Old 03-26-2020, 12:29 AM #1
4Reak Show's Avatar
4Reak Show's Avatar
Talk me into installing an Inverter
Alright, so I came across a brand new 1,000 watt inverter that I can easily install as a removable unit in my old 95 and have no issue doing it. But really, why? And I'm serious. I can't think of a legitimate reason to need 110volt AC power when off roading or camping.
Common uses of inverter in an RV:
1) TV. Nope don't want that to camp
2) coffee maker. Nope. Jet boil.
3) hair dryer. No. Just no.
4) charge phones/devices. Nope, I have 3 USB ports.
5) maybe a portable fan? But again, could run one off USB or cigarette outlet.
6) CPAP machine. Fortunately I don't need one.
7) power tools? I would think if I break something so extreme to warrant a tool requiring 110VAC I'm doing something wrong.
8) fridge. I rock an ice chest but I suppose that would be useful.
So what am I missing? I want to justify this install but I'm having a hard time finding a purpose.
Maybe blender for margaritas?
Old 03-26-2020, 01:54 AM #2
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
I guess I am in the same boat. I have one and I rarely ever need one, but I like having the capability. I don't even store it in the truck.
I did it more or less just because I can... I use a lot of Anderson Powerpole quick disconnects and I have a few different locations in and outside of the truck where I can plug one in.
The last time I used it was when I was helping a friend with some electrical work on the truck. Wasn't near an outlet. Used it to run my heat gun for shrink tube. Also used it with a Dremel tool once. The thing is... once you have it, you find uses for it.
Old 03-26-2020, 01:56 AM #3
Bumbo's Avatar
Bumbo's Avatar
Plus... do you even have anything better to do right now with all this Covid 19 action?
Sound like an ideal self isolation project.
Old 03-26-2020, 09:42 AM #4
4Reak Show's Avatar
4Reak Show's Avatar
That's funny, I just modified my subwoofer assembly main battery connection to those style connectors
So my plan was to just put the same connector onto the inverter and then I can plug and play as needed. (whenever that is).
Maybe mostly why I want to is just to have the added option. Maybe power goes out at home and I can run one of my house fridges while truck idling? Math says they only pull 600w. Inverter is an RV grade 1000w continuous, 2000w peak for motor start ups. Or a small space heater when sleeping in the truck in winter.
Old 03-26-2020, 12:40 PM #5
Bumbo's Avatar
Bumbo's Avatar
Those are called the SB50 series Anderson Connectors... I generally scavenge them off server APC UPS units. I got a ton of them...
You can buy parts from these guys... I generally keep the housings and buy extra 10, 8, and 6 AWG crimp heads so I can upgrade the cabling.
SB50 SB Series 50 Amp Anderson Powerpole Kit | Powerwerx
Something you might need to do to reliably run 1000 watts as that is a 84 amp load at 12 volts. I run these modules in parallel so I can distribute the load.
Another thing to consider is just making a battery project so you have some reliable emergency power for home that has nothing to do with the truck. I made a small DIY solar setup at home... it powers my HAM radio and ARB fridge 24/7 in an off-grid manner. I also have the option to use my inverter with that setup too if needed.
Old 03-26-2020, 11:10 PM #6
4Reak Show's Avatar
4Reak Show's Avatar
Oh dude awesome! I was also able to procure 2 really nice HEAVY 6 volt batteries that produce 400 amp hours when wired in series. So I'm building a little cover for that and have the inverter and battery bank just be its own thing. And by using those same subwoofer style connectors to connect the inverter and batteries, it does allow me to toss the inverter in the truck if I ever want to. Or the whole battery contraption if I have the need. I like the versatility options.
That website only offers 6 gauge versions, but I'm using 4 gauge wires since again, I have an abundance available to me. Do you know if the pins run large and the 6 gauge may fit a 4 gauge wire?
I ask because the ones I used on the subwoofer were advertised at 2-4 gauge and they were massive.
And the inverter will have a 100 amp cube style fuse on it, which is what the machines at work utilize for this exact set up.
Edit: nevermind I found the bigger ones. I have 175 amp version on the subwoofer so I'm going to stick with that all around for switchability. I like to go bigger to avoid weak links.
Old 03-27-2020, 07:49 PM #7
Bumbo's Avatar
Bumbo's Avatar
That’s great. It’s hard to tell the size by photo but they have up to SB350 series which handles 1/0 to 4/0 wire.
Those 6v solar/golf cart batteries are excellent for deep cycle work. That would pair very well with that inverter. If you need a recommendation for a really great solar charge controller I highly recommend the Victron Energy Smart Solar MPPT units. They are fully programmable which makes them very versatile and usable with lead and lithium batteries, "smart" units have built in Bluetooth capability for their app, data logging and reporting… and pretty affordable for what you get. Here is a screen shot.
All this DC power and battery stuff is kinda my jam... its what I enjoy most about these types of project at least
Right now I’m just playing with it and moving it around to different setups, but the plan is to get it into the 4Runner with a panel on the roof so I can actually see what’s going on with my electrical system and fridge loads.
