Old 03-14-2021, 02:03 PM #1
Gamma Ray's Avatar
Gamma Ray Gamma Ray is offline
Gamma Ray is a jewel in the rough Gamma Ray is a jewel in the rough Gamma Ray is a jewel in the rough
Gamma Ray's Avatar
Removing braces for skid plates?
I was watching this video last night from Victory 4X4 about their install of the Victory 4X4 skid plates.
https://www.youtube.com/watch?v=8JLF9z_18SY
I saw that they removed some parts that they called crash bars and another thing they referred to as braces of some sort. They put the skid plates on after removing those parts, but those parts remained off.
Is keeping those parts off really a good thing? They look like they're rather sturdy things that would provide structure for the vehicle, and I'm not sure if the skid plates would be good replacements for those parts. I've got to wonder if skid plates that go on over these parts would be better for the vehicle in the long term.
I'm reminded of these cracks in the wheelwells that I've seen people have. Perhaps there's a correlation between removing these parts and a stretching of the wheelwell to the point of cracking? And if not this, then maybe something else?
Gamma Ray is offline   Reply With QuoteReply With Quote
Old 03-14-2021, 02:36 PM #2
AMLOR AMLOR is offline
AMLOR will become famous soon enough AMLOR will become famous soon enough
My .02...I have a PRO with the factory Pro skidplate. I chose RCI for my skids specifically because they have an engine skid that integrates with the factory skid. A GX460 obviously does not have this. so...maybe not apples to apples, but close.
That said, those curved "crash Bars" (NOT the ones to the radiator support) were also removed with the RCI units. I was satisfied that the skid itself took on most of the stiffness of the removed bars. I based this on how the skids bolted up to the vehicle; using the factory bolt holes for the removed bars, to secure the skid plate. Very solid.
The PRO skid plate bolts up to the same place on the radiator support as the "s" shaped braces, and to the cross member in back. Is it as strong as those braces...dunno. But the Pro skid is a stout piece of metal, and I'm willing to consider that an "acceptable risk".
Good luck!
AMLOR
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, Whiteline, C4 Fab, BPF, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, Metal Tech, StrongBox, Eibach Load-Leveler rears & TRD Pro front coils, CE Auto Elect., Blue Sea, SP9100, Cornfed, RCI skids, BajaRack "basket", RIG'd Ultraswing, REV Gear 4.88's, NOCO 5x2 onboard
AMLOR is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 12:09 PM #3
ahtoxa11 ahtoxa11 is offline
ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about
Interesting. When I installed my RCI skids just a month ago, the insructions specifically stated to leave those on, which I did. There are spacers that are integrated with the mounts of those curved braces. The spacers act to clear the exhaust.
ahtoxa11 is offline   Reply With QuoteReply With Quote
Old 03-22-2021, 02:00 AM #4
SoCalAl SoCalAl is offline
Real Name: Al
SoCalAl is on a distinguished road
Real Name: Al
I mounted mine the same way as ahtoxa11. I bought the aluminum RCI full skid plate package during last months group buy. Mounted it this month on a 2021 ORP. I could be wrong, but I believe the TRD Pro does not have the “crash bar/curved braces.”
SoCalAl is offline   Reply With QuoteReply With Quote
Old 03-26-2021, 04:27 AM #5
JPOVS's Avatar
JPOVS JPOVS is offline
JPOVS is on a distinguished road
JPOVS's Avatar
Few years ago I installed the TRD skid plate and there was no instructions to remove the bars. Like the previous two posters I recently added the RCI front skid and that had no instructions to remove the bars either.
My only thought is why didn’t RCI use the same bolt holes under the radiator that the TRD skid used that also mounts the front of the bars? Would of saved me a lot of time cleaning out the threads of the holes next to them that were caked with mud. The originally used holes are much stronger location with larger bolts.
