Old 04-04-2020, 05:50 PM #16
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Originally Posted by Shawnm126 View Post
Dude, where did you get those batteries and how much are they?
If you were talking to me and referring to post #13, that was pulled from the Tesla Model S battery pack.
They cost about $900-$1500 each depending on where you source them and their condition.
It might sound expensive, but it's not. It would take 7 Odyssey Extreme group 34 batteries weighing in at 350 lbs to match it's raw capacity.
The Tesla module weights 55 lbs and still has a longer service life.
You can find these all over the place like forums/eBay. EV West in San Diego is a reputable place to buy stuff like this. They specialize in EV conversions but also sell parts to DIYers.
Tesla Model S Lithium Ion Battery 18650 EV Module - 22.8 Volt, 5.3 kWh, EV West - Electric Vehicle Parts, Components, EVSE Charging Stations, Electric Car Conversion Kits
Old 05-03-2020, 04:18 AM #17
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
Dang. All this fancy stuff. I have a 400W inverter hard wired into my rear cigarette lighter and bolted to my sleeping platform. It charges my laptop and other electronics while the truck is on, then powers off when the truck is off so I don't drain my battery. I can also run a drill and electric chainsaw off of it (smaller one). Works like a charm.
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
MrSeth is offline   Reply With QuoteReply With Quote
Old 06-01-2020, 02:33 AM #18
Thebeastlives Thebeastlives is offline
Thebeastlives has a spectacular aura about Thebeastlives has a spectacular aura about
I have 2 in my 96 4 runner. I used them to charge my laptop, tablet, phones, run air compressor and other off the grid items that need when camping or offroading.
Thebeastlives is offline   Reply With QuoteReply With Quote
Old 11-03-2020, 07:27 AM #19
buterin buterin is offline
buterin is on a distinguished road
Indeed, for me, a 110 volt AC power inverter is enough for camping. I also had an old one that couldn't give enough power for such needs. And I found a new one on 10 Best RV Inverter Reviews 2020 – Expert Buying Guide. Indeed, there are many models for an affordable price. My friend decided to make an inverter by himself and he suffered for half a month until he collected everything for it and after all, it worked badly and there were crashes. Honestly, I don't understand why spend so much time, nerves and energy if you can buy a new and better one for a democratical price.
buterin is offline   Reply With QuoteReply With Quote
Old 04-23-2021, 10:04 PM #20
AspenBob AspenBob is offline
AspenBob is on a distinguished road
I run an electric blanket in my roof top tent. Nothing better than getting into a warm bed on a cold night!
My 2nd battery, an Optima, will run it for an hour or so, with the charge dropping from 100% to about 75%.
2008 4Runner SR5 V6
AspenBob is offline   Reply With QuoteReply With Quote
Old 10-05-2023, 04:19 AM #21
wheeler00 wheeler00 is offline
Real Name: James Wheeler
wheeler00 is on a distinguished road
After installation, test the inverter with a few low-power devices to ensure it's working correctly. Gradually add more load to verify its capacity. Keep an eye on your battery voltage when using the inverter. Prolonged use can drain the batteries quickly, so you may need a battery monitor to prevent over-discharging
wheeler00 is offline   Reply With QuoteReply With Quote
Old 10-05-2023, 05:04 PM #22
wegotarnr wegotarnr is offline
Real Name: Adam Nguyen
wegotarnr is on a distinguished road
I have a 2016 4unner. It is currently on a dual battery system that is not permanent. We have it connected to a 200w solar charger with a 25amp DCDC controller. For our vehicles, an inverter would not always be needed vs RVS. We have other 12v sources we can run to save power. I was running an inverter with my 200AH LITHIUM battery and rarely used it and if you run an inverter on an AGM battery you can only take 50% before you damage your battery vs lithium. All of my connectors are VIA Anderson connector due to the reliability and that cig sockets are limited in the amount of power it can push. I know diving into power on your rig can be intimidating but it is awesome once dialed in. With our set up and fridge, our battery can last up to 5-6 days on solar without tampering with the starting battery (Low voltage disconnect needed). I use to run the kickass system but have then found a better set up with redarc, if you want to see some pics of set up here: https://www.instagram.com/adam.built/
wegotarnr is offline   Reply With QuoteReply With Quote
install , inverter , nope , power , usb
Talk me out if it. Or talk me into it haha poser 3rd gen T4Rs 21 12-12-2014 06:16 PM
Stuck at Hood - Can't Talk about it so Let's Talk about My Truck? Ryan1975 5th gen T4Rs 4 04-03-2014 01:06 AM
inverter kevinpt 4th Gen T4Rs 4 11-25-2012 01:38 PM
What do you use the inverter for? CJ3Flyr 4th Gen T4Rs 27 01-26-2009 03:27 PM
Power inverter hulk311 4th Gen T4Rs 9 05-12-2007 12:30 AM