Ultimately it’s going to charge a compact lithium battery for my fridge setup which is still kinda in development, but the proof of concept testing has already been done. System is complete with its own battery management setup so it can safely be charge/discharge unattended.
I want to build all the cells into a low profile drawer system under the fridge... most people wont even know its there unless I told them. Technically it would become a triple-battery setup as the fridge now has its own dedicated non-shared power source.
Made using recycled 18650 batteries, I basically got for free...
Old 03-28-2020, 12:42 AM #8
4Reak Show's Avatar
4Reak Show's Avatar
PM sent.
Oh dude nice! Yeah I've installed TONS of solar at work, but it's normally a simpler controller system. Not a lot of victron yet. Mostly just lithium batteries with massive inverters and some basic solar panels.
I'll post up pictures once I finish my modular inverter system.
By the way, the 6v Trojan AGMs are HEAVY batteries.
Old 03-29-2020, 03:10 PM #9
4Reak Show's Avatar
4Reak Show's Avatar
So far I've decided to leave it as a modular, stand alone unit, eventually to have connectability to my 4Runner via the Anderson plugs I'm waiting on. Here is how it looks buttoned up, besides the 12 volt cables which will run through the lid's corner.
Inverter is attached to the lid, and that comes off with the top of the battery box
The box is not attached to the batteries other than a snug fit over the tray. To build a box strong enough to lift and support those 2 batteries would be stupid. Plus moving both batteries at the same time in a box that big is like moving a dead body. If I need to lift them into my truck for a trip or whatever, the top lifts off, then the surround lifts off. Couple of connections and each battery is independent again so transport is easy. Otherwise, I can just slid the whole contraption around on my garage floor pretty easy.
I'll post pictures once I get the big connectors and finalize it all.
Old 03-29-2020, 05:21 PM #10
Bumbo's Avatar
Bumbo's Avatar
Nice work... simple yet effective. I like that you can keep the battery box separate from the inverter. Solid use of Anderson plugs.
Not that it's legal to do without a generator interlock kit on your main breaker panel, but you could use that like a generator to back-feed the house for backup power to run a fridge in the event of a power outage.
Something like this might be pretty useful around the garage or house.
18 In. x 12 In. 1000 lb. Capacity Hardwood Dolly
If you have a backyard or place to store that and dont use it often, I would add a solar charge controller and a 100 watt solar panel just so its always charged, maintained, and ready to use.
Old 03-29-2020, 10:49 PM #11
4Reak Show's Avatar
4Reak Show's Avatar
Thanks! A solar controller is a great idea. We may even have a couple floating around somewhere that got upgraded. Good call for keeping it charged without even thinking about it.
Old 03-30-2020, 12:33 AM #12
supercliff2 supercliff2 is offline
supercliff2 is on a distinguished road
I haven’t found a use yet but just finished installing a 1000w inverter and custom cabinets in back. I ran 4 gauge wires from the 2nd battery in the engine bay to the back. I have a portable folding solar system and can connect it to the battery when camping via Anderson connectors.
(Lower left side is for a fridge which isn’t in the shot. )
supercliff2 is offline   Reply With QuoteReply With Quote
Old 03-30-2020, 12:18 PM #13
Bumbo's Avatar
Bumbo's Avatar
Originally Posted by supercliff2 View Post
I like it. I need a cabinet / base for my fridge that looks just like that.
It’s the ideal shape/size for these battery 5 kWh battery modules which would run the ARB 50 for approximately 14 days straight at 75F ambient.
Old 03-30-2020, 08:56 PM #14
4Reak Show's Avatar
4Reak Show's Avatar
@supercliff2 Looks really good! I'm also in the planning stages of a drawer system for my 2nd gen. I just can't commit to fully/permanently mounting those insane batteries I acquired. It would literally be like always hauling around an additional person. So my drawer system is going to be 3 way convertible but that's for my build thread.
Anyway, Do you have a link to those drawer slides with the locking handles? Those look pretty cool.
Old 04-04-2020, 05:07 PM #15
Shawnm126's Avatar
Shawnm126 Shawnm126 is offline
Shawnm126 is on a distinguished road
Shawnm126's Avatar
Dude, where did you get those batteries and how much are they?
Shawnm126 is offline   Reply With QuoteReply With Quote
install , inverter , nope , power , usb
Talk me out if it. Or talk me into it haha poser 3rd gen T4Rs 21 12-12-2014 06:16 PM
Stuck at Hood - Can't Talk about it so Let's Talk about My Truck? Ryan1975 5th gen T4Rs 4 04-03-2014 01:06 AM
inverter kevinpt 4th Gen T4Rs 4 11-25-2012 01:38 PM
What do you use the inverter for? CJ3Flyr 4th Gen T4Rs 27 01-26-2009 03:27 PM
Power inverter hulk311 4th Gen T4Rs 9 05-12-2007 12:30 AM