2016 TEP, Elka 2.5 RR Adj F&R, Chaos UCA & LCA, OME 899, KO2 285/70E, Wheeler F&R Bumps, BMC, Nitro 4.88 Gearing, Hefty Fab F&R Bumpers Dual Jerry Swing, Warn Plat 12s, Icon Pan & Billet Rear Links, Gobi Stealth Line-X, RCI Sliders, Every RCI Skid Plate (In Alum if avail), SCS Stealth 6 Rims, ARB Twin Comp, ARB 2500 Awn, Quick Pitch Shower Awn, Compustar T11 & RMS, Dual 42" drawers W/ Adj sleep/dog height platform (2nd Row Removed). Switch Pros, Baja LP9’s, S2 Pros A-Pillar and Rear Bumper, Rock Lights, Dometic CFX3 35qt, Transmission Cooler
Overland Explorer TDK Trailer, 2x Battle Born Batts, Victron BMV712, 4x Baja S2 Pro, 2x ARB Awn + many acces, 6x Baja Rocks, Dometic CFX 65DZ,
JPOVS is offline   Reply With QuoteReply With Quote
Old 03-31-2021, 01:05 PM #6
91foxbody 91foxbody is offline
91foxbody will become famous soon enough
Out of sheer curiosity, what was your order number? I think I got into the order pretty early but I'm still waiting for my full AL set.
91foxbody is offline   Reply With QuoteReply With Quote
Old 05-13-2021, 08:03 PM #7
For what it's worth, I went back re read the instructions and reinstalled the curved frame braces.
Yes the Pro models also come with the braces...at lease my '19 did.
AMLOR
Old 06-11-2021, 09:19 AM #8
Sundy Sundy is offline
Real Name: Ryan
Sundy has a spectacular aura about Sundy has a spectacular aura about Sundy has a spectacular aura about
Real Name: Ryan
I had to pull these loops off with my RSG skid plate - the skid seems much beefier and uses the mounting points compared to the radiator support hoops which were removed.
I've also got an aftermarket bumper so the OEM crash bar is long gone
2019 TRD ORP w/KDSS: Dobinsons IMS Lift (front C302 - 3" / rear C725 - 2.5"), Freedom Offroad UCA's, Falken Wildpeak AT3W 255/80R17, RSG Angled Kickout Sliders & Skid Plate, C4 Lo Pro, Warn Evo 10S, Agency 6 Flatlink, Diode Dynamics SS3 Fogs, Desert Does It Seat Jackers, UpTopOverland Bravo Rack (on order)
Sundy is offline   Reply With QuoteReply With Quote
Old 06-11-2021, 06:16 PM #9
MAST4R's Avatar
MAST4R MAST4R is online now
MAST4R is a splendid one to behold MAST4R is a splendid one to behold MAST4R is a splendid one to behold MAST4R is a splendid one to behold MAST4R is a splendid one to behold MAST4R is a splendid one to behold MAST4R is a splendid one to behold
MAST4R's Avatar
I have all possible functional skid plates (no A arm ones lol) and have not removed nor would remove anything of that sort from the vehicle.
It makes no sense to me at all to be removing those supports and I would rather have the Toyota parts than a small shop alternative. They provide structure to the RCI 3/16 steel front skid plate, in my case. Ask me how I know (the entire pax side of the front plate is caved in but the support in question held on).
I have skid plates to make things stronger, not to sweat them out.
As for bumpers, that's different, it is an obvious binary decision: do or not. With skid plates, there is no need to have to make X vs Z decisions.
(6112s/650lb at 1.25" lift, 8100 rear with Eibach 1" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
MAST4R is online now   Reply With QuoteReply With Quote
parts , plates , removing , skid , thing
Access to oil filter w/o removing OEM skid plates obxbird 5th gen T4Rs 14 07-07-2021 08:22 PM
Painted Stock Skid Plates (Bash Plates) AggieOE 5th gen T4Rs 0 07-09-2020 09:47 AM
FREE 2017 OEM Skid Engine Skid Plates, Lakewood CA choochoo Free 1 11-04-2019 02:07 PM
Breaking bolts while removing skid plates WiscoRunner 4th Gen T4Rs 13 06-05-2019 08:08 PM
5th gen; RCI full skid plates/fuel tank skid LOCAL ONLY (LOS ANGELES) madlib For Sale: T4R Items 3 02-27-2017 03:58 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
