Old 03-03-2020, 07:05 AM #1
Munson Munson is offline
Munson is on a distinguished road
How Do You Change a Tire (Jack Recommendations)?
Hi All,
Looking for recommendations on how ya'll with lifted rigs change a tire either on the side of the road or a trail (not at home). I have about a 2.5" lift using Icon Stage 2. I have a hi-lift jack but stock bumpers. I dont trust my N-Fab bolt-on "sliders" as a jack point for the hi-lift unless someone has information to the contrary.
I'm thinking the best option for me is to get a floor jack but I have no room to keep it inside the truck and secured. I was thinking about putting it in a case on my roof rack but that would not only raise the center of my gravity but also be heavy lifting up and down.
What is ya'lls plan if you get a flat while out?
Thanks,
M
Munson is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 11:44 AM #2
Sea_ledford Sea_ledford is offline
Sea_ledford is on a distinguished road
Have you tried the stock jack? I have a 3" lift and I can get any wheel off the ground with the stock jack with room to spare. Rear wheels are easy since you are lifting the axle, but the front is a frame lift behind the front wheel. I should also note I'm on stock sized tires.
I have not done that offroad yet, but I have a hi-lift base plate that'll stabilize and lift the base of the jack a little bit.
There is also safe jacks: Safe Jack - 4WD, Outdoor,Off road, 4X4 accessories and products.
and I found a guy that makes top adapter for the stock toyota jacks here:Jack Adapters - Land Cruiser Products - LCP
I've asked on the safe jack website if their adapters will fit over the toyota bottle jack and haven't ever heard back, but based on measurements, it wont work. Which is a bummer, I'd like to get their extension set, but not sure I want a hydraulic bottle jack to use it.
2019 ORP
Dobinsons suspension- Front:C59-314 / GS59-700 Rear:C59-325 / GS59-701
SSO Slimline bumper with Warn VR Evo 10-S, LFD Offroad crossbars
Diode Dynamics SS3 fogs,GE Megalight Ultra +130 low beam
Sea_ledford is offline   Reply With QuoteReply With Quote
Old 03-06-2020, 03:26 AM #3
You got me! I haven't tried the stock jack yet...but I did use it when the truck was stock and I wasn't really a fan.
However....that safe jack looks awesome, I think that will work great for what I am looking for! I really appreciate it!
M
Old 03-11-2020, 09:26 AM #4
cotto4 cotto4 is offline
cotto4 is on a distinguished road
Thanks for sharing!
cotto4 is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 06:52 PM #5
Justthemechanic Justthemechanic is offline
Justthemechanic is on a distinguished road
I carry a Powerbuilt jack. It has a nice wide base, locks like a jack stand and its not too large. It works well for me.
6000 Lb. Unijack Bottle Jack & Jackstand in One – Powerbuilt Tools
Justthemechanic is offline   Reply With QuoteReply With Quote
Old 03-12-2020, 01:28 PM #6
Drunner97's Avatar
Drunner97 Drunner97 is offline
Real Name: Danny
Drunner97 will become famous soon enough Drunner97 will become famous soon enough
Drunner97's Avatar
Real Name: Danny
Stock jack works fine under the rear axle or under the lca in the front on a flat surface. You just have to load the suspension enough to get the tire off and back on. You don't need a lot of clearance if you're just changing a tire.
build thread: https://independentoffroading.com/in...xit-thread.30/
IG: @4runner_doa
Drunner97 is offline   Reply With QuoteReply With Quote
Old 03-12-2020, 03:45 PM #7
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
You also don't want a jack that is too tall to get under a jack point when the tire is flat.
Stock jack + 6 ton bottle jack + 2"x6"x12" + 4"x6"x12" has sufficed for more situations than I've encountered
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 04-15-2020, 11:23 AM #8
TomasON TomasON is offline
TomasON is on a distinguished road
thanks for the tips.
TomasON is offline   Reply With QuoteReply With Quote
Old 04-15-2020, 11:46 AM #9
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
I also have stock bumpers (no hi-lift jack points) and have been looking into the air jacks: Amazon.com: Honhill 4T Exhaust Air Jack Inflatable Jack for SUV Car Truck Off-Road Rescue: Automotive
I can't find a reason NOT to get one to toss in the truck (or car). Will work on looser terrain as well such as snow and sand.
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
change , hi-lift , jack , recommendations , thinking
Recommendations for jacks & jack stands? optik General Discussions 27 09-27-2017 07:41 AM
Lightweight aluminum jack for travel - anyone have one? Recommendations? BrianSD_42 General Discussions 11 11-21-2015 03:21 PM
Where to jack up the truck to change the tire spoiler900 3rd gen T4Rs 6 10-13-2014 02:12 PM
Recommendations on Floor Jack? jamess Maintenance/Detailing 5 05-10-2010 04:04 AM
Floor jack recommendations? xUSNavy Maintenance/Detailing 3 10-29-2006 08:45 PM
