easy trails as not many have weekdays off like me.
My first purchase was/is water. I rotate the bottles regularly as the plastic does wear rubbing against each other.
Then I bought recovery and tow straps. Then treesavers to spread the load. Had just the hitch in back and tie down loops in front. Better than nothing. Also got some bow shackles.
Next was proper front recovery points. Next will be rear recovery points.
Currently no plan for a high lift jack, no appropriate spots. Bottle jack(s) for now and maybe a bellows jack later.
Winch down the road. No trees around here. Ground is too hard for a sand anchor.
Shovel, 4 tire air up/down hose set, just need another compressor as the Wife keeps "ours" in her pickup.
Still gathering stuff. Fortunately haven't used any of it yet.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 02-23-2020, 09:58 PM #19
ericantonio ericantonio is offline
ericantonio is on a distinguished road
Great info thanks!!!
2017/SR5
6112/5100/OME/Camburg/MethodNV305/285/70/17
ericantonio is offline   Reply With QuoteReply With Quote
Old 02-28-2020, 01:25 AM #20
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
A come-a-long is much safer than a hi-lift for winching. And easier.
I am in so cal. I have actually needed and used:
Tow strap
Shovel
Tire repair
Compressor to air down and up
Shackles
Jumper cables
TP
Knife
Multitool
Tire pressure gauge
Batteries, AAA and AA
Chains for snow
delloro is offline   Reply With QuoteReply With Quote
Old 02-28-2020, 12:49 PM #21
Ripper238's Avatar
Ripper238's Avatar
Totally agree. I totally want to get a come-a-long but the good ones are so darn expensive and the cheap ones suck.
Old 03-02-2020, 08:49 PM #22
Tow strap
Shovel
Tire repair
Shackles
Jumper cables
TP
Knife
Multitool
Tire pressure gauge
Chains for snow
Thanks so much!!! Any brand of come-a-long you recommend??
2017/SR5
Old 03-02-2020, 11:09 PM #23
delloro's Avatar
delloro's Avatar
Maasdam Pow'R Pull 144S-6 1 Ton Capacity Pow'R Pull USA Made - Come Along - Amazon.com
Made in the USA!
Or a heavier rating, but likely imported Amazon.com: Allied Tools 64DGCP8 4 Ton Heavy Duty Dbl. Gear Cable Puller with 3 Safety Hooks: Home Improvement
Old 03-07-2020, 09:22 AM #24
Oh my Amazon list-of-things-to-get!
I've always wondered why people get a Hi-lift and use it as a winch. I never thought of "just get a winch". I see truckers use these all the time.
Thanks!!!
2017/SR5
Old 03-07-2020, 01:57 PM #25
Ripper238's Avatar
Ripper238's Avatar
But do they have the travel needed? Some of these cheap ones only pull for a few feet.
Old 03-07-2020, 03:14 PM #26
delloro's Avatar
delloro's Avatar
About 10 feet. Will have to pull, reset, pull again maybe.
The version with a pulley pulls 2x as much, 1/2 as far. Still better than a hi-lift for pulling.
Old 03-08-2020, 10:57 AM #27
Ripper238's Avatar
Ripper238's Avatar
Ok, many i have seen reviewed with only 3ft of travel. lol
Old 03-08-2020, 11:15 AM #28
barongan barongan is offline
barongan is on a distinguished road
Originally Posted by dade73 View Post
Just my $0.02
What is your goal for this - just weekend trips, overlanding, rock crawling?
Deciding that and your budget will help determine some what of your order. Self safety should always come first. Once you have a first aid and extinguisher then work on recovery.
weekend warrior:
jumper cables (or jumper battery back)
snatch strap
tow strap
recovery boards
winch extension
winch
tree saver
fuel
hi-lift/farm jack would be on of the last items
Overlanding:
jumper cable (or jumper battery pack)
fuel
water
snatch strap
winch
recovery boards
tree saver
hi-lift jack
Rock crawler:
same as weekend warrior, but move the hi-lift jack up as the tendency to brake things increases greatly.
Check local forums and FB groups. You might be able to find some of that gear a little cheaper, and the mighty amazon has all kinds of things available. Like other have stated before, practice using your equipment, so you are so comfortable with it, that when an emergency occurs, you are prepared.
Comms: You need to work in with what ever your group you are running with first. I currently run CB and GMRS. I will be adding HAM soon, just because some groups have one and not the other.
Nice
barongan is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 09:25 AM #29
cotto4 cotto4 is offline
cotto4 is on a distinguished road
Very helpful. I've been putting this off for too long
cotto4 is offline   Reply With QuoteReply With Quote
Old 04-20-2020, 02:00 PM #30
5VZ-FE's Avatar
5VZ-FE 5VZ-FE is offline
5VZ-FE will become famous soon enough 5VZ-FE will become famous soon enough
5VZ-FE's Avatar
Thanks for all the info!
‘98 T100 SR5 4X4 5spd (sold)
‘99 4Runner SR5 4x4 5spd E-Locker Unicorn
5VZ-FE is offline   Reply With QuoteReply With Quote
gas , order , roads , trails , type
Your favorite tools for wrenching / tech tools for special applications Jhelms 3rd gen T4Rs 340 09-19-2021 10:20 PM
Kobalt tools seem to be getting phased out. What mid-level tools do you guys prefer? repo Off Topic 12 04-20-2019 11:24 AM
Emergency gear/tools to keep in your T4R Hellamatic General Discussions 37 05-19-2017 12:13 AM
MOVING SALE IN NH: Tools, drill press, yard tools, etc clemson4r For Sale: Non-T4R Items 0 06-16-2016 08:49 PM
FS: Mac tool box, tools, cart, diag tools lot. IL Nikkshepherd For Sale: Non-T4R Items 16 04-20-2016 05:34 PM
